Question about JVC XL-R5000BK CD Player
Jvc uxsgs shows reading disc then says no disc
Jvc ch-x350 12 disc cd changer. Loads cd but will not play it. reads: no disc and moves to the next cd and repeats. ??
If you are inserting non original cds, cds you make from your pc or cd copies sometimes they dont read, another reason is to make sure that you are inserting the disk with the correct side up, it will show you in the cd changer magazine slots. If none of this solves your problem then you have a defective cd mechanism and you need to replace or repair the changer. Very common problem with JVC Cd Changers, I used to replace them all the time and they tend to skip alot as well, get yourself a Pioneer if money is ok if not then follow my steps.
Good luck and dont forget to rate and vote for me if I helped you.
Thanks.
Jun 13, 2010 | JVC CH-X350 12-Disc CD Changer
JVC - XV-F80 DVD Player
Either the disc or the player likely need a good cleaning. Clean the disc with a soft cloth, clean the player with a good cleaner disc.
Feb 26, 2009 | JVC XV-F80 Multi-disc DVD Player
Can't eject dvd's.It says"LOCKED'How do you unlock to eject dvds
To unlock the JVC TH-C5 disc tray is by having the system off and at the same time hold the stop button and eject button until it says, "Unlocked".
Jan 10, 2009 | JVC THC5 Home Theater System with 5-Disc...
JVC XL-SV22 Video CD
if cracks having in disc mean some times header does read disc! clean your header with disc cleaner!
Jul 01, 2008 | JVC XL-SV22 CD Player
Some blank DVD+R discs will not read on my DVD player
The JVC DR-MV1S DVD Recorder / VCR Combo does not suppport DVD+R, only DVD-R, -RW etc.
At least mine only supports these formats, as when I first bought mine, I got some blank DVD's they were DVD+R.
I recorded a movie onto one on my PC, then tried playing it in the JVC unit... no go!
Instruction manual (available for D/load online) proved to me that I could not play +R disks!!
Jun 11, 2008 | JVC DR-MV1S DVD Recorder/VCR
Wont read audio discs
If you used a cleaning disc, try again only this time open up the unit and clean the lens using a cotton swab and alcohol. Those cleaning discs rarely work. Let me know if yuo still have a problem.
Dan
May 01, 2008 | JVC MX-K30 CD Shelf System
CDR shows No Disc
Have you tried to use a optical disk cleaner? it will remove dirt from the optical eye and is the first thing I would try. Since it won't read any disks then the optical eye may be dirty you can buy at Radio Shack, Staples, Office supply stores and Wall mart or Wallgreens Pharmacy you can order online at fry's or tiger direct.com hope this helps, if you need more help just post here.
Mar 27, 2008 | JVC XL-R5000BK CD Player
JVC DVD Player/Video Cassette Recorder Model HR-XV2EK
try to clean your machine by playing a lens cleaner disc coz the lens might be dirt enough not to pick on data from the discs you play. if it does not work then isuggest you change the lens coz it might be weak
Aug 01, 2007 | JVC DR-MV1S DVD Recorder/VCR
Home theater won't start playing DVD
If a disc will not spin, A- the laser may not be focusing on the disc, as it must do this before it will spin and read the TOC. ( table of contents) B- you could have a fault in the spindle motor circuit or the motor could be bad. You will need to find an authorized servicer if you do not understand solid state repairs. Good Luck PS please dont forget to rate this.
Oct 14, 2006 | JVC TH-A9 System
JVC XL-R5000BK CD Player Logo
32 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
