Question about Kenmore 57029 Side by Side Refrigerator
Both boxes are warm. the fan runs, and the compressor kiks on for 10 sec. then kiks off i have checked the thermostat and the door seals, both r good. what else could it b?
    Novelist:
    Champion:
  • 266 Answers
Im sorry but it sounds like your compressor is bad. You can try replacing the start relay it is located on the top of the compressor under a plastic cap. The cap is held on by a metal clip. The start relay is about the size of a nickel and is under this cap and attached to one of the three prongs coming out of the compressor. The compressor is located in the back under the bottom of the refrigerator and is about the size of a soccer ball and is black. Make sure you unplug the refrigerator first. I hope I'm wrong and the start relay is bad but most of the time if it kicks in for more than five seconds its the compressor. good luck
Posted on Aug 31, 2010
D768BM2F It starts, we hear the coil kiks in and the compressor comes on for 10 sec and goes off
Sounds like you need a start relay, overload and run capacitor kit. If a fan is defective it also will cause the compressor to start and stop like this (short Cycle)
APPLIANCE911
Aug 19, 2016 | Refrigerators
Top refrigerator is hot
FRIDGE COILS or door walls SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly but shut off with each defrost cycle.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
the reason the outer side of the door seal area is getting hot is the compressor is over heating, probably the condenser fan motor to your compressor is bad.
It should be a little warm but not hot. they don't use heaters anymore ( some older models still use heaters) around the doors, instead they use the condenser coils to remove condensation and moister, you might want to check your condenser coils on the bottom or back of fridge to see if they need cleaning
If the condenser coils/condenser fan are all plugged up they need cleaning and/or the condenser may fail or has failed..
The ones that use an electric heater will have an "energy saver" switch that will turn it off.: God is the reason I give you free advice so God is good!
Mar 27, 2016 | Amana Refrigerators
Serial # 20245743CD
the compressor is supposed to cycle as it is controlled by a thermostat
if the cycle times are too short then check the following
door seals in good condition --cracked or broken seals let the cold air out
thermostat setting too cold -- doesn't allow for a long period to warm up
door being opened too often motor stops then has to restart from the door open
problem thermostat
Jan 31, 2016 | Refrigerators
Old whirlpool freezer door left slightly ajar.light on inside.door won't seal. Rubber on door warm.
May 03, 2015 | Whirlpool Refrigerators
Compressor not running, water light flashes about two flashes per second.
Broken or bad connection under freezer door hinge. Wiring going to dispenser board. Im pretty sure its might be wet as well. find that connector under freezer door hinge. Let me know.
Mar 27, 2015 | Hotpoint Refrigerators
Ge profile 26 pfss6pkx Light comes on but won't get cold, no fan running
It doesn't cool
  1. Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
  1. Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
  1. Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
  1. Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
  1. Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective. Refrigerator Repair Help Troubleshooting and Parts
Aug 15, 2014 | GE Profile PFSS6SMXSS 26 French Door...
Icebox not cold
Hello - From what you have described it sounds like you might be experiencing some form of sealed system issue or a bad door seal. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Try checking if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check the door from closing then replace the gasket. If any proves to be ineffective, you would need to contact your manufacturer and then a professional to move forward accurately.
Oct 27, 2012 | Frigidaire FRT18FS6C Top Freezer...
PLFU2067DS4
From what you have described it sounds like you might be experiencing some form of sealed system issue, faulty defrost timer or a bad door seal. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. Trying checking if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check the door from closing then replace the gasket. If any proves to be ineffective, you would need to contact your manufacturer and then a professional to move forward accurately.
Oct 15, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Unit not cooling down,compressor running,condenser fan running. suction line just cool,condenser line barely warm.
Check if evaporator fan is running. Is there any frost buildup on freezers evaporator cover? If so you have a defrost problem (bad heater, defrost thermostat, thermister, defrost timer or circuit board ). If no frost and the freezer is warm then you most likely have a sealed system problem(leak, restriction, bad compressor) which is costly to repair.
Oct 19, 2010 | GE Â 17.9 Cu. Ft. Top-Freezer...
Model# 596.58642891 freezer side thawed first and now the fridge side is warm. The fan is running constant and adjusting the temp controls has no effect. The doors are sealing and the coils and fan are...
I humbly disagree with Sea Breeze. We know the thermostat (cold control) is working because the fans are running and the compressor is hot to the touch. So we're getting power to the compressor. Now, only TWO things will keep the compressor from firing up when it has power supplied to it.
1.) A failed Starter. (that box connected to the left side of the compressor.)
2.) A failed compressor.
Then there are two things that'll take out the starter.
1.) Just a mechanical failure within the starter (blown ceramic disk). Note ---> You can normally tell if a starter is bad just by taking it off the compressor and shaking it. If it sounds like it has pebbles in it... it's bad. If it's solid, it's probably good.
2.) If the compressor locks up or fails, the starter is not far behind.
This Kenmore is made by Frigidaire. My experience with these is that 90% of the time, the compressor has locked up. You said you had access to the compressor... if it's made by Tecumseh (you'll see a blue Indian head logo on the sticker) I can almost guarantee it's failed. (Frigidaire is now putting Embraco compressors in their machines because Tecumseh was such a terrible one.)
All that to say this... you may decide that you want to replace the starter (if it's bad/rattling). If you do, go here and look at parts # 211 & 251 on the diagram... you'll need these. So, all-in-all, it'd cost around $20 plus shipping to replace the starter. If the new starter works? Great! You fell within the 10%... (almost like winning the lottery!) If the starter doesn't work, all you're out is the $20.
Good luck,
SG
Mar 28, 2009 | Kenmore Refrigerators
Kenmore 57029 Side by Side Refrigerator Logo
48 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
