Question about NorStar M7324 Corded Phone
WE CAN'T DIAL OTHER EXTENSIONS FROM ANY OF OUR PHONES. OUR SECRETARY BROUGHT IN HER CHILD & HE MESSED WITH THE PHONES & NOW WE CAN'T CALL EACH OTHER. HOW DO WE RESET THE PHONES?
Try disconnecting all power for a minute and then reconnect everything.
Posted on Aug 31, 2010
Reset Admin password NorStar T7316E Corded phone?
You NEED to get SYSTEM documents (Hard Copy or CD)
for NORTEL NORSTAR CICS before TAMPERING ...URL posted below...
Found on page 24:
Default Password Code is "admin" on your phone dial... Done by pressing 23646 on your phone dial...
Time feature is accessed by inputting **8463 = (**TIME)
Hope this helps...
(CAUTION: read & understand BEFORE programming)
http://phone.manualsonline.com/manuals/mfg/nortel_networks/compact_ics_61_system_coordinator.html?p=24
Feb 03, 2016 | NorStar T7316E Corded Phone
Denied access on Nortel T7316E Log# 1020000 will not work..How do I fix this?
Follow this instructions to reset the Administrator password.
Press Feature 985 and dial 9 even though it is not listed as an option.
The display will show Pswd: dial 73738767793
The display will show Reset pswd? Press YES.
You should now be able to enter the default password.
2 digit extensions use 120000
3 digit extensions use 1020000
4 digit extensions use 10020000
Jul 31, 2012 | Nortel Networks T7316E Telephone Platinum...
How do i transfer a call to another extension?
Unless your phone is connected to a TAW-848 or higher, your extensions are numbered 101-124 maximum, or 21-36. Try going to any phone but the main one and dialing either 101 or 0 and look at the display. You'll figure out your 3-digit extensions. Now just press TRANSFER and dial that 3-digit number. The outside call is put on hold when you press transfer, so there's no need to use the HOLD button.
As an alternative, you can press HOLD, putting the outside line on hold, and dial the 3-digit number into the intercom dial tone and announce the call for line number x. Or, dial the page code 330 and announce to all phones for the person to pick up line x.
Carl
Jun 16, 2011 | Panasonic KX-T7730 Corded Phone
What is the code for adding gateway
Here is the code in the older version I added to /etc/asterisk/extensions.conf under [macro-dialout-trunk] as follows:
; Special mod for custom account code
exten => s,n,Set(CODE=${CDR(accountcode)})
exten => s,n,GotoIf($["${custom}" = "AMP"]?customtrunk)
; Modifyed next line
;exten => s,n,Dial(${OUT_${DIAL_TRUNK}}/${OUTNUM},300,${DIAL_TRUNK_OPTIONS}) ; Regular Trunk Dial
exten => s,n,Dial(${OUT_${DIAL_TRUNK}}/${CODE}${OUTNUM},300,${DIAL_TRUNK_OPTIONS}) ; Regular Trunk Dial w/ Account Code
exten => s,n,Goto(s-${DIALSTATUS},1)
New version added [macro-dialout-trunk-predial-hook], it is just before the dial happens.
So I added the following in extensions in the [macro-dialout-trunk-predial-hook]
exten => s,1,Set(OUTNUM=${CDR(accountcode)}${OUTNUM})
Dec 09, 2010 | Computers & Internet
Change Auto Attendant message to Rollover Calls to Ext. 10 and 15
**use with care ** if it is a "Partner System" here you go. if unsure do not do this. it is simple but one wrong keypress will cause ... mmm problems. so just hang up if unsure. dial intercom 777 , then * to get main greeting, if ok then * again then enter extesion should be prompted. press 0 # then password , default is 12345678 #. if it is good dial 9 (administration) then 3 (auto attendant) then 1 , 1, 6, * , # then 1 to record and follow prompts.
Oct 10, 2009 | Lucent PARTNER18 Corded Phone
Panasonic kx-t7030 FWD/DND button
Outgonig calls and the FWD/DND button are not realted. Walk up to the phone and dial 790 on the intercom. That should reset everything.
Now, try that calling out and see what it's doing. If you can dial "9" from the intercom and get an outside line, start dialing a number and see if it fails. Watch the display at all times. If it is still broken, post back.
Carl
Jun 23, 2009 | Panasonic KX-T7030 Corded Phone
KX-T7730 phone. Need to reprogram one of the PF buttons as a CO2 button. I accidently messed up the programming of this button while trying to program a different PF button as a one-touch dialing...
Just so we're on the same page, the PF buttons are the 12 buttons on the right and their ONLY function is one-touch dialing. They can't be CO buttons. The 12 buttons on the left are called CO buttons and they can be programmed to do a number of things, including CO, DSS, and feature access buttons.
To reprogram the button, press PROGRAM, the button, the dial 0 + the CO number (1-8) and STORE. Extensions are 1+ext and one-touch are 2+. Other features are in the programming guide.
The PF buttons are programmed by just dialing the digits, but if it calls out, you must dial an access code first, usually "9".
Carl
Jun 17, 2009 | Panasonic KX-T7730 Corded Phone
Transferred calls
sounds like the phone transfer numbering is out of sync or someone thinks its funny to send there transfered calls
i would go with the lessor of 2
phone numbering extensions example=
say you want to call someone at 2430 ext. but it takes you to 2340 that would be phone interupt extention box
the phone company who installed the software should come out and make sure the extensions are to the correct offices its there service but you pay for quality service to know and see it works
to send back calls just transfer back to secretary switch board the secretary will know what to do
May 07, 2008 | NEC Dterm DTP 32D-1 Corded Phone
Extensions
Call Pickup Direct
Upon hearing ringing or voice
announcement at another
telephone:
1. Lift the handset.
2. Dial the Call Pickup Direct
code 67.
3. Dial the station number of
the telephone to be
answered.
4. Converse.
Apr 09, 2008 | NEC Electra Elite 32D-1 Corded Phone
NorStar M7324 Corded Phone Logo
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
