Question about Acer AL1916W 19" LCD Monitor
I have an Acer AL1916W monitor which powers up and shows the Acer logo and then cuts off. It seems to do this when on for long periods.
  • 11,361 Answers
Please inspect the DC filter caps in the power supply, see failed ACER due to bad caps first.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Aug 31, 2010
I have an Acer AL1916W monitor with a M1100 desktop and my monitor is acting up. It would stay on for about twenty minutes then will cut off and on every 3 seconds. The Acer logo will show then the desktop...
Hi this seems to be a common problem with this type of monitor i found the best solution apart from throwing it out the window as it drives you crazy is turn it off from the main switch and back on i have tried so many things on the computer and still no good but try the power thing and see how you go it has worked on a few i have dealt with and also just try the switch on the monitor if that dont work try connecting the monitor to your laptop as an external monitor or another computer and see if it does the same on that computer then you know it is for sure your monitor and one more thing is to try another type of connection as you should have a couple or few ways of connecting hope it helps
Jul 06, 2011 | Acer AL1916W 19" LCD Monitor
I got an Acer AL1916W 19" when I turn it on, It
Inspect the caps first.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 16, 2010 | Acer AL1916W 19" LCD Monitor
Cuando enciendo el monitor tarda un minuto en restablecerse,
Would you please give information as regards the problem posted in English? Giving me this information in English will guide me to suggest a solution to the problem.
Take care.
Jul 16, 2010 | Acer AL1916W 19" LCD Monitor
Acer AL1916W about 2 years old. Turned on this
Bad caps in the power supply, common problems with 2-year old monitors, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | Acer AL1916W 19" LCD Monitor
Acer AL1916W no sign of life.
If Power LED lits up and then turns to orange (standby mode) but no display, pls check SMT fuse (F200), replace the caps and replace 40T03GP power mosfet N-channel enhancement mode. Good luck
Apr 26, 2009 | Acer AL1916W 19" LCD Monitor
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Acer al1916 monitor goes black
You probably have a few dodgy caps on the power board inside. It's an easy fix if you are confident around electronics.
If not, pop it off to your local TV repair shop and have it taken care of now before it gets expensive with a complete failure.
Hope it helps =)
Apr 09, 2008 | Acer AL1916W 19" LCD Monitor
Moniter turns on for 2 seconds turns off
hi guys, first run the system in safe mode, and with vga mode, see if it is the same problem ?? let me know
Dec 30, 2007 | Acer AL1916W 19" LCD Monitor
Black outs
May be your IP board is going out. Replace IP board.
Aug 25, 2007 | Acer AL1916W 19" LCD Monitor
Problem with the acer al1916w
Sounds like the backlight or inverter might need replaced. It's pretty common on LCD monitors. It's best to call a local repair shop to do that unless you know what you're doing.
Jul 31, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
138 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
