Question about Heavy Duty Arrow T50 Staple Gun
The wrong sized staples apparently have been inserted into my Arrow T-50 How can I retriever them
5 Suggested Answers
brainyass
  • 242 Answers
SOURCE: Stanley TR70 Manual Stapler won't accept Arrow 1/4" staples
It sounds like you have a light duty stapler and are trying to use heavy duty staples. 1/4" refers to the length of the legs not the thickness of the actual staple. You probably just need light duty staples.
Posted on Oct 23, 2008
  • 240 Answers
SOURCE: how to remove jammed staples in staple gun?
Pinch the clip located on the end of the Magazine Unit Pull out the Magazine Unit Remove jammed staples from the channel. You may need to use long-nosed pliers . Make certain that you are using correct size staples. Close Magazine Unit.
Posted on Jun 16, 2009
efs_perpends
  • 1996 Answers
SOURCE: I have a staple stuck in my Arrow model #ETN-50
Unplug it. If you can see the driver jammed against the staple, take a screwdriver end and try to push the driver back in and the staple should be released. If you can't get the driver to go in and release the staple, you'll have to disassemble it to clear the jam, If you need help with that, see the instructions for the current model here, page three, diagram 3, cleaning the magazine.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 18, 2009
Testimonial: "Thanks for your help! Much appreciated!"
  • 1335 Answers
SOURCE: I have an Arrow T-50 which is missing the staple
You need the staple loader to keep the tension on the staples. The part is usually not sold separately. Your only chance is to find a used T-50 and cannibalize the part. You can get a new T-50 online for $25.
Posted on Dec 09, 2009
Loading staples into a Stanley sharpshooter staplegun
There are 4 staplers in the Stanley SharpShooter family. You drop the staples on top of the "slide out loader," then slide it into the gun. See models and staple sizes below:
TR150HL Stanley Sharpshooter
  • Stanley SharpShooter TRA700 series or Arrow T-50 heavy duty staples
TR150 SharpShooter
PHT150C SharpShooter Heavy Duty Hammer Tracker
  • TRA700 series or Arrow T-50 heavy duty staples (1/4"-3/8")
TR250 SharpShooter Plus Heavy Duty Staple/Brad Nail Gun
  • Stanley SharpShooter TRA700 series or Arrow T-50 heavy duty staples and 1/2", 9/16" and 5/8" Brads
More information on the Stanley SharpShooter and a quick loading demo can be found here: http://www.expotv.com/videos/reviews/12/134/StanleyTR150HLSharpShooterHeavyDuty/185661
Sep 11, 2012 | Stanley Proto Stanley TR150HL SharpShooter...
I cannot insert the retainer spring into the stapler 2025, with or without staples. What am I doing wrong? Arrow fastener model T2025. I played with the front piece for different sizes of staples; since...
make sure the rod inside the spring is not bent. the slightest bend can cause the retainer or push up loader to act goofy. Also make sure the u shaped(a square U) that makes contact with the staples isn't warped or out of shape. and if staple gun was ever dropped the whole track it slides down could be pinching down too much creating resistance. if so, pry open gently wherever you see that it might be getting tighter. If a visual inspection is not obvious try slowing sliding the spring loader into staple gun's staple track and once resistance is felt start to gently work open with a pair of needle nose pliers, insert closed the use two hands pull pliers open to spread the track apart. . Or any method you find easier that would create the same effect. be inventive and use commonsense always. before u know it you will be MacGyver. LOL Hope this helps, and good luck.
May 09, 2011 | Arrow T25 Staple Gun
What size staples for a Cobra heavy Duty stapler?
Take it to home depot or lowes, they will sell you the right ones.
Feb 22, 2011 | Arrow Fastener 8000 Cobra Heavy-Duty...
Just purchased t27 arrow staple gun but can't load staples. I have removed spring loader from rear and unsuccessfully trying to load staples from rear. Wrong method? Wrong size staples?
That stapler takes a jt21 staple. some fill from the bottom when the plunger is in the drawn back position and some fill from the rear with plunger removed. If the plunger is attached, then it fills from the bottom. Hope this helps:)
Aug 24, 2010 | Arrow Fastener T27 Light Duty Household...
Staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
May 26, 2010 | Arrow T50P ARROW STAPLE GUN
I have an Arrow T-50 which is missing the staple pusher needed to reload. Can it be reloaded without the staple? If not, where can I get that part? Thanks!
Dec 09, 2009 | Arrow T50P ARROW STAPLE GUN
What size staples does the B&G Powershot staple gun use? I bought a refill pack 3/8" & 5/16" long. They fit but the shank when pulled out and loaded with staples won't close. Thank you. Julia Carr
Hi Julia,
You have the right size staples. The problem is the length of the refills. Some staplers can't accommodate a full length clip.
Break the staple refill clip in half, then insert it. The shank will be able to close and latch that way.
Best regards
Mike
Dec 06, 2009 | Black & Decker 5700 Powershot Forward...
Can't load staples
Fire the stapler with the load chamber open and down, see if anything falls out. Point it in different positions and fire it, just make sure it cannot fire anything at you.
Apr 18, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
Is the Ace Hardware #22084 Staple Gun the same as Arrow T-50 ?
Found a friend who had an Arrow T-50 stapler and compared staple sizes - not the same.
Feb 17, 2009 | Arrow T50P ARROW STAPLE GUN
Heavy Duty Arrow T50  Staple Gun Logo
54 people viewed this question
Top Heavy Duty Tools & Hardware - Others Experts
Joseph Hoffmann
Andrew Taylor
Andrew Taylor
Are you a Heavy Duty Tool and Hardware - Other Expert? Answer questions, earn points and help others
