Question about Ogio Golf Stand Bag
I have an Ogio Grom golf stan bag. One of the plastic hinges for one leg snapped off. How do I replace it or get it fixed.
How do I fix the stand on this golf bag?
I would definitely take the bag to a pro shop or specialty shop if I wanted to do a repair. A pro will know whether the bag would be worth repairing or not
Jan 11, 2015 | Golf
What is a Luggable Loo? Are they any good for camping?
A LuggableLoo is a sturdy plastic bucket that comes with a snap-on toilet seat and hingedlid. They are easy to transport around but if you are camping and hiking youmight want to look at portable toilets that collapse flat and can be stored inyour bag.
Aug 02, 2012 | Camping, Backpacking & Hiking
Change doors from left to right
Depending on the brand, this "may" be possible. Look for a mounting bracket area on the side you want to change to. Is so, have someone help you, two person job!
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | Refrigerators
My Oreck XL upright vacuum is blowing air instead of sucking air.
I've solved the problem! I had exactly the same problem, with dust being sucked up properly and then some blown out where the bag connects. The XL machine has a hinged plastic dock for the bag, which slides in the dock and you then close the hinge, there's a slight click and the velcro keeps it shut. The problem is that the plastic dock is not behind the ridge, but is in front. So when you start up the bag connection is pushed forward. So:
Undo zipper, open dock hinge and push it back squeezing the panel on the cloth bag. One side will go behind the ridge and you need to push it firmly, opening it a bit if you can. It will go behind that ridge all the way round. You'll see now that the dock is firmly in place, and can be hinged closed as you did before. But instead of the joint being loose, the bag is now tight.
Mine now works fine... thanks to fixya for encouraging me to fix it! I was close to binning the machine. But it sucks well, and I don't go for bagless... like my dirt packaged for disposal. And if you're a farmer, try farmideas.co.uk !!!!
Nov 25, 2010 | Oreck XL Deluxe U3700 Bagged Upright...
How do i get the battery out of my 2000 golf. It has this circuit thing on top of the battery that icant loosen. Cheers. ant
It has to come off. It actually snaps in place. The unfortunate thing is with heat in the engine compartment the plastic tends to remold itself. So you may break acouple snaps, but its only a minor thing. It should hinge towards the firewall.
Jan 14, 2010 | 2001 Volkswagen Golf
Ogio Stand Bag - Broken "H" Clip
Mine slide up and down the legs. Not a good design since the weight broke 1 of them. I have not found a replacement part for this yet.
Dec 08, 2009 | Ogio Golf Stand Bag
Plastic tube inside fabric bag broke cleanly at the base.
It can be fixed by yourself, if you are some-what handy. The part is called snap fill tube and the part number is 1900399 your local vac repair shop should be aware of this number part sell for about $9.00 to $14.00 hope that helps.
Oct 31, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How to choose the right bag for me?
first, make sure your board fits in the bag. Than, think if you need or want it to fit something else. After that. Choose the type by price and needs. Padded or not, with wheels or not etc…
Dec 01, 2008 | Ogio Agent Snowboard Bag
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2008 | Microwave Ovens
Ogio Golf Stand Bag Logo
71 people viewed this question
Top Ogio Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you an Ogio Winter Sport Expert? Answer questions, earn points and help others
