Question about GE Kitchen Ranges
How can I adjust the burner flame lower on a GE gas range?
CrazyLarry
  • 173 Answers
SOURCE: Gas range top burners hard to light...
Gas burners use propane or natural gas...refer to the manual to see what it takes and sometimes you have a switch to select the proper gas. you can call a gas man to confirm this and correctly tell you whats going on. but he will propably make a trip. good luck
Posted on Aug 31, 2007
SOURCE: gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Posted on Feb 19, 2008
  • 1073 Answers
SOURCE: Propane gas flame too high
if it set up for propane or natural gas need to make sure if for propane you need to change the orifice in the cook top, it is shipped for natural gas call the store and they can order the kit
Posted on May 06, 2008
burzerko
  • 254 Answers
SOURCE: new gas range converted to propane
I think it sounds like one of two problems either the wrong orifaces were installed in the gas valves for the conversion or the pressure on the output side of the gas valve was not set correctly.
Posted on Jun 22, 2008
docjohn174
  • 943 Answers
SOURCE: GE range stove #317B6641P001
Hi thanks for the question. the problem you are having is with the igniter. it does not get hot enough to work at 100 % . replace the igniter. thanks te appliance doc
Posted on Oct 06, 2008
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
I have a GE Kitchen range XL44, stove top burners work fine, but oven won't light??? HELP please
Unplug the range.
Remove the oven racks.
remove the oven base pan.
remove the flame spreader pan.
remove the glow bar ignitor on the left hand side of the gas burner and replace it with a good ignitor.
Jan 25, 2010 | GE Kitchen Ranges
When i turn my oven on, the flames come up into
If the burner pressure is adjustable(some are not) you can use a small adjustable wrench to turn the gas orfice to lower the gas pressure. The orfice is usually located in the broiler/storage comaprtment at the very bottom of the range. It is the brass piece that goes into the burner venturri and is where the gas comes out. If your turn it clockwise it will decrease pressure & counter clockwise will increase pressure. If the flames are coming into the burner compartment that is quite an increase in pressure!!! Make sure the the range did not have the gas regulator removed. If it was then that would explain why the oven burner pressure is so high.
Nov 11, 2009 | Whirlpool GS460 Gas Kitchen Range
Ge propane kitchen range changed to natural gas.can't get the ove
Hi, Did you flip the cap on top of the regulator? As far as adjusting the bake/broil orfices, all you will nee to do is turn them 2 full turns counter clockwise. Start the oven and watch the flame. It should have blue tips as much as possible.
You might have to raise or lower the orfice adjustment as needed.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
JGBP89SEMSS BURNER HEIGHT
Sounds right long as you did the conversion okay did you change the spring in the reg ? lp gas does burn lower than nat gas smaller blue flame . you could see if the aeration can be adjusted to the burners You could also check the pressure at the burners lp working pressure is 14in wg .
You could check the reg outside . That's all I got .
Mar 17, 2017 | GE JGBP88SEKSS Gas Kitchen Range
GE XL44 Oven - On/Off heating of bottom burner.
Mag...not sure here. Is there a particular reason that you're suspecting a problem? Does the unit heat much slower than before? Does it bake properly? You may be looking for problems that aren't.
Dec 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Simmer is to hot
I am hesitant about answering your question because if the flame is adjusted incorrectly it could be dangerous.
Remove the knob and look inside the stem of the gas valve. You will see a very small adjustment screw. This is where you adjust the flame for the burner.
What I usually do is light the burner and turn it to the lowest setting. Hold the stem in this position and turn the screw. They are usuall kind of stiff to turn.
You want to adjust the flame so that it just comes to the top of the burner cap at the low setting.
This is the important part!!!
When you have got the flame adjusted, put the knob on and turn the flame to high. Quickly turn it from high to low, if the flame goes out, adjust it higher. Repeat this test until you can turn it from high to low quickly and it stay lit.
Also important to remember. When turning the screw, a little turn goes a long way.
Post back if you have any questions.
Oct 31, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Aug 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Kitchen Ranges Logo
159 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
