Question about ViewSonic VX2235wm LCD Monitor
Vx2260wm How do I get the case open? Saw only 2 screws in back holding stand on but front bezel seems VERY tight & I'm afraid of damaging the case. Eric
  • 11,361 Answers
Use very thin screw driver to pop up the front bezel but do not completely remove the bezel, just enough to pop the back off when you place the front of the monitor on the table top facing odwn on top of a towel. It is a little hard for me to explain in words. You can also serach YOUTUBE.
See vx2255 which is the same chassis.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2255W/
See other pictures in my albums also.
Posted on Aug 31, 2010
How do I open a Klipsch SB3 soundbar to repair it?
The front bezel may be a tight friction fit (to prevent rattles). Gentle application of a putty knife may pry it loose. I know Vizio uses such an arrangement so others could be similar.
Sep 13, 2014 | Computers & Internet
How to open an APC BX900R so I can replace the fan ?
slide the front bezel there is still 2 screws holding in there
Dec 16, 2012 | APC Back-UPS® XS 900 (BX900R) UPS System
How do I remove the case from my Samsung Syncmaster t190 monitor? I removed the screws from the stand, but I can't get more than the bottom loose.
my daughter's 3 year old SyncMaster T190 monitor developed a fault last week -it switches on ok, perfect display for about one minute, then the screen goes blank. It's the same with either DVI or VGA input.Switching off for a few minutes enables the display again, for about a minute.
Other Samsung monitors exhibit similar faults, mostly due to blown Capacitors.So, rather than junk the T190, I decided to open it up and check for damage capacitors.
But how to dismantle it? After spending over an hour searching the web, without success, I had another go.
Here is how:1. remove the foot dish (undo butterfly screw at bottom)2. swivel the remaining stand post RIGHT back, as far as it goes (it may be quite stiff, I had to use WD40)3. stand the monitor on its top edge, you can now see 2 small cut-backs on the post, where it enters the monitor case4. use a small Philips screwdriver and remove the two screws hidden there5. remove the screw holding the two cover halves of the post together6. remove the covers7. the metal core of the stand, with its hinge part, is now exposed8. pull this out (NOT easy!); the part inside the monitor is shaped like a spade and is a very tight fit! I tapped it with a small hammer while pulling hard.9. when it is removed, you can access 2 screws that hold the bezel and housing together.10. gently insert a small flat screwdriver all along the four edges of the bezel and snap it apart11. the remaining parts can now be dismantled; some cables need unplugging (make a note of polarity!)
If anybody needs more information, please email me, I have taken some photos
PS - all capacitors were ok, I've no idea what's causing the fault.
Nov 22, 2010 | Samsung T190 19" Widescreen LCD Monitor
How do you open the back of Thinkvision 20'' LCD Monitor?
NOT FAMILIAR WITH THIS PARTICULAR MODEL BUT EXPERIENCE OF MODERN FLAT SCREEN MONITORS ETC. SHOWS THAT MOST HAVE PLASTIC LOCATION STUDS AND/OR 'CLICK' LOCATORS ALONG THE SIDES + TOP & BOTTOM. THE SECURING SCREWS ON THE MONITOR STAND + CONNECTORS AND MAINS SOCKET MAY ALSO 'DOUBLE' AS CASE SECURING SCREWS.
FIRST ENSURE THERE ARE NO MORE SCREWS HIDDEN UNDER LABELS THEN GENTLY, - REPEAT G E N T L Y - PRISE WITH A WIDE BLADE ALONG THE EDGE, USING CARDBOARD OR PLASTIC WEDGES TO KEEP THE HALVES APART. DO NOT FORCE THE BLADE AS THE PLASTIC CASE LOCATOR SLOTS MAY BE DAMAGED
Sep 26, 2009 | Computers & Internet
Solution didnt help
Looks like a standard sceptre. Should be 4 screws on the back of the mnonitor in each corner. Plus maybe two just above the stand at the rear as well. Once removed, use something thin like a small screw driver to pry the front bezel off. This requires sticking a small flatthead screwdriver into the joint at the side of the screen's plastic bezel ans slightly prying it open (SLIGHTLY). start in a corner and while opening it up slightly pull forward on the frontbezel. This action will release the locking tab that holds the front bezel to the rear housing. You'll have to do this all around the screen. There are roughly 4 tabs for each side. Some of the screws by the way may be hiding behind stickers or sometimes small rubber covers. Once the front bezel is off, you'll need to detach the screen from the rear housing. Remove the button bar at the front once inside (three screws) then remove six silver screws that hold the screen to the stand. Lay the screen down on it's back wqhile doing this makes it a lot easier. Once loose, lift the screen from the housing. What do you want to do when you are inside?
Aug 01, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
How do Iopen the case of an HPvs17x monitor?
The Capacitors on the power board are usually the reason for failure of an LCD. If you open the HP VS17 ( I can provide an exhaustive step by step If I have to) remove the five screws for the power board ( larger of the two boards) and look for an area where there are 4 caps (see pic). Look for exploded, popped up, bulging, or leaking caps and replace with the same or slightly higher tolerances. The one I replaced last night were (2x )1000uf25-50volt and (2x) 470uf25-50volt. Check the rest of the board for similar issues and replace as needed.
Jan 21, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP L1940 19" LCD Monitor
Hi...there,
It's open from the front bezel of the screen.. Place a piece of cloth or fiber cloth over the screen and carefully lifted up the bezel... do the same from other angles...
Dec 16, 2008 | HP L1940 19" LCD Monitor
Lg monitor l194wt
It's not glued!!!! It's clipped together...and DON'T take out the screws first...
First, turn the monitor upside down and look at its thin edge. See where the grey bezel meets the black case? That's your clip point, all the way around the monitor. The reason you want to start here? This monitor is VERY tight, and there's a good chance you will mar the plastic, so it might as well be in the least visible place.
Next, fit a plastic trim removal tool (you have one of those, right? Right!? :) ) in between the black and grey plastic, halfway along the length of the monitor. If you have difficulty getting it in, run it back and forth until you find a loose point, but you'll eventually have to come back to the tight spot.
Here, there's a little bit of finesse required...you have to pry the grey part (which I will start calling the "bezel") gently upward, not away from the black plastic (which I will call the "case"), perpendicular to it. This will pull a clip up out of its slot. When you feel the clip release, now you can move it slightly away from the case, but don't remove the trim tool. Keep unclipping the rest of that side.
Once you've gotten the hang of it, do the next side. This bezel is particularly tight, so don't start at the edge...you will definitely damage it. Once you've gotten two sides loose, the whole job becomes easier, but still stay patient and careful, because there's a lot of potential for damage.
Now that you've gotten the entire bezel off (and the hard part is over with), hold the LCD in place as you turn the assembly face down onto a soft cloth, like a blanket or comforter. Now you can remove the four screws from the back.
Lift the case off and remove the two screws holding the switch assembly. This will lift off easily.
Lastly, partially remove the silver tape holding the electronics case on the back, carefully remove the connectors (remembering their positions, of course), and you're ready to play electronic doctor. I'm posting this with my newly repaired L194WT. :)
Jun 14, 2008 | Gateway FPD2275W LCD Monitor
Can't open case
dell optiplex have very tight casings, dont be afraid to use force.
I have one myself and it is a struggle to get the casing off.
as long as those 2 side buttons are pushed in just give it a good tug and hopefully it should come off.
Dec 04, 2007 | Dell OptiPlex GX260 PC Desktop
Is there an easy way to open this monitor?
-Flip the LCD face down and remove the screws that hold the base in place. -looking at the top edge of the LCD monitor you should see a small notch on each end between the front bezel and the back cover. -Using a plastic tool or a flat blade screw driver insert the tip and gently pop the case open. -Work your way around the edge of the case. -Once the LCD monitor is open unplug the control panel connector from the right side and remove the front bezel. Let us know if you have any other questions and please don?t forget to rate this post.
Dec 28, 2006 | Dell E173FP 17" LCD Monitor
ViewSonic VX2235wm LCD Monitor Logo
327 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
