Question about Compaq Computers & Internet
My compaq computer keepd shutting down unexpectedly. It then has to be disconnected from the power source , reconnected and restarted. It does this after it has been on for a while or if it is on and not being used. Could it be that it is over heating?
    Brigadier General:
  • 10,406 Answers
Yes, overheating is the likely problem -- dust inside the laptop is a good (though unwanted) insulator.
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air, and give your computer a "blow-job" -- shooting through every possible vent and port on your laptop.
Also, check that the fan(s) "inside" the computer are working correctly, i.e., not seized-up.
Posted on Aug 31, 2010
Caps lock led not working
Sometimes electrical components needs to have all power sources removed and reintroduced to work properly. Try performing a hard reset first, if it doesn't work then try updating your BIOS. If neither works...It's pretty much dead and not worth fixing.
To Perform A Hard Reset
  • Shut down the computer by going to the Start menu and selecting shut down. (If you have no display, hold the power button down for 5 seconds)
  • Disconnect the AC Adapter from the notebook.
  • Remove the battery from the bottom of the notebook. There will be a switch/button to eject the battery.
  • Wait at least 1 minute with all power sources disconnected.
  • Re-insert the battery and reconnect the AC Adapter and then attempt to power on the computer.
May 22, 2011 | Computers & Internet
I dont remember power on password for hp nc4400
The power-on password prevents use of the computer until the password is entered. The
setup password prevents unauthorized changes to Computer Setup. To clear the
passwords, you must remove all power from the system board. If you do not know the
passwords, use the following procedure to clear the password:
1. Remove all battery packs.
2. Disconnect the AC power.
3. Remove the real-time clock battery.
4. Wait thirty minutes.
5. Reconnect the AC power. DO NOT INSTALL THE BATTERY!
6. Restart the computer. During Power-On Self Test (POST), a ? 162 System Options
not set? message appears.
7. Shut down the computer, then disconnect AC power again.
8. Replace the real-time clock battery.
9. Install the battery pack(s).
10. Reconnect the AC power.
11. Start the computer.
12.It should work....
Apr 08, 2011 | HP Compaq nc4400 Notebook
Unexpected shut down of my HP Compaq I was trying to close the windows I was working witt when all of a sudden without notice my laptop shuts down. I tried to restart it but it would not. I took off the...
Compaq's are famous for over-heating, if you didn't have a cooling pad under the laptop it may have burned up some components, or it could just need time for the components to cool.
Jan 07, 2011 | Computers & Internet
Mac cannot see 750GB maxtor 4
Did you disconnect the firewire drive before installing? You may need to update your firmware. Also, try these things:
1. Shut down and disconnect your firewire drive leaving nothing is connected to the firewire ports.
2. Restart, and use Disk Utility to repair permissions on your internal.
3. Shut down, and disconnect the AC power from the computer and your drive; also remove battery if laptop.
4. Let computer sit unpowered and disconnected for15 minutes.
5. Reconnect AC power to only the computer and reinsert battery.
6. Restart computer.
7. Verify that firewire ports are visible using System Profiler.
8. Reconnect your firewire drive, and refresh window in System Profiler to rescan the firewire bus, and confirm that drive is visible.
9. Repair disk and permissions on the firewire drive.
Dec 13, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
When i scan the image i get is black
  1. Shut the computer system off and then disconnect the scanner from the power source.
  2. Leave the scanner disconnected from the power source for at least one full minute.
  3. Reconnect the power and then restart the computer system.
  4. When the computer system has fully restarted, try scanning again.
Nov 03, 2009 | Mustek ScanExpress A3 USB 1200 Pro Scanner
Gateway monitor fpd2185w goes to sleep and then shuts off
I suggest to mess around with the monitor buttons and see if you can disable it from sleeping from there. If not then try enabling it to sleep on your computer settings. A good restart after any changes is always helpful.
Jul 07, 2009 | Gateway FPD2185W 21 in. LCD Television
E500 won't shut down
It is probably not shutting down because there is a program running that will not shut down. Unnstall programs you no longer use and do a virus scan, often the programs that refuse to shut down are malicious. Holding down the power button for 5 seconds should shut down the computer (it signals the motherboard to power down). As for the black screen, not enough detail for me to say.
Jan 02, 2009 | Compaq Armada E500 Notebook
I have problem of powe on password with my laptop compaq armada m700. how i can by pass my password power on password?
Dear
hello, how are you?
i am surfing internet and it solved my problem for free
i have act as it tell me in its instructions step by step
now my computer is working for free cause i can not surf money i have not enough on your demand i can provide you this link that have help me
Thank you
Dec 01, 2008 | Computers & Internet
Green light flashing after shutting down computer to relocate office.
if its by the power button the led just indicates power after u have removed its source and reconnected it........this is normal nothing to worry about.
Sep 13, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
47 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
