Question about Dell Latitude D510 Notebook
My dell d510 battery not charging - Dell Latitude D510 Notebook
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 08, 2010
SOURCE: Dell Latitude D510 will not charge battery
HI, check soldering on Fuse 1 right next to the power inlet plug, just fixed mine.
you will have to dissassemble it completly to get acces to it
Posted on Feb 13, 2009
peeface
  • 180 Answers
SOURCE: battery light is flashing orange on d510 computer
i have a d800 that does the same thing. battery is no good
Posted on Apr 22, 2009
dww0642
  • 79 Answers
SOURCE: ac adapter's wont charge battery or pwr. unit
I would say take to a good PC repair shop (Not Geek Squad) and ask them to look at the power jack on the motherboard, it may need replacing. Next would be more of a a motherboard problem and its just quit. Good repair shops could help you either way get it fixed. I don't recommend anyone tackling any sort of laptop motherboard fix unless you really know what your doing.
Posted on May 04, 2009
  • 14 Answers
SOURCE: Dell latitude d510 new battery wont charge
the laptop charger is the problem, try to fix it if you can or buy a new one with warranty..
Posted on Sep 28, 2009
SOURCE: I have a dell D510 latitude. AC power OK - doesn't charge battery
The battery of the dell D510 latitude is completely bad and need to be replaced. i suggest you get another one and avoid the battery running completely down before charging it.
Compliments and I wish you best of luck
Posted on Dec 24, 2009
Latitude 510 battery light flashing amber and white
Hello, the problem you are having is caused by a loose connection on your motherboard between the charging port and the motherboard. You can either open your computer and try to solder it, or you will need to replace the motherboard.
Another possible cause is that your laptop charger is dead. If you can't confirm, just get a new ac adapter, it is much cheaper than replacing the motherboard:
Replacement Dell Latitude D510 AC Adapter 90Watt 19.5V 4.62A
Replacement Dell Latitude D510 AC Adapter 65Watt 19.5V 3.34A
Nov 11, 2012 | Dell Latitude D510 Notebook
Dell d510 battery not chargeing
Depending on how old the battery is, it may have lost its ability to charge / retain a charge.
Dec 30, 2010 | Dell Latitude D510 Notebook
Dell latitude d510 want power on
Why can't you dell latitude d510 power on?You didn't descript your dell latitude d510 problem clear even.It may be the problem of ram,graphics card ,mainboard,or dell latitude d510 battery.
May 31, 2010 | Dell Latitude D510 Notebook
Dec 24, 2009 | Dell Latitude D510 Notebook
Sep 28, 2009 | Dell Latitude D510 Notebook
Ac adapter's wont charge battery or pwr. unit
Apr 20, 2009 | Dell Latitude D510 Notebook
Jan 20, 2009 | Dell Latitude D510 Notebook
Dell Latitude D510 Notebook Logo
131 people viewed this question
Alun Cox
