Question about Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive
My husband has the 500G WD external hard drive which has worked perfectly until yesterday. Now when he plugs it in, the computer doesn't recognize that anything has been plugged into the USB and it's not listed under "My Computer".
  • 131 Answers
Try it on another computer to see if it is working. Sometimes the USB cable can fail, too, so if you have another USB cable that fits, try it.
If it still does not work, perhaps the drive has failed.
Posted on Aug 31, 2010
Windows xp not recognizing my external hard drive
The most likely reason you cannot see your hard drive on your Windows computer but can on your Mac, is that the drive has been formatted for GPT which is only supported on Windows Vista or 7 or above, not on XP.
See the Microsoft article on GPT here and FAQ's on GPT here
Jan 13, 2012 | Western Digital Elements powered by WD 320...
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
Feb 08, 2011 | Western Digital My Book Essential Edition...
Computer doesn' t recognize iomega eGo portable
a windows update may have run and killed the drivers...try rolling the system back to before the problem started, then if updates run again..and set them to download but dont install..install them yourself..run updates and see if the problem re-appears.
Jul 24, 2009 | Computers & Internet
WD 1TB Hard-drive, worked perfectly now it won't :'(
If you go into Administrative Tools, Computer Management, you will see a tree for disk management. It should be listed there - probably without a drive letter..
You can partition and format there.
To get to administrative tools: Go into your control panel - click on classic view and it is one of the top options.
Jul 12, 2009 | Western Digital Elements powered by WD 320...
Macbook Wont Recognize
Try the drive in another computer.
If it doesn't work it is dead...
May 06, 2009 | Western Digital My Book Essential Edition...
My computer won't recognize my wd my book 500g hard drive. I think it overheated and now is making noise (internal relay switching) It sounds like it's trying to turn on and off but it is on!! What can I...
There can be 3 possible problems since you hear the clicking sound. 1 is that the drive is not receiving enough power from the power supply and it is attempting to turn on. 2nd is the controller board is damaged and 3rd is the drive itself is damaged. From my experience with WD external drives. the 3rd is my best guess. One thing you can try is to buy an external chassis for the hard drive and take the hard drive out of the My Book and put it in the chassis to see if it works. Get one from a place with a good returning policy would also be good as well
Nothing on my Computer
Your disk has not been initialized to work with the Windows NTFS file system.
Go to Start, right click on My computer, and select Manage. Then in the right hand pane of the window that opens, double click Storage, then Disk Management. You should see your drive in here as logical drive 1, likely. It will be the one that is not initialized. from this window you can initialize and format the disk.
Once this is done, Windows should be able to see it.
I hope this helps, please rate!
Mar 18, 2009 | Western Digital External USB 2.0 80 GB...
External hard drive not recognized
I recenctly bought a my book 500 gig drive and it is usb.
the firsttime I plugged the usb cable in it worksed. I had only a 40 gig ide harddrive and so I ordered an internal 500 wd hard drive to replace it. The internal 500 gig is a sata drive. first I cloned the 40 to the sata 500 and then copied the external 500 to the internal. I mover the cables to then make the internal 500 sata my boot drive. The computer would no longer show the external e\when i used the windows explorer. the device manager said it was there and working with no problem but windows did not see it.
After several experiments with diferent configurations I have concluded my motherboard wasauto configuring the external and internal 500 drives as drive 0. Since the usb was detected first and was notthe boot drive then windows assigned the internal drive as drive 0 and since the usb drive was drive 0 also it would not work. windows ignored it. my solution was to return the ide as the boot drive and plug the sata into a slave port. with that configuration both drive are seen and work normally. It took me several days to find this arrangement. so since my sata ports are auto configure and the external has a sata connection i will install an esata port adapter and try to hook it up as a slave sata drive so i cab\n use my internal 500 sata drive as my boot drive.
sorry this was so long but it is my solution to what others may be facing.
May 12, 2008 | Western Digital My Book Essential Edition...
Blinking green light
Same problem. Blinking green light. Device not recognized. Have my whole life on this drive! HELP!
Apr 03, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive Logo
75 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
