Question about Samsung HLT6176S Television
I have a Samsung HL-T6167S DLp that has a picture problem. The picture isn't bright enough to see at all during the day. And due to low light levels it is just barley visible at night with all the lights turned out. We have tried all adjustments and nothing works. Now when you turn on the TV it takes a while to turn on after the green indicator light then the red indicator light then green lights switch back and forth till it takes a couple if minutes to turn on. I know that allot of problems can be solved by replacing the lamp. But if you think this is my problem is it possible for the bulb to be bad and still show some light. When a normal light bulb blows it doesn't work at all, is this type of bulb different?
  • 5138 Answers
SOURCE: Samsung DLP HL-R-5667W lamp LED comes on solid, no picture, then turns off
DO you have the owners mannel if so read it and see what they would do ,have you removed the lamp and if so how did it look? some lamps only last for 5,000 hrs and others 8,000 hrs If lamp is bad TV will not come on.
Posted on Feb 20, 2008
SOURCE: DLP no image at time - no chime - lamp light blink but no image - sometime 3 front panel lights blink
i have the exact same issue.
have you found the cause?
Posted on Apr 02, 2008
SOURCE: Samsung DLP HL-S5087W 56" Confused...
Mine did that when the color wheel didn't spin up...just give it a whack where you installed the light & the wheel should spin up. I had to replace my color wheel as the bearing was shot & was buzzing all the time. The light won't come on if the wheel doesn't spin up first.
Posted on May 10, 2008
  • 558 Answers
SOURCE: my tv turns on but no picture or sound
power pack capacitors have failed they will need to be replaced with new ones and that should repair the tv, soldering skill is required to do this or replacement of the entire power pack.
hope this helps
Posted on Apr 07, 2009
  • 187 Answers
SOURCE: Red light flashes but TV wont turn on
If you dont have the led light on when plugged go ahead and replaced the powerboard, but if your led light is on when plugged then you will need to replace the mainboard.
Hope this info help you.
Posted on Jul 01, 2009
Samsung dlp 1080p picture is dark and brightness control is at max
I am hoping somebody will answer this because my TV is dark and I played with the controls and it is still dark!
Sep 24, 2012 | Samsung HL-S6187W - Rear projection TV -...
I have a Samsung 42" DLP. During the daytime I can hardly see the people and definition on the screen. It is all very dark. Nightime is better.
check your video settings there are 3 or 4 usually that all have various levels of brightness, it may be set to one of thelower ones. or you can go into tv menu and try kicking up the brightness. if no luck the lamp may be failing if not recently replaced they begin to make screen darker before they fail.
Jan 23, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung HL-P4663W/HL is making a buzzing noise
Color wheel needs replacement is the most likeliest cause.
Jan 02, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
I have samsung DLP TV HL-R5087W with pink/green discoloration
NO ,its not the Lamp it is your Light Engine. Call UED for price of rebuilt one 1-800-648-6657.
Sep 24, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
We have 2 problems....dark screen/bright light on right side
Replace the light engine. If you wish to get some details; visit the site linked here. Pull up older posts.
Apr 11, 2017 | Samsung HL-S5087W DLP TV
Samsung DLP RL-P5056W 56" TV Problem
Oct 03, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
81 people viewed this question
Jerry Greenberg
Jerry Greenberg
