I have a Toshiba Satellite P100 laptop which I bought in New Zealand. I think the model comes from the USA. Part of my screen is flickering. It runs vertically from the top to the bottom of the screen and the flicker is 2 inches wide. I can start my computer as normal but the flicker stays constantly. I can't read the screen behind the flicker or see my pointer. Can you tell me what is wrong with it and how to fix it? I have already tried the save mode and restart points but both don't work. I have an upto date Norton 360 antivirus complete package which I update weekly. John
    Sergeant:
  • 324 Answers
Good morning, Kevin!
Sounds like an LCD problem. You can verify this by hooking up an external monitor. The external monitor will probably show a good display.
After verification of the problem,you may want to try to replug the LCD cable at both ends, just to see if that corrects the situation.
If that resolves things, all is well and good. If not, you may need a replacement LCD.
If the external monitor shows the same display, you may have a motherboard problem.
Hope this information is of some help.
Ron-
Posted on May 09, 2008
TOSHIBA p100 LAPTOP SREEN DEAD AFTER BIOS UPGRADE
Purchase a new EEPROM with a good BIOS loaded. I suspect the anti virus programme was not disabled and has stopped the new firmware from loading, leaving a corrupt EEPROM.
Mar 23, 2013 | Toshiba Satellite P100-429m Laptop DC Car...
Toshiba satellite pro p100 screen problem
The LCD can be replaced. The part is around $50-$75 I believe. It can be tricky to replace, but if you take your time, you can save money by doing it yourself. The screen sounds cracked or broken, and black & white will not work either.
good luck
Mar 19, 2013 | Toshiba Satellite P100 Series / Satellite...
How to check out or look for problems with the lcd monitor on toshiba satellite p100
The internal screen is faulty. Check the inverter first. (under the display).
Jan 20, 2013 | Toshiba Satellite P100-102 P100-103...
Toshiba satellite backlight
Mohammad,
Toshiba Satellite P100 screen Inverter replacement;
1) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P105-P100/remove-lcd-screen-inverter-1.htm
(You can click on any photo to enlarge it. At the top, and bottom of the page are the page numbers. They are in white; Page1 :: Page2 :: Find another model )
2) Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight (Present technology) is a CCFL, or a series of LED lights.
The Toshiba Satellite P100 series of Notebook PC's uses a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average size is approximately 2mm Thick, and the length is close to the height of the LCD screen. 2mm is a little larger than 1/16th of an inch.
This means the CCFL can be broken quite easily, as it is fragile. (You also DO NOT want to be cut by a Fluorescent lamp )
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
A screen Inverter converts the power from the laptop, for the Backlight, and LCD screen.
As previously stated in a Clarification, 90 PERCENT OF THE TIME the fault is the screen Inverter.
Regards,
joecoolvette
(I never request commendations, but thank you for offering.
We, the older techs here, feel that is begging.
3 years at FixYa so far.
Regards,
joecoolvette)
Mar 23, 2012 | Toshiba Satellite P100 Notebook
Can graphics card installed to toshiba satellite L510
If you are asking if you can upgrade your laptop video card the answer is NO. Your laptop came with an INTEGRATED Intel Video card. Not possible to upgrade or install a different graphics card
Nov 20, 2010 | Toshiba Computers & Internet
Toshiba laptop P100-ST9612 majors problems--NOT fixed by Toshiba.
oooo man that ones a doozy, if its the one with the go9700 video card its a pretty bad model. the card brand new is 700+ from toshiba. i have run into that problem quite a bit.
Nov 30, 2009 | Toshiba Satellite A105 Notebook
LCD Screen turned opaque at two places, I see two white opaque lines 3 inches wide one on left side of screen and other in the middle
Yes you are correct. I would say 95% of the time, you will need a LCD screen replacement. Also be sure to disconnect and reconnect the lcd cables, at the motherboard and behind the lcd itself, just to make sure the cables aren't making bad connection.
I have provided you a link to MANY lcd screen for your laptop on EBAY.
http://computers.search.ebay.com/Satellite-P100_Screens-LCD-Panels_W0QQcatrefZC6QQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQdfspZ32QQfromZR2QQfsooZ2QQfsopZ32QQftrtZ1QQftrvZ1QQsabfmtsZ1QQsacatZ31569QQsargnZQ2d1QQsaslcZ2QQsbrftogZ1QQsofocusZbs
Hope this helps you. Please rate my solution.
May 16, 2009 | Toshiba Satellite P100 Notebook
Laptop works fine until the screen turns complete black...
Well you can look if you pluged cable into GeForce not into motherplate second you can try it on another laptop if it works well you must repair your computer
Dec 31, 2008 | Toshiba Satellite P100 Notebook
Toshiba Satellite P100-10M sound driver
i see well then try this
http://www.pcauthorities.com/driver/audio_drivers.html?gclid=CNXxq5LwpJQCFSUaagodZiP3tg
Feb 19, 2008 | Computers & Internet
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
