Question about Kodak Cameras
Curious as to why different images are stored at different sizes. For example I have 1 pic that is 298 kb and another at 889 kb. I am trying to upload images on to a website and it will not allow me to download images greater than 150 mb.
    Brigadier General:
  • 11,967 Answers
The amount of light and detail in the pic will affect the total size.
Posted on Aug 31, 2010
As soon as i take 1 pic my memory is full i have no memory card in is that y and shouldnt camera hold more then 1 picture
No the internal memory is tiny and if you have a high quality picture setting it will easily fill it up. Buy a 16GB SDHC memory card on eBay, they are ridiculously cheap.
Jul 21, 2016 | Cameras
What is ECM
engine control module
( the unit that controls all functions of the engine and gear box )
Jun 18, 2016 | Isuzu Cars & Trucks
How do u download pic 2 wprofile on web site
Hi!
Just what exactly are you trying to do. Your picture to be uploaded and become the profile picture in a website profile page (like Facebook or yahoo or gmail)?
First of all you need to save the picture as jpeg format (recommended format for image and picture.
You will need to shorten the image size of the picture. Because most of picture uploader needs at utmost 150 kb size of the image file. (In case your picture exceeds the allowable size.. there is a free software that you can use to cut the image size of your picture (like Image Resizer program)
Just post back if you still have some question.
thank you for using Fixya
Mace1Mace
Nov 13, 2010 | Logitech Webcam
Scanning an image only gives a scan 1/4 the size of original...
if u mean the size of image is reduced, as i know, the resolution of image, dpi, is too small --> try bigger dpi
if u mean the image is cut off, u have to clear the scan area or by default
May 07, 2009 | HP Scanjet 5470c Flatbed Scanner
What is best size in kb to upload pics onto Lucid 8?
I'll assume you're Lucid 8 is an 8" frame which is likely to be 800 x 600 pixels.
Giving a size in KB isn't the best criteria - it depends on lots of things including what format you're storing in, the composition of the photo, the software you're using, how many photos you want to display and what you're storing them on. I'll assume the storage isn't an issue and you only care about quality.
If you're storing in JPEG, make sure your image is the same size as the frame (probably 800 x 600 pixels), for an average image, a good balance of compression and quality would be 100-250 KB.
May 06, 2009 | Cameras
I need screws for the Gerry 9021
SEE IF THIS HELPS GOOD LUCK: These assembly instructions are for Evenflo crib model 9021 manufactured in 1999. When you click on the link, click on the image, select "view raw image" and you will be able to use magnifier to zoom in.
(front and back) http://tinypic.com/view.php?pic=2ufeg7o&s=5
(pg 1&2) http://tinypic.com/view.php?pic=315cyeq&s=5
(pg 3&4) http://tinypic.com/view.php?pic=33578ma&s=5
(pg 5&6) http://tinypic.com/view.php?pic=2cy3709&s=5
Feb 13, 2009 | Evenflo Jenny Lind Crib
Lumix FZ20 - Splits and discolors tiff/high-res images - jpgs are ok
I just encountered the same problem with tiffs and a kind friend wrote me a Mac terminal script to fix it since I couldn't run Windows' Irfanview and do 'swap colors rgb to brg.' That still left the slices to move anyway.
I also emailed Lemke Graphic Converter and he put the fix in version 6.4.2. Open the program, go to file/convert and modify, navigate to the image in the left window, choose function/fix Lumix FZ20 2 gigabyte tifs in the dropdown and click go. I imagine if you select all the images and click go it will batch them.
Here's the terminal script. It needs to be put in a plain text document named  'fixtiff.sh'.
for FILE in "$@"
do
echo "Fixing file $FILE"
dd if=$FILE of=1 bs=16384 count=1
dd if=$FILE of=2 bs=16384 skip=2
cat 1 2 > temp/$FILE
rm 1 2
done
Then follow these instructions:
1.  Make a NEW folder called "PhotosFix" or something friendly on your Desktop. If you name it something different, be sure and use the new name in each step below.
2.  Put the "fixtiff.sh" file into the "PhotosFix" folder above.
3.  COPY (copy, not move!) all your photos into the "PhotosFix" folder as well
4.  Open Terminal.  After each command below, hit enter. I've added space to make it clear which part is the UNIX command.
5.  Type    cd ~/Desktop/PhotosFix              (changes to your home folder)
6.  Type    mkdir ~/Desktop/PhotosFix/temp      (makes a TEMP folder - where the fixed files will be)
7.  Type    chmod +x fixtiff.sh                 (makes the script "run-able")
8.  Type    ls *.TIF > list.txt                 (makes a list of all your TIF files in list.txt)
On my computer I needed to do an 8b. Type     bash     (had a different shell than the creator)
9.  Type    for tiffimage in $(<./list.txt); do ./fixtiff.sh $tiffimage; done     (does the conversion!)
Step #9 is where the work begins.  What it does is run the fixtiff.sh script on every file in the list.txt list that is made in Step 8. The script itself takes the first part of the file, skips the 16k of garbage, and then adds the rest of the file.
Some important notes:
1.  There cannot be ANY spaces in the file names.  None at all!
2.  Files MUST have a .TIF extension on them. (the ones you sent both did)
3.  All the "fixed" images will be in your /Desktop/PhotosFix/temp folder
Terrie
Nov 02, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Size of pictures
You cannot make it better, even if you make it larger. If your goal is to make it smaller, Kodak's EasySHare software will allow you to edit and resave as a smaller file for things like web pages or attachments, for example. Just please understand that less data and smaller file size will also limit the print quality to smaller good quality images.
Mar 03, 2008 | Olympus SP-350 Digital Camera
*ist RAW converter problem
Ignoring the JPEG artifacts, which isn't about the extra grain in both the TIFF and JPEG images produced by the convertor, is it possible that different sharpness settings were used for the output images that for the on screen review? High values of sharpening without using an appropriate noise threshold value will have the effect of increasing noise/grain.
Sep 08, 2005 | Pentax *ist D Digital Camera
Cameras Logo
19 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
