Question about Pinnacle Studio Ultimate 14 for PC
Pinnacle 14 says "not responding" very frequently... i have 250 + 80 gb hard disk.. in 250 gb hard disk am using os.. pls help me.
    Problem Solver:
  • 5 Answers
I found that Pinnacle usually did the whole "this program is not responding...CRASH" thing when I was trying to do a lot of things all at once very quickly...clicking on this, dragging this over there, adding this effect here...all before i allowed pinnacle to render the things i had it do.
To combat this, everytime I do something new to a clip, I let it render before doing anything else...
it slows me down a LOT, but not more than having to re-open pinnacle over and over did.
Posted on Sep 29, 2010
Toshiba 593400-e external hard drive problems
Hi.
my external hard disk not supported in my laptop after install new os for window 7 professional 32 bit so pls give the solution
Oct 16, 2012 | Toshiba Canvio Plus 320 GB 2.0 Portable...
When I was instoling pinnacle studio ustimate version 14, which I received when I bought camcord, it ask me that I don't have windo3.4. what can I do?
The system requirements for Pinnacle Studio Ultimate 14
1) Windows® 7, Windows Vista® (SP2), Windows XP (SP3) operating system.
2) Intel® Pentium® or AMD Athlon™ 1.8 GHz (2.4 GHz or higher recommended)
Intel Core™2 Duo 2.4 GHz required for AVCHD*, Intel Core™2 Quad 2.66 GHz or Intel Core i7 required for AVCHD* 1920.
3) 1 GB system memory recommended, 2 GB required for AVCHD*
4) A DirectX® 9 or 10 compatible graphics card with 64 MB (128 MB or higher recommended)
128 MB required for Red Giant Magic Bullet Looks Plug-in: Pixelshader 2 required, Intel GMA integrated graphics not supported. 256 MB required for HD and AVCHD*
5) DirectX 9 or higher compatible sound card.
6) 3,6 GB of free hard disk space.
7) DVD-ROM drive to install software.
Check to see if your system forfills the minimum system requirements.
Mar 07, 2011 | Pinnacle Studio Ultimate 14 for PC
Hi pls how do i formatt my 500gb hard disk for my mac
Go to the applications folder and then utilities open Disk Utility in the left box select you firelite and then clcik on the erase tab to your right. You can then select how you are going to format the hard drive standard for using with Mac only machines is Mac OS Extended (Journaled) or if you want to use with both PC and Macs is MS-DOS (FAT). Then name your drive and click on erase. Hope this helps.
Feb 03, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I cant install the disk because it says that i need service pack 2
Hi there
Please go here http://windows.microsoft.com/en-GB/windows/downloads/service-packs and choose what Operating system you are using maybe XP, Vista or Win 7 there you will be guided to wher you can download the latest service pack for your PC. The disk that came with Pinnacle was created to be used with only SP 2 or above. That is why it is calling for the SP 2.
You will need patience, these packs are big in file size. Make sure you have a good internet connection and good RAM memory in your PC. Optimise you disks with Mydefrag makes your PC faster too but it takes a long time http://www.mydefrag.com/
All the best now, good luck, it may take a few hours! Phil
Dec 17, 2010 | Pinnacle Studio Ultimate 14 for PC
Recently i ordered a dell studio 14 laptop. they did not send me any copy or disc of the OS installed in it, i.e., Windows 7 Home Premium. however the entire 500 GB of hard disk space has been only in the...
Hello Sir,
You can create a Partition in your hard drive without affecting your OS. Just follow the process I've sent.
1.) Go to Start Menu and Type in search area Create and Format Hard Disk Partition.
2.)Open the Create and Format Hard Disk Partition.
3.)Now you can Select the C: and can Partition it with another new drive.
Thank You
Aug 09, 2010 | Dell Computers & Internet
We are unable to load window xp on hard disc, before we only find the 32 GB in 80 GB hard disk ... we successfully installed the window xp, but when jumper setting done in accurate place, it shows 80 GB,...
I think this model is still an IDE type. You set the 32GB limit then jump the settings to read the full capacity of the drive. If you are trying to load XP OS from a blank drive.
First prime the hard drive, you can do low level formatting and use third party software to partition and format the drive. on FAT32 partition you can only use 8GByte to make the drive bootable. Make it primary if I remembered it correctly and active. Or use the NTFS format.
You can use also if it have the manufacturers' hard drive utilities to check the hard drive integrity. I know they have it. It also equip with zero fill to renew chain and links of the drive. Then partition, format, primary and active. Then load your OS.
Check also your CD disc integrity, scratches do make a lot of troubles. And also your cdrom/dvdrom drive.
Oct 27, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My system is not stable
Can be virus...hardware..or o/s issue
  1. Try taking unwanted files or prrgrams
  2. empty the temp folder
  3. Scan using latest anti virus
  4. Defragment
  5. if still same. Try formatting and re-installing the o/s..
  6. if still the same check replacing HDD ...or M/B
May 22, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
I am having 8 gb transcend flash my flash was plugedin the usb of my computer. i was trying to use norton ghost for one hard disk.it was asking me for some option i dint see and started preesing ok ok .....
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Apr 30, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Pinnacle Studio Ultimate 14 for PC Logo
1,821 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
 Ian Kayhan
Ian Kayhan
Pavel Pranovich
Pavel Pranovich
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
