Question about Goodman CKL30AR30 Air Conditioner
IM PRACTICIN TO GO IN THE FIELD O WIREING AND I WAS WIREING MY GOODMAN CPKE36-1A UP AND IT STILL DOES NT WORK I PUT THE WIRES BY COLOR TOGETHR WITH TO LEFT OVER A GREEN AND A ORAND AND IM NOW AT A STAND STILL I WOULD HAVE A PROFESSIONAL DO IT BUT LIKE I SAID IM N COLLEGE NOW 4 THIS SORT OF STUFF.. JUS NEED A LIL HELP
  • 32 Answers
By reading you post I would sya to hir a professional!!!!!
Posted on Aug 31, 2010
Im working on a electric furnace & when i put the thermostat on auto & heat it cuts off. i thinking i have a wire in the wrong place. any suggestions?
Check for a jumper wire on the thermostat termnials (RH/RC) if not, add one small wire to connect them and include the wire that is already connected on RC.
Nov 09, 2011 | Goodman GMS90703BXA Heater
I have a 97 toyota corolla, my father had givin me his old radio, earlier today my car radio lit on fire almost torching my dash board, im a trained firefighter so i know how to put it out. unfortunatly im...
OK, first I recommend you purchase a wiring harness specific to the vehicle. The wiring harness is equiped with standardized wire colors to match aftermarket radios. Then the harness plug situates the wires in the correct pattern to match the vehicle. All you do then is plug it in. You will probably need a trim panel too. I recommend you check out www.crutchfield.com, they have the harnesses, dash kits, and instructions. Hope this helps.
Aug 29, 2011 | Car Audio & Video
Im trying to wire a goodman 5 wire air handler to my 4 wire t-stat and 2 wire condenser can u help
remove the jumper from the t-stat between rh & rw then the stat will be 5 wire
Apr 02, 2011 | Goodman Heating & Cooling
I have power in 14/2 and 14/2 out to light. how do I wire the switch. I tried putting whites together and blacks to switch but it doesn't work.
Your breaker is not tripped.
Your light bulb is working.
You have a working on-off switch that has two brass screws and a green ground screw.
That is a single pole switch. Black wires go on either brass-colored screw, and whites are twisted together.
If switch has 3 screws and ground screw, connect black wires to dark-screw and one of the brass screws.
First you should test your wires.
You have 2 cables.
Both cables have black, white, and bare copper ground wires.
One cable goes to light.
Other cable comes from breaker box.
Cable from breaker box has black-hot wire and white-neutral wire.
Turn on power and test black wire to white, and then test black wire to ground.
Tester should light up with both tests.
If tester does not light up, then breaker is suspect, or there is a short in nearby box.
Track back the short towards breaker, going one box at a time, each time testing black to white and black to ground.
Next, inside the switch box, remove the switch and connect both cables without the switch.
Black to black
White to white
Turn on power, does light turn on.
If light turns on, your switch is suspect. Connect new switch. One black wire to each brass screw, and then tie white wires togethr.
If light does not turn on, your light is suspect. Open light fixture and test black to white and black to ground again.
If light tests with power, then check your bulb
If light has no power, then wire between switch box and light is suspect.
Dec 06, 2010 | Electrical Supplies
My modle number is aruf 036-00a-1 my serial number
MY MODLE NUMER IS CPLE42-1 SERIAL NUMBER IS 010940037
Aug 04, 2010 | Goodman CKL36AR36 Air Conditioner
Blower does not work and heating element heat with
Check for power to the unit. If power exists, check your low voltage. Do you have 24volts to R & C at your thermostat?
Feb 07, 2010 | Goodman GMS90703BXA Heater
All the wires on the outside of my goodman airhandler
The wires on a Goodman Air Handler Red to R, blue or brown to c, yellow to y cool, green fan g, white to w heat
Dec 14, 2009 | Refrigerators
Motorcraft alternator to regulator
Here is a generic wiring diagram that should work
Oct 30, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Goodman CKL30AR30 Air Conditioner Logo
149 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
