Question about Apple eMac G4 Desktop
Removing outer shell of emac
Hello i took my emac apart before but i remember having a big problem connecting the small power button wire back on it is so tiny.  used a tweezer and needle or something and it took me hours.  anyway i would like to know how i can reconnect the power button or what is  the proper way of going about it. i have to clean the inside around the fan. i can't find a print out i had on how to go about it. it is okay now but i want to clean it. please reply asap. thanks
Purchase a curved Hemostat. This works wonders in tight situations because you can lock the gripper in place while you work the plug back in. Hemostats usually cost less than 5 bucks at fleamarkets and some Drug Stores.
Posted on Jun 08, 2008
  • 4 Answers
Lift the housing up 4 " pull off the power button cable on the housing side. reverse.
Jerry
Posted on Jun 03, 2008
I have clothes that is stuck between the outer drum and its plastic shell, how do I get them out?
Hello, Thank You for using FixYa. I will be helping you today.If it were me i would remove the hose that connects the tub to the pump and see if i can get them through there. Taking the whole thing apart is a big job and last resort.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Washing Machines
The power electric was run over by mower -unit has no electical power
You could bring it to a repair shop where they will probably install a new power cord. The now-shortened power cord can be fitted with a new plug, and used as before instead - for a fraction of the cost.
From what I can tell, the pressure washer is a 120 volt type. Purchase a replacement plug - called a "cord cap". The most common configuration is pictured below:
A 15 amp / 125 volt male cord cap made by Leviton.
Your's is likely rated at 125V/ 15A (like the one above). This means there's 2 parallel blades and a ground pin - like most grounded plugs in your home. If unsure, bring the cut off section of the power cord to a hardware store to select an identical cord cap. You'll want to purchase the type of cord cap that has terminal screws - not the type without screws. The packaging of the cord cap will indicate how much of the cord jacket and individual wire insulation to remove. A little more or less won't make it impossible to do - but don't deviate too much from these dimensions for the best results. Once the cord has been stripped correctly - Disassemble the cord cap body from the outer shell by removing the screws on the front. Loosen or remove the 2 screws at the cord grip end and slip the shell over the end of the power cord.
Bring the cord cap body to the cord. The body will have 3 screws. One each silver (or light colored), bronze (or dark colored) and green. Loosen all the screws - do not completely remove them. Twist all the strands of each wire so that they are bundled together and there are no stray wires sticking out. Do this for each white, black and green wires. The black wire will connect to the bronze colored screw, the white wire to the silver screw and the green to the green colored screw. You can either insert the stripped wires into the small holes at the back of the terminal screws, or wrap them around the screw terminals themselves. The best way is to wire from the back - but if you choose to wrap around the screws, be sure all the small wires are under the screw head. Tighten the screws and tug the wires one at a time to make sure they are held firmly in place.
Once satisfied that the wires are connected correctly and tight - slide the outer shell towards the cord cap body. Align the screws with the holes in the outer shell. The parts will only fit together one way - so don't try to force it together. Tighten the screws in the front and then install / tighten the screws at the cord end to grip the cord. This clamp should be firm - but not to the point of crushing the cord. Test in a ground fault protected outlet and you're done!
I hope this helps.. please rate this reply - thanks!
Dec 21, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
Starter replacment need to remove starterRwoo0
Disconnect the battery, drain and remove the outer primary cover. From the left side of the bike, remove the battery cable from the starter and the small solenoid trigger wire. You may have to remove some or all of the exhaust system. Back on the right side of the bike, remove the two bolts just above the outer clutch shell that holds the starter in. They are two different lengths so remember which bolt goes where.
Good Luck
steve
Aug 28, 2010 | 2005 Harley Davidson XL 1200 C Sportster...
How remove Kenmore frontload basket from rear shell?
this is a big job and prob spendy if not under a warranty......
the outer tubs are connected by metal fasteners which need to be removed by a flat screwdiver mark the old fron outer basket with a marker so u can replace those clips in the same manner..........to get acess to the tubs turn power off and remove top, remove back panel, remove front as well console bottom panel etc,,, disconnect all componets,bellows gasket ,connection wires, tubes, remove motor, undo bottom pump tube, remove belt and remove back bolt holding on pulley, get two people and remove tub out front when completed disasseblying all necessary pieces.. once tub out then remove those metal fasteners and set aside front tube reinstall onto new rear/inner rear tubs... hope this helps i might have forget some things actually i know i did this is a complicated process hope this helps let me know
Apr 20, 2010 | Kenmore Elite 45986 Front Load Washer
No power cannot turn on
Inside the unit behind the control pannel is a ceramic fuse looks like a car glass type fuse. To replace it you must remove the outer shell. First unplug the device,2nd
place on a flat work area,3rd remove the screws from the back of the unit,4th pull the outer shell back if it's stock a flathead screwdriver can be used to aid in removal,5th after removal look behinde the control pannel find the main power wires by following them from the back of the unit the fuse will be about 1" long and about as big around as a #2 pencil remove it carefully and replace it with a new ceramic fuse. The fuses are about $3.00
If you don't feel comfortable doing this yourself find a repair shop it will cost about $35 dollars
Hope this helps
Please leave feedback
Jan 07, 2010 | Kenmore 63672 Convection/Microwave Oven
Toshiba Tecra S1 'Display freaks out' Iserni hello, your help with my display problems for a toshiba tecra s1 was helpyul with one exception... What/whenre is the 'Berg Strip' I took the thing apart...
if it is a single wire ,pls check it and connect to wireless card , id it has cover ,don't need to connect. also it has multi wire connector pls connect to display connect on the mother board.
Mar 07, 2017 | Toshiba Tecra S1 Laptop Notebook
Need to remove outer sheel to get access to drain pump
first remove the two screws that hold in the control panel and tip it back, then there two clips that the shell is locked onto undo them and pull the shell away from the unit. remember to shut off the power first. remove any wires that are hooked up aand the replace the pump. good luck
Jan 11, 2009 | Roper RAX4233PQ Top Load Washer
Dead ECS G733 laptop
Yes, try replacing the power button assembly first and the heatsink assembly and fan before shelling out big bucks on a Mobo (which is probably pulled from another LT).
Nov 21, 2007 | EliteGroup ECS G733 Notebook
Apple eMac G4 Desktop Logo
150 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
