Question about Refrigerators
Hi, I have a Hotpoint refrigerator model #CTX21. This refrigerator has hardly me any problems until now. The refrigerator does not seem to keep the foods cold. I'm notice foods seem to be spoiling quicker than normal. The freezer is doing fine
  • Refrigerators Master
  • 1,711 Answers
The most posible fault is a dirty condenser.
The condenser in your model is located behind the base grille on the bottom of the fridge. Remove the base grille by grasping it at the bottom andpulling it out. Now either sweep away or vacuum dust that is readily accesible.
This easy cleaning should be done at least once a year for most efficient operation.
Their is also a smaler posibility that the automatic defrost system which can be either the defrost thermostat or the defrost heater.
So if the condenser cleaning will not make a change after a couple of days then switch of the refigerator for tow hours and try to keep door closed so good not spoiled. then switch it on again and notice if you have desired temperature. You should find a thermometer so this will help you realise the deference in temperature more acurate.
Good luck and thanks for using FixYa.
Posted on Aug 31, 2010
Help? Top mount fridge not cooling?
many times there is a freon leak, and you have two choices. Go to a place like autozone and get a freon can with sealant (11 ounces or so) or take it into a hvac store and ask them to recharge. Many will test it for free and tell you whether it is good or bad. Usually not a thermostat problem but seals do go badk, and the sealant swells these up again.
Aug 21, 2014 | Refrigerators
Problem with rlb20 model is that it keeps freezing up
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 29, 2011 | Hotpoint Refrigerators
The Ice maker in my mother in laws Hotpoint CTX21 refridgerator is no longer producing ice. I have water pressure in the water line going into the "valve" at the bottom rear of the fridge. And...
Replace the icemaker. It sounds to me as though the harvesting thermostat has gone bad and it would cost more to have a serviceman fix it than to just buy a new icemaker. This is a common problem that I've seen so many times !
Sep 29, 2017 | Hotpoint 21.7 cu. ft. Side-by-Side...
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Hotpoint Refridgerator HSS251FMBWW, Ice dispenser runs by itself
Hi! Hopefully the manual of a similar Hotpoint fridge witll help you. There may be not a unique reason of this problem. Seems that it might be a problem of a cube dispenser.
https://manualsbrain.com/en/manuals/820483/?page=32
Aug 09, 2017 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
hi thanks for the question you problem could be a no defrost problem remove the floor of the freezer 4 screws lift from back to front remove foam if its all frosted up you have a defrost problem a bad fan motor also can cause this it could also be stuck in ice if so use hair blower and thaw dry it real good re assemble and try again thanks the appliance doc
Sep 22, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
126 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
