Question about Kitchen Ranges
Hot surface indicator light won't turn off - Kitchen Ranges
  • 3 more comments
  • ge range May 25, 2008
    Hot surface light won't turn off. No burners are on and none are hot. Is there a short or something?
  • rdg51 Jan 31, 2009
    same problem each burner has its own light how do yoy rplace sensor?
  • tmaddern Mar 10, 2009
    Yup, hot surface indicator light will not turn off. It's not the end of the world if it burns out, but I'm wondering if more problems might arise because of it?
  • Anonymous Mar 29, 2009
    I have a single light unit. I have removed all elements and the light still is on. Should it go out when the defective element is removed?
  • Walsh71 May 12, 2009
    My Hot surface indicator lights will not go off either. The burner still works, so I will just not worry I guess.
  • 413 Answers
The element contains a sensor to detect when the element is hot, these sensors fail. The element will have to be replaced. If there is only one light to indicate hot surface, you will have to determine which element has failed.
Posted on May 29, 2008
My model #: JS968SOF5SS. bottom rigth, surface ligth will not go out
Posted on Jan 01, 2009
    Genius:
  • 1,073 Answers
What is the model number of the range
Posted on May 09, 2008
5 Suggested Answers
jazzyboy11
  • 728 Answers
SOURCE: The hot surface indicator light remains ON all the time.
Your hot surface indicator light might have a short that causes it to stay on all of the time. If you can, try unplugging it for a little while and plugging it back up. If the light is still on, you have a short. You can still use the stove, but the light staying on will not be any help to you.
Posted on Oct 22, 2008
  • 29 Answers
SOURCE: Hot surface indicator
The component that controls the hot surface light is part of the element. If there is a light for each element you just replace that element. If there's one for the whole surface or each side you'll have to figure out which element is causing the problem.
Posted on Nov 14, 2007
  • 49 Answers
SOURCE: cooktop light stays on when cool
no your not doing anything wrong. the unit has a fault. you should call your nearest warrenty agent
Posted on Mar 08, 2008
MNTECH
  • 1543 Answers
SOURCE: GE EVOLUTION Glass top. The hot surface(Glass top)
Individual burners, located directly under the cooktop glass, contain a temp sensor which lights up the hot surface lamp when they sense a hot condition. If the light stays on after all burners are cool, one of the sensors has shorted out. The sensors are an integral part of the burner, so the offending burner must be replaced to solve your constant on hot light.
Posted on Jul 01, 2009
Hot surface indicator light stay on?
One of your surface elements is bad (the hot-element switch that is part of the element is stuck on). If each element has its own hot-light, then you know which element is bad; but if you have just 1 hot-surface indicator, your problem is figuring out which element is bad. That takes an electronic technician with patience and an ohmmeter.
Sep 24, 2014 | Whirlpool RF378LXKS Electric Kitchen Range
The surface light on my mothers stove stays on and all burners are off and cold any ideas why
Here is a tip that I wrote about why the hot surface indicator light will not go out...
Oven Hot Surface Indicator Light stays on
heatman101
Jan 18, 2011 | Maytag Cooktops
Why the hot surface indicator light always on when I turn off heat.
the hot surface indicator should go off when th temp of the unit has coled off enough to be touched.if it does not turn off then there is a more than likely a shorted wire.
Nov 28, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Hot surface light will not go out
heatman101
Sep 02, 2010 | Maytag Kitchen Ranges
Hot surface indicator light stays on. the knobs
signs of a faulty hotplate sensor especially if the surface is cold
Mar 21, 2010 | Whirlpool Kitchen Ranges
I have a new ge range. When I turn on the left
mvek,
If you could see through the glass, you'd see "temperature sensors" located near the elements. They're very sensitive little guys, and rightly so! Their job is to detect temps and energize the warning light on the cooktop so users won't get burned.
To answer your question... It appears that there is an issue with the front left sensor (and possibly the right as well). The temp warning lamps should NEVER go off immediately. Please call for warranty repair (1-800-GE-CARES). This is an unsafe condition for you and your Family. The warning indicators are there for a reason and should indicate high temp's as long as high temp's are present.
SG
Apr 11, 2009 | GE Kitchen Ranges
Oct 22, 2008 | Frigidaire FEF366EC 30" Freestanding...
GE Spectra JBP30B0B4WH surface unit light stays on
If it's the light that indicated the element is on, replace the switch. If it's the light that indicated the element is hot, replace the element.
Jun 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
Cooktop light stays on when cool
Mar 08, 2008 | Kenmore 95002 / 95004 Electric Kitchen...
Surface unit indicator light is always on
Coffy, if you are talking about the hot surface indicator lights, they are controlled by the limiter on the burner itself. When the burner heats up the limiter closes and sends power to the light (hot surface). When the burner cools the limiter is supposed to open cutting power to the hot surface indicator light. They may be stuck closed. If you are talking about the lights on the back panel, that is controlled by the infinate switch itself. Catriver
Oct 09, 2007 | Kenmore 96012 / 96014 / 96019 Electric...
Kitchen Ranges Logo
2,214 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
