Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Greetings, I have a problem with a ViewSonic VA720 model turns well but after 2 seconds you will image
  • 11,361 Answers
Look for bad DC filter caps first as hsown here:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Aug 31, 2010
The power light stays on but there is no image at
More likeley to have bad caps in the power supply, that is the first place to look, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
VA 730 may have the same chassis as VA720. If the cpas are bad, you should replace them with PANASONIC FM or FC series caps from DIGIKEY. Your college should have good electronics test equipment to repair these monitors.
Feb 24, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
What voltage do i need for my ViewSonic VA720
Monitors and PCs (amongst other things) use a fairly standard power cable. You should not need to worry about the specifics as there is generally no transformer needed for a monitor.
Oct 26, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Have just hooked up my Viewsonic VA720 moniter as the main moniter to a new laptop that I have. The laptop is an ACER Travelmate 6293 running windows XP. When I come to start up my computer each morning...
You most likely have a capacitor that has changed value. When a capacitor goes bad it will work after it heats up. Sometimes a bad cap will have a bulging top or show signs of leakage. Sometimes can only be checked with a meter.
Oct 04, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic VA720 monitor has small blinking light, won't turn on
When turning on the computer we get analog auto save, and don't get as far as the desktop, how can I solve this problem
Debi
Viewsonc VA720 Flickers On and Off Continuously
Take a look at the capacitors and see if you have any weak one. An obvious way to spot one would be one bubbled up on top. A bad cap won't always be bubbled up. The monitor probably can operate until the voltage drops under 8 volts. Also possible if power supply check out good would be a weak backlight inverter.
Apr 05, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic VA720
The VA720 I have has 4 screws from the back: 1 at each bottom corner and 2 in the middle lower at the base. Remove screws and carefully pry the front and back halves apart. They snap together. Usually working the bottom apart first is easiest.
Oct 08, 2006 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
61 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
