Question about Motorola Mobility Rival A455 Cell Phone
AMSS HASH MATCH FAIL appeared on my phone when I tried to update it how do I fix it
Give me formate code for samsung C5212
list of samsung codes for u
Quote:
PLEASE BACK UP YOUR FILES BEFORE UNLOCKING
This will also bring the phone to default settings
1. First do a CUSTOM reset: *2767*2878# (star 2767 star 2878 hash)
turn off the phone
2. take out the battery and sim and put wrong
network SIM and insert a half of it,(pic2501)
so it won't ask for
network password and shows "Insert SIM" message.(pic sam25020)
Now put the battery ,and switch the phone on .(phone shows "InsertSIM" message.)
3.With out turn off the phone push the sim fully in. At this stage the phone isstill asking to "Insert SIM"
4. Make a FULL reset by typing: *2767*3855#(star 2767 star 3855 hash)
5. The phone should reboot working with "wrong" sim inside.
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#(star7465625 star 638 star 8zeros star 8zeros hash)
7. Now Disable
networklock By typing: #7465625*638*00000000#(hash 7465625 star 638 star8zeros hash)
Phone is unlocked (check with *#7465625#)
For Model:
Samsung A300
*2767*637#
Model: Samsung A400
*2767*637#
Model: Samsung A800
*2767*637#
Model: Samsung E500
*2767*688#
In newer phones:
#*7337#
Model: Samsung E700
*2767*688#
In newer phones:
#*7337#
Model: Samsung E715
Turn off the phone. Put a non-accepted Simcard and turn it on. Type*#9998*3323#. Press Exit. Choose menu #7. After phone reboots type *0141# andhit the Call button. Turn off and insert another Simcard. Turn on. The code is00000000.
In newer phones:
#*7337#
Model: Samsung M100
Type *#9998*627837793#. Then type *#9998*737#. Press >/[] (Play Stop) untilphone shows NCK/SPCK number. Press Exit. Type #0111*CODE# (Code is the last 8digits of the NCK/SPCK)
Model: Samsung P400
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung S100
*2767*7822573738#
Model: Samsung S105
Remove Simcard. Enter *2767*7822573738# and after phone reboots, enter#0111*00000000#
Model: Samsung S300
*2767*7822573738#
Model: Samsung S307
In newer phones:
#*7337#
Model: Samsung S500
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung SGH600
*2767*3855#
*2767*2878#
Model: Samsung SGH2100
*2767*3855#
*2767*2878#
Model: Samsung V200
*2767*7822573738#
Model: Samsung X100
In newer phones:
#*7337#
Model: Samsung X600
In newer phones:
#*7337#
Model: Samsung Universal
TEMPORARY UNLOCK:
Put a non-accepted Simcard and turn it on. Type *#9998*3323#. Press Exit. Youwill get a new menu. Select Malloc Fail.
In newer phones:
#*7337#
d500 - #*7337# - ( but not in the newer software versions )
update 04/02/07
1. If you have changed your phone password, change your password back to thedefault 8 zeros (00000000).
1a. NOTE (Modification here by my experience): Goto SETTINGS, SECURITY, thenSIM LOCK and disable this before proceeding.
2. Put a SIM card that is from a network other than the one your phone islocked to
3. When Incorrect SIM error comes up, type *#9998*3323#.
4. White screen will appear with an exit option. Press the right softkey.
5. From the menu that appears, select the Malloc Fail option. This will rebootthe phone and the normal service screens will appear.
6. Type *0141# and then press the green call key. "Personalization"or "Personalized" will appear.
7. Turn off your phone and put the original SIM back in.
8. Turn on your phone. You will receive a prompt to enter a password.
9. Type 8 zeros (00000000) (This is because the SIM LOCK mentioned earlier getsswitched back on)
10. Completed. You have now unlocked your phone.
tested on e900 and d900 phones - may work on similar models but not sure
ps this will work with your new sim but if you try anither sim not used in thatphone bofore it will need code doing again
Apr 03, 2011 | Cycling
Serial number of my phone
To find the 16 digit Phone ID number type (star) (hash) 06 (hash) into the keypad.
hash is also known as pound sign in the US.
Your number will appear on the screen.
You can also check this symbol list by looking at howto unlock your phone websites.
They all start with the list -- Ray
Mar 04, 2011 | Cell Phones
Sir,Pls provide me the details of smasung monte s5620 software update
Here you will catch the right steps for Update S5620 Monte software:
  1. Download Samsung S5620 Monte Software Downloader.
  2. Run the Downloader Program and Select ( BRCM2153 ).
  3. Put your phone into Download Mode by pressing ( Volume Down + Power button ) at the same time.
  4. Now Connect USB cable to phone.
  5. In the program window press Port Search Button to check good connection.
  6. If you want to flash Boot files then chec: Full Download option and then press Boot button and select Boot files folder.
  7. Now you have to select these files : Amss - Rsrc1 - Rsrc2 - FactoryFS each one in its field.
  8. Press Download button to start the programming operation.
  9. Do not remove phone or cable till the program finish the whole process.
  10. After reboot the phone do Full reset by ( *2767*3855# ) and you are done.
Hope this help and if helpful RATE please.
Feb 17, 2011 | Samsung Wave S8500 Smartphone
I need a puk code for my Nokia 3220
Hello - I can help there --
press they charactors into you phone
(star) (hash) 06 (hash) and your PUK number will appear --
sorry I don't have (hash) on my key board -- Ray
Jan 23, 2011 | Nokia 3220
I m trying to by pass my phone lock for sumsung star gt-s5233a, but its not taking the hash key when i try to input the code to unlock it. Please help.
When had set the code of your phone....there will b no hash in that.... try entering the code without hash ......and if still it doesn't get unlock ask again me and also send me the message that appears after entering the code......
Oct 13, 2010 | Samsung Star GT-S5233 Cell Phone
Whenever try to open the login page of yahoo, it says the certificate is not valid
following step can fixed your problem
Strange as it sounds, your systems' time must be synchronized to the actual time. Although your cert's may be current, the time is unsynchronized, & doesn't match the sites certificate parameters.
Right click the system tray time clock> Adjust time & Date> Internet time> Update now. (Make sure your system is set to 'Automatic Synchronize...' while you're here)
Another possible fix:
With Internet Explorer, go to Microsoft Updates, then select the 'Custom' button (not the 'Express'). That will tell you all specific updates for your computer (hardware & software) and in this case the certificate updates.
Note that some Certificates having MD-5 'hash' authentication method, may have been hacked, so it's important to have your system's time & root certificates up-to-date, otherwise a 'Cross Site Request Forgery' hack is possible.
("Security Now" #166)
Mar 16, 2010 | Yahoo Mail
I cannot receive microsoft updates, they fail. Error 1606
The error code 646 will appear when any of the Microsoft office application updates fail to install. Run fixit provided in the below link and then try to install updates.
http://support.microsoft.com/kb/971058
Jan 12, 2010 | Microsoft Windows Vista Home Basic Edition
I am trying to remove my o2 operators logo from my samsung toccolite
Hi,you can do this by installing a new software version on your tocco,
You will need a usb cable to connect phone to pc
Download multiloader
http://tinyurl.com/mxl7xl
Download firmware for a tocco lite such as
http://tinyurl.com/n6nwa9
Connect tocco via usb cable & put in download mode (Hold down the 'Volume down' key,hold in camera & power on) screen should then say download,
Open multiloader ,select the 2nd box MSN2675...,then select full download,select boot and search for bootfiles from the firmware files you downloaded,do the same fof amss,rsrc1,rsrc2 and factory fs,leave the rest as they are,then port search,then download,DO NOT TOUCH AGAIN THE PHONE UNTIL ALL COMPLETE
Download will begin
Ensure your tocco has good charge in battery before starting as its important it doesn't power off during download,keep it connectes until message appears saying all files complete and phone reboots,
You should now have a phone running the newest samsung firmware and no network branding logos
Sep 08, 2009 | Cell Phones
Motorola Mobility Rival A455  Cell Phone Logo
242 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
