Question about HP Computers & Internet
HP a1640n shuts off monitor after xp progress screen is done
  • 808 Answers
Vga fault
Posted on Sep 01, 2010
Blue screen.wiped hard drive fresh install still get blue screen
You have bad hardware. Try by testing the RAM. One DIMM at time, one slot at time. This is not easy to identify, and hope it is not the CPU. gl
Feb 27, 2013 | HP Pavilion a1640n (RC663AA) PC Desktop
After the Windows XP progress bar is done, the monitor goes to a screensaver, its a black screen with a blue block moving around the screen, with some kind of chinese lettering. At this point I can't...
First,turn the power off on the screen. & unplug the screen from the computer.After it's disconnected turn it on. This is to see if this screen saver thing is the monitor or the pc doing it.
The Monitor, if working correctly will say "No Signal". ONLY.
You should be able to get to the menu here.
If the Screen saver thing is only present when connected to the PC then its not the monitor but more than likely a problem with Windows XP configuration.
Here is your user manual:
http://support.gateway.com/s/Manuals/Monitors/8511446.pdf
If you can set up your monitor now, do so. Make sure the language part of it is set to English settings.
Sep 14, 2010 | Gateway FPD1975W 19" LCD Monitor
Auto adjust in progress, want it removed
Your video card or monitor sounds like it might be malfunctioning. Have you tried another monitor? Does it show anything on the screen after turning on the computer? If it does then goes to "Auto Adjust" then try restarting and pressing F8 over and over until you get a menu. Then select VGA Mode. Change the screen resolution by right clicking on the desktop and clicking "Properties" then the "Settings" tab. Use the slider to lower the resolution and then restart.
Aug 03, 2010 | Microsoft Windows XP Professional
Bios Help? Motherboard? How to fix?
The most likely cause is your hard drive has stopped being detected for some reason. You would need to go into the CMOS setup utility and check and see if the drive is listed there. Usually there is a shortcut key you push like F1, F2, Del, F12 (it varies from computer to computer). Start trying these keys right after powering on the PC (within one or two seconds). The actual screens also vary from PC to PC, making it difficult to describe further clarification on what these will look like.
If you're comfortable with opening your PC you can check and make sure the power and data cables are securely connected.
Sometimes inexplicably the simple act of blowing all the dust and other crud out of a PC helps with this. If you haven't done that for a while...stranger things have happened.
If all else fails you may have to buy a new hard drive and re-install your OS. Before that I would recommend taking the PC to someone who can look at it in person and really determine the issue.
Jun 03, 2010 | HP Pavilion a1640n (RC663AA) PC Desktop
Auto adjustment in progress popping up and
Right click on your desktop, go to properties, and navigate to the settings tab. There, try to set the monitors resolution to the largest available. That should fix your problem. If it doesn't just try some other resolutions until ou find one that works. I hope this helps, Yannick.
Jun 09, 2009 | HP w1907 LCD Monitor
For 2nd int. hard drive ? SATA or IDE -HP Media Center a1640n
You can contact your vendor. Or at ebay
( http://computers-networking.shop.ebay.ph/Computers-Networking__W0QQ_sacatZ58058 )
copy an dpaste the link your Internet browser address bar
melnavz
Feb 23, 2009 | HP Pavilion a1640n (RC663AA) PC Desktop
Display Problem with Scenic P300 i845GV
it seems that you have a corrputed operating system. try 2 repair it by using the operating system installer and do a repair just follow the steps.
Jan 28, 2009 | Fujitsu Siemens SCENIC P300 PC Desktop
Dell E196FP TCo99 Monitor screen problems
The screen colour changing is apparently an auto test procedure on the monitor and was prompted by a fault with the monitor not automatically shutting down when the computer is shut down. The settings on the monitor have been adjusted to rectify this and the problem is now gone.
Apr 06, 2008 | Dell E196FP 19" LCD Monitor
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
