Question about SanDisk Sansa e260 MP3 Player
Why doesn't my expansion card show on my PC? - SanDisk Sansa e260 MP3 Player
  • kakima Sep 01, 2010
    What size memory card? If it's larger than 2GB then it won't work in the e260.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
Having received no response to my query in over a month, I assume the problem was in trying to use a microSDHC card in a microSD device.
Posted on Oct 08, 2010
Memory card not working
try to put in card reader and connect to PC,if PC recognize your memory card try to take backup of your file in card using icare card pro software..then format the memory card... even PC also not recognize your memory card is dead...
May 14, 2012 | BenQ-Siemens Benq E71 Mobile Phone Cell...
Where is the wifi card located optiplex 160 l?
See http://support.euro.dell.com/support/edocs/systems/op160l/en/ug/smtabout.htm#1189371 which is the Dell Optiplex 160L User Guide and shows the internal layout of this computer with instructions for removing expansion cards.
Dec 22, 2011 | Dell OptiPlex 160L (160LMIN) PC Desktop
Hi, Is Asus ATI Radeon HD6450 Silence 1GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card capable for my Compaq HP Presario SR2020NX? -thanks a lot.
You mean will the Asus ATI Radeon HD6450 with 1GB of graphics memory, work in a Compaq Presario SR2020NX Desktop PC?
Yes.
The Compaq Presario SR2020NX Desktop PC has a PCI-Express x16 expansion slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757470&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3245048
{Motherboard illustration and photo are towards the bottom of the page}
Look at the specifications.
Scroll down to the heading - Expansion slots.
Three PCI. (PCI expansion slots)
One PCI Express x16 graphics.
NOTE*
Looking at the motherboard illustration, it is Wrong.
Shows - PCIEX1 (PCI E X1)
According to the specifications it is a PCIEX16 expansion slot. (PCI-E x16)
A PCI-Express x1 slot has 36 contact pins. 18 on each side.
In comparison a PCI slot {White} has 124 contact pins. 62 on each side.
Looking at the photo of the supposed PCI-E x1 slot they show, the black PCI-Ex1 slot is longer than the white PCI slots.
It is a PCI-Express x16 slot with 164 pins. 82 on each side.
The Asus ATI Radeon HD6450 uses a PCI-Express x16 expansion slot.
So you know the graphics card will fit. Low-profile to boot.
Power requirement:
The Compaq Presario SR2020NX desktop computer comes with a 300 Watt power supply.
(Although in actuality it's more like 70 percent of the maximum rated wattage. 210 Watts)
Enough power for the computer, and the graphics card.
ATI graphics cards do not use as much power as a comparable Nvidia graphics card.
Concerned that the Asus graphics card uses DDR3 graphics ram memory, and the Presario SR2020NX uses DDR2 Sdram ram memory?
Don't be. The graphics cards graphics memory runs independent of the computer's ram memory.
Information on PCI-Express,
http://en.wikipedia.org/wiki/PCI-Express
For additional questions please post in a Comment.
(Top right of your page, blue Comment)
Regards,
joecoolvette
Sep 15, 2011 | HP Compaq Presario SR2020NX PC Desktop
Cd and hdd both run on startup... monitor says it is in standby and doesn't display?
  1. Ensure the display is configured to use the input connected (Analog for VGA, Digital for DVI etc. If you are using some sort of an adapter to connect the display, then that could also cause an issue. If possible, try a connection that has no adapter and/or try monitor on another system to ensure it is functional.
  2. Re-seat the video card. Often this can be an issue where just re-seating the card firmly will ensure you have proper connections. If using integrated display then there isn't a lot to do for that. Also ensure that if the system has an expansion graphics adapter, you are not connected to an on-board port as these are normally disabled by an expansion adapter. If you do have both video expansion and on board video, also try removing the expansion adapter an use just the on-board one.
Jul 11, 2011 | ASUS P5NSLI (0610839134670) Motherboard
It won't start it is black
Dell systems have built in no post diagnostics, you can check them here:
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
if the system is completing post, but not showing any display, then you have either a Video Card issue or a monitor issue. Things to check:
  1. Ensure the monitor has the proper input selected for the cable that is connected (VGA, DVI, DisplayPort etc)
  2. Reseat cable connections
  3. If system was recently moved, make sure cable connected to correct Video Card Connection (Some systems have 2, and if an expansion card is inserted, generally on-board video is disabled.)
  4. If still no video and system has both expansion and onboard video, remove the expansion card, try the on-board.
  5. If still no go, try a different monitor
  6. if all the above fails, replace video card
Mar 19, 2010 | Dell Dimension 4600 PC Desktop
It does not recognize an 8gb sd card in storage expansion.
Your netbook should read SDHC(over 2 GB capacity) memory cards. The problem might be either the card slot driver, Which you should download if a newer one is available. Or in case you format the SD as DOS then it will only have around 2GB of space, You should format it as DOS32 or NTFS so you get the full capacity for the SD card. Some pirated rather cheaper memory cards have a lower actual capacity. With some compression technique the capacity presented is higher than it actually is. If you format it then it will show the real capacity. hope that is not the case!
Good Luck!
Nov 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
I need to get my sound card back to working
  1. Determine if the sound card is integrated or an expansion card (Usually a Soundblaster) If using an expansion card, the integrated audio must be disabled in the BIOS F2 at boot) If no expansion card, then in integrated audio must be enabled.
  2. Once the sound card has been determined, make sure that the master volume control is not MUTED and the WAVE audio is not MUTED
  3. Download and install the latest sound driver from support.dell.com
Oct 03, 2009 | Dell Dimension 3100 PC Desktop
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
EXPANSION PACK WIRELESS PC CARD
You need to install the drivers for it.
Xracer
Oct 31, 2007 | Compaq iPAQ H3955 Pocket PC
Not recognize the PC Card Expansion Jacket after a soft reset
Make sure the P300 has completed the boot process before attaching the PC Card Expansion Jacket. This will ensure proper detection.
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
SanDisk Sansa e260 MP3 Player Logo
26 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
