Question about Apex Digital DRX-9200 DVD Recorder
I have a DRX-9000 DVD recorder and am looking for a power supply board JK007686166 RU E190089 CFR-1 94V-O or a diagram to use a PC power supply and where to hook it up or where to soder.any help?guywintersjr@yahoo.com
I have an external dvd/cd rewritable drive by SONY model DRX-S70U-R and is not recognized by de system... my operating system is windows 7 ultimate service pack 1... what can i do? Thans fpr you rhelp
Do you know that you cant run this drive just from the usb port? It requires its own power supply and i suspect you have this missing. The voltage and current value should be near where the plug plugs in so you can get the correct supply.
May 26, 2011 | Sony DRX-S70U-R DVD±RW Dual Layer Burner
I think that my baseline dvd recorder Model no:dvd772 was exposed to a power surge. As a result, some of the components on the supply circuit board is blown. Where can I get the circuit diagram or where...
Many people buy parts items from ebay to fix their own defective units. Just read the problems of the parts item, then you can decide if the parts you need is available from the broken unit?
Nov 18, 2010 | Televison & Video
Do I need a DC plug to operate the Sony DRX-820U burner? I don't seem to find it.
At the back side of your dvd recorder, near the USB port, is the connector for connecting the external power supply (12Volts, 3.0Amp) that is included in the box.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 04, 2010 | Sony DRX-820U Burner
H&B DRX-430 region free code
with no disc inside press 7, 7 and a number (1, 2,3...) for a desired region code ( 0 for all regions)followed by power off
Sep 16, 2008 | H&B DRX-430 DVD Recorder
Transformer
The Power supply was made to fail on this model. I would recommend using a Regular Computer Power Supply. It would cost $20 to $30 dollars for a brand new supply if you don't already have one to use.
Aug 24, 2006 | Apex Digital DRX-9200 DVD Recorder
Apex Digital DRX-9200 DVD Recorder Logo
123 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
