Question about Canon MultiPASS MP700 All-In-One InkJet Printer
Canon i350 waste tank is full - Canon MultiPASS MP700 All-In-One InkJet Printer
  • penquin Nov 10, 2008
    wast tank almost full
  • Anonymous Feb 08, 2009
    my i350 canon is splitting lines what canI do?
  • 1,218 Answers
Check the following steps for reset canon i350 waste tank :
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
http://social.technet.microsoft.com/Forums/en-US/itprovistaprinting/thread/a1e247a6-52d2-416e-8432-ce3e361a9547
Posted on Oct 07, 2010
  • 734 Answers
1)Printer on, press Additional Functions, Scan, Copy, ScanNow you should be in service mode from there for waste ink tank reset it is simalar to what has already been posted
2)Select Test mode which is like the last avalabe selection
3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
The menu will now say EEPRON Clear
Select Ink count which is option (0) and press set
Then press Stop/Reset Followed by the power button and then wait for it to restart.
Posted on Dec 09, 2008
techman
  • 3130 Answers
SOURCE: canon i350 printer waste ink tray full.
according to cannon the Waste ink ABORBER not tank is getting full. To clear this error press resume and print button. But this will only fix your problem if at all for a short time as this is not considered user replaceable part. You can contact canon on line at http://consumer.usa.canon.com Good luck
Posted on Apr 23, 2006
SOURCE: waste ink tank full error 5b00
Check out:
http://www.fixyourownprinter.com/forums/inkjet/50418#1
Posted on May 01, 2008
  • 49 Answers
SOURCE: Canon printer i 475D
This may be worth a try
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Jul 03, 2008
SOURCE: I have a Canon i350
check online for reset code temp fix longer solution time permiting open front cover power up like you need to replace cartrige pull plug before return with light look were the cartage usually stops you'll see a  square  ontop of square is rubber gasket holding 2 filters remove and clean  with soap &water clean out area around square suggest isapropal alcohol and q-tips (lots of them) let everthing dry overnight reasemble use reset code you should be good to go
Posted on Sep 16, 2008
  • 56 Answers
SOURCE: tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Posted on Sep 14, 2009
My Canon i350 has a full watse ink tank, how can I get round this?
open you printer then replace waste ink the back side of printer mechanism
Aug 12, 2011 | Canon Office Equipment & Supplies
"Waste ink tank almost full"
Here is the reset process. You need to carefully follow the steps for it to work. Not to defend Canon but without the waste ink counter you will at some point end up with ink leaking from the printer.
Waste Error Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
6: Press Power to set data
I hope this helps.
Mar 21, 2011 | Canon Office Equipment & Supplies
Message coming on saying waste tank full contact supplier
HI!
Honestly?You can throw the printer away and buy a new one as it will be cheaper and easier on the pocket!!!
Good Luck!!
Jan 22, 2011 | Canon i350 InkJet Printer
Not printing, flashing amber-green light. Message says waste tanks are full....................HELP
Hi there! Follow those steps: i250, i350 and i000 series
3: Connect power.
This method will work only whilst the printer's connected to power. Turning off and on at the switch will keep it, but unplugging it from the power will reset it, which means you'll have to do this again: What this does is temporarily reset the printer, but also stops it from doing headcleans everytime you open the door to switch print heads or ink tanks.
Thaky for using Fixya.com
Nov 24, 2010 | Canon i350 InkJet Printer
When i try to print i get a message "used ink tank is full" canon i350
This applies to Canon printers but since you did not specify the printer name and model here is the information I have courtesy of Canon's Support Website.
Don
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700 The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 01, 2009 | Canon Office Equipment & Supplies
Tank absorber full and lights blinking
Note
Sep 14, 2009 | Canon i350 InkJet Printer
After the power went off my printer doesn't print and is in a cycle of green and orange light. What can I do?
my printer says the waste ink tank is full, and the power lamp flashes alternately green and orange
Jun 30, 2009 | Canon i350 InkJet Printer
Canon i350
http://startcopy.ru/repair/can_s_ip.htm
Nov 08, 2007 | Canon i350 InkJet Printer
Canon i350 printer waste ink tray full.
Apr 22, 2006 | Canon i350 InkJet Printer
Canon MultiPASS MP700 All-In-One InkJet Printer Logo
741 people viewed this question
old marine
old marine
