Question about Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
I have a 9D902-1607-E1 Briggs and Stratton edger that wont stay running because the throttle springs have been removed. I need to know where the two springs go on the throttle and governer
4 Suggested Answers
  • 3 Answers
SOURCE: Briggs & Stratton Engine Won't Stay Running
Make sure none of the hoses are cracked or loose fitting
Posted on Aug 03, 2008
SOURCE: Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Posted on Oct 25, 2009
SOURCE: Purchased a Troy Bilt Edger model# 258-554E011
I purchased a 5 HP Briggs & Stratton outboard motor which did not have a operators manual. Is there a free site that I can download this manual from?
Posted on Sep 16, 2011
I have a Briggs & Stratton 10 HP engine, model 220707 that I could use some help with the governor spring on?.
Should see a bracket with holes in it .and a small throttle bracket that has a hook shape the spring locks on to it.
May 20, 2014 | Briggs & Stratton Briggs Stratton Intek V...
I have a 18HP B&S Vangaurd Vertical shaft on a scag walkbehind motor runs good untill I engage the blades then it seems to draw down to about half throttle until I disengage the blades then the motor...
Check the govenor spring to see that it is not stretched out or popped off...there should be a colored spring on the throttle plate where the throttle lever connects to...also, there are several holes in the plate where the spring attaches...these hole will set the sensitivity of the govenor...you may need to make it more sensitive to hold the engine speed high when engaging the blades
May 11, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
How does choke work on 20 horse briggs the throttle only has turtlespeed and rabbit no place marked choke
Many have auto chokes, which are set to close and open essentially with spring pressure. You can verify this by looking into the intake, ahead of the throttle plates. Other designs use a priming bulb to accomplish the same function.
Nov 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a 24HP V-Twin Briggs that i blew up. I found the parts i needed and rebuilt the beast. It starts and runs but i cant get it to throttle down. I split the case again and inspected the governor....
A big vavume leak and or the throttle blade doesn't close or it gone ( missing). the carb should close all the way ( you can't look thiugh it) with the linkage off you should be able to run it by hand with good results. if you can find out the correct way to put the springs on and just move things around or gat a look at one thats working right and you may see whats put together wrong on yours.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
3.5 Briggs with not run at full throttle
same problem, was told it was the jets, are your symptoms as follows
runs at low throttle, will only run at full throttle if fully choked
dies if choke is relieved
Apr 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engin runs wide open and will not idal
Us+ally the air cleaner has been put on backwards or the spring has been snagged or over tightened. the throttle spring. needs only slight tension to open the throttle++
Aug 29, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Have to choke to keep running
this is not hard to do here is what you need , 1 can of carb cleaner anykind will do , a 10 mm rench to remove the bowl 7/16 socket . now remove the carb take a good look where the spring is before you take the carb off it muct go back in the same hole , now that you have it off take the bowl off remove the float place to the side here is the fun part look in the carb you will see some small hole spray them this will clean all of the old gas out if you can let it set for about 10 min then do it again blow out with air if you have one nothing else to do but reinstall this works most of the time ...Good Luck..
Aug 16, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Need carburetor adjustment
I had a similar problem with my 23 hp briggs. While cleaning the carb I found that the great gas we get today had eaten the seal around one of the jets in the throttle body causing it to fall out. Replaced the jet and now runs like a champ. Hope this helps.
May 05, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766 Logo
196 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
