Question about Acer Computers & Internet
When I turn on it says acer then blue light turns yellow and says no signal?
  • 11,361 Answers
Try it with other PC, check the cable, if it still does not work then we will have to open it up. Post back what you find first.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 31, 2010
Why blinking yellow light and green light infront of cpu
Check if the signal cable for the display is connected and whether there is any kink that may break a wire inside the cable. If the circuit for display inside the computer is broken, most of the time you would hear beeping when turning on the computer.
Aug 02, 2014 | Acer Veriton Computers & Internet
The light is on yellowe
Hello Qutey Babe, Hi.... the yellow light means there is no signal from the CPU. check your CPU.
Blue means normal, there is signal coming from CPU Yellow (orange usually). means no activity on the CPU,
Dec 06, 2010 | Acer AL1916W 19" LCD Monitor
Blue light goes out yellow light stays on after computer is turn off
User manual: http://www.retrevo.com/support/Acer-X223W-Monitors-manual/id/23224ci553/t/2/
That is normal condition, yellow = no video signal from PC since PC is off or PC in standby mode.
Mar 24, 2010 | Acer 22" X223w LCD Monitor
I need a steering column wiring diagram for a 1979 cj5. On the column side of the plug that goes to the steering column there are 8 wires. White, Black, Yellow, Green, Purple, Brown, Light Blue, and Dark...
Black horn ground
lt.blue left front turn
blue right front turn
brown hazard power
purple turn signal power
yellow left rear turn
green right rear turn
white brake light input
Feb 12, 2010 | 1983 Jeep CJ5
I have an Acer X1700 desktop - 3 days old by the way. Runs Vista Home Premium. 1 day after arrival, pushed power button. Monitor light is blue, flashes the Acer logo, then says "no signal" and blue light...
I would get ahold of acer. It should be under warrenty. sounds like a hard drive issue to Me. Just because it is new doesn't mean it was right from the start. My neighbour had the same problem with his acer. I told him to but a dell or hp. good luck.
Apr 27, 2009 | Computers & Internet
2003 ford ranger 7 pin wiring for a trailer all I need is what the colors on the wiring are blue/yellow/green/black/brown/white
White is ground, black is power to trailer battery trickle charge, blue is brakes, green is tail/running lights, red is left turn signal and left brake light, brown is right turn signal and right brake light, yellow is aux power/back up lights. This is the general color coding, there are exceptions, white, black, and blue are pretty much always as listed above, sometimes the others vary. If you find you are having trouble, post any further questions here, I'll be glad to help out. Curt
Apr 24, 2009 | 2003 Ford Ranger Regular Cab
Looking for a wiring diagram for a 2006 Ford Expedition
7way- black is 12volt (power), brown, running lights, yellow is left turn signal and stop light, green is right turn signal and stop light, white is ground, blue is brakes, and orange is aux power (can be back up lights, if trailer equipped w/ them). 6way is the same, minus orange wire. I have run into some variations to the above color codes (brown, yellow and green only-sometimes these 3 are different than stated, but only mixed as that group, as to what they control- example would be green is running lights, brown and yellow are turn signal and stop lights, the others should be as stated), if you have any trouble with things not working properly, it may be due to these variations, although the above are pretty standard. If you have an ohm meter you can check as you go (check for power at black wire- should be constant 12v, turn on turn signal and check for power-it will fluctuate from approx. 12 volts to 0 volts as the signal power pulses in the wire) hit the brakes, blue wire should show power, etc. Let me know if you need more help as you go.
Apr 11, 2009 | 2006 Ford Expedition
Acer AL1912 Monitor - Screen to black and light on yellow
I found some solutions other posted that didn't come up the first time I looked. I did a reboot and I'm good to go!
Dec 07, 2008 | Acer Computers & Internet
Trailer Lighting Kit
Do u have a 4,5,6,or 7 way (wire) system? If it's 4 way it allows basic hookup for 3 lighting functions:
GREEN is right turn signal and stop light, YELLOW is left turn signal and stop light, BROWN is license, and side marker lights, WHITE is ground.
5way is same as above, but adds a BLUE wire for brake signal or aux. power. Its used on pop up campers, utility and boat trailers.
6way (rectangle plug) green=right turn signal, yellow=left turn signal, brown=taillight, white=ground, red and blue can be used for brake control or auxilary. Used on small motorcycle trailers, snowmobile trailers, utility trailers.
6way Round Plug, same as above, but blue is electric brakes, and black (sometimes red,) 12v; note:sometimes red/black need to be reversed w/ blue to suit the trailer.
7way adds an additional pin at plug in for 12volt power or back up lights. Whoa! hope that answers your question w/out confusing u. Let me know if u need more info.
Oct 27, 2008 | 1997 Mitsubishi Montero Sport
Computers & Internet Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
