Question about AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen
I am using an AO Smith motor on a Hayward pump to run my pond. It is about 4 years old now. Most recently, in the hot weather (90+F in the Northeast) the pump just shut off as I was watching the waterfalls. I cehcked the electirc supply and found no problems. I left it unplugged to go out, and 4 hours later when I came home I plugged it in and it restarted. That was 2 days ago. Today I was told that it stopped again. It is still plugged in, and I will see if it restarted itself when I get home from work. Is there some type of overheat or overload which shuts it off. Will this restart the motor itself? Does this mean that the motor is going? I noted the motor was in full sun the first time it stopped, and it was pretty hot to the touch, but no hotter than my pool motor which was also running at the time. Thanks, Mike.
    Problem Solver:
  • 10 Answers
Pump is protected with a thermo switch made inside the motor to shut it off if it gets to hot check for oil ports at the bearings if it dose not have them maybe try adding a ball valve and turning down the flow some to create slower flow and higher pressure
Posted on Sep 01, 2010
I have a Hayward in ground pool pump with an AO Smith model# k48m2n111. It's 10 years old now but yesterday it stopped working and just whines real loud when i start it . Could it be a quick fix? Is it...
Hayward pumps are poor quality. You're lucky to get ten years. In 4 years I've needed the motor replaced twice and the pump repaired. The motor is starting to whine again. Just a matter of time before it fails. Do yourself a favor and stay away from Hayward.
Oct 06, 2014 | Pool & Spa
New ao smith pool pump motor keeps tripping out under load
check the breaker might be weak possibly from previous pump motor also if it was hooked up incorrectly at first might have done damage to motor windings
Apr 17, 2014 | AO Smith Pool Pump Motor Hayward Swimming...
Why is new ao smith pump getting hot
Most motors are warm to hot when running.
Is it getting so hot that the thermal overload is turning it off? If so the pump should restart once it cools down.
If this is a new motor on an old pump (replacement) it is likely to be:
1.) Incorrect or loose wire connections.
2.) Low voltage supply (frequently caused by undersized wire).
3.) Lack of fresh air supply to motor due to clogged vents.
4.) Incorrect amperage of replacement motor.
Jul 25, 2012 | AO Smith Pool Pump Motor Hayward Swimming...
I have a A.O. Smith pool pump (Model #C48L2PA105C5 & Serial #04609FM) and there is no suction at all
hayward ?? good chance the impeller is broke or it could be plugged with trash make sure you pump basket has no cracks , see picture on how 2 remove your pump .find your local pool pump motor repair guy and ask him how 2 take better care of your pump.. he can save you thousands of dollhair$ over the years .. jay pump guy longwood Florida9_30_2011_7_43_54_pm.gif
Sep 23, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
A.O. Smith c48k2pa105c5 pool pump motor was running fine for 3 weeks. The other day it shut off cause of the thermal switch. Well now when I turn it on it works fien for a couple minutes then it shuts off...
If you mean that this motor is only 3 weeks old, and this is happening, return the motor.
If its an old motor and this is happening, purchase a new one. Even if you had a technician come out to look at the motor, chances are it would cost more than the motor itself.
Largest causes of thermal overload are.
-incorrect wiring
-wiring to wrong voltage
-incorrect wiring size
-bad motor windings
-bad rear end bearings.
Apr 27, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
May 02, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Hayward Swimming PoPump is 4 years old - when I opened pool, pump
it you've inspected all the wiring for possible shorts, the most likely problem is that the motor has developed a short in the windings. You may have to replace the motor. First check for loose connections and make sure the wiring going to the pump is good. Also, check the start capacitor, should be under the hump or under the end cover on the motor. If it's bloated or leaking, it's bad.
Most likely the winding have a direct short.
Apr 05, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor  / Cen Logo
161 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
