Question about HHB BurnIt CDR830 CD Recorder
My hbb cdr -830 stopped in the middle of 1.22 into finalization, and i tried refinalizing and it still didn't want work.
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: can't finalize after recording, disc error
So are they always CD-RW?
I have a Pioneer PD509 which is a spittin' image of the HHB CDR830 but tied down to use CD-Audio discs only.
My experiece with Rewriteable Media has been that they don't hold up to multiple uses. I used them to make quick 'n' dirty dubs of cassette audio then worked it into a polished copy with proper track marks and sweetening later for copy over to a CD-RA. After a few passes I'd start getting audible problems when copying off the -RW's, so I routinely just use them about 5 times. With two DVD players and a Blu-Ray I sometimes get through the errors on one of them for one final digital copy and then I can them.
BTW: you may want to try the failing disc in a DVD player. Mine will play through an unfinalized CD but can't cue up to anything. So if the recording is vital you might retrieve it that way. Just remember to pause the Recorder at the end of the last cut you want because the DVD will just crash right into the old data without changing track numbers or any warning.
Posted on Mar 04, 2010
dunnbiker
  • 8546 Answers
SOURCE: Hi , My cdr 830 stopped recording at maximum
I can't speak to the hardware issues that might be at play here but I would advise you to retain the 'bad' recordings. I've copied unfinalized CD's from an old DVD player. It will read the CD but you won't be able to manuever around the tracks. As I recall, the track marks will still be there.
I don't know what you mean by 'maximum fidelity'. The CDR records at the CD standard of 44.1kHz. Digital is all ones and nones. Just data. If it is written correctly or with tolerable errors the ADC of the player (ANY player) turns it all into music.
Posted on Mar 03, 2011
Hi , My cdr 830 stopped recording at maximum fidelity, and most recently all data disappears upon finalization, the prompt reading "new disc" after recording a whole 70 plus cd. Frustrating...
Mar 02, 2011 | HHB BurnIt CDR830 CD Recorder
Phillips CDR 570
Let's start with an assumption... you're using ReWriteable discs.
What specific message do you get when you try to unfinalize it?
When finishing a recording, what does it display instead of "update" when you stop?
May 04, 2010 | Philips CDR796 2-Disc CD Recorder
Problem with Finalizing Disc
When you insert the disc what does the recorder display after it examines it (Reading TOC)? - CDR, TOC, CDR-W, NO TOC?
It should know the disc is not finalized and let you either record more on it or finalize it.
If not, and you need to recover the 4 tracks try loading the disc on a DVD player. My old Pioneer will read unfinalized CDR-A's so I can digitally copy what's on them back to another CDR-A.
Apr 13, 2010 | Tascam CC-222mkIII CD Player / Recorder
Can't finalize after recording, disc error
Mar 04, 2010 | HHB BurnIt CDR830 CD Recorder
Anytime I try to record with my HHD BurnIT cdr 830, the red record light will only be bleeping and the time counter will not work as well. And there will be nothing recorded on the cd.
Just a guess, but did you ever try to hit the record a second time once you're all set up to start? The first press of the record button places the machine in record/pause mode after it calibrates itself to the disc.
Jan 19, 2010 | HHB BurnIt CDR830 CD Recorder
Cannot use the finalize function anymore
they wear out have it serviced and cleaned
Nov 05, 2009 | HHB BurnIt CDR830 CD Recorder
HHB-830 CD TRAY does NOT open.
It's made for HHB by Pioneer, you could try one of their agents?. Opening up is fairly straightforward if you are methodical and take your time if you need to. There is a test mode sequence you can try - hold down the 'menu/delete' and 'auto/manual' keys together for 5 seconds until the display blinks all the lights then press the stop button. Now ONLY press the open / close button - pressing any other keys will change settings and without the service manual you won't know what you're changing. Press stop then power it off to exit.
I can email you the service manual if you need it. It sounds like a gear has come loose inside to me. I strip these machines for parts quite regularly so may be able to help you out if you're able to work out what if anything is broken but I'm in the UK. It may be as simple as a belt has come loose :-)
Feb 28, 2008 | HHB 830 Plus CD Recorder CD Player
HHB BurnIt CDR830 CD Recorder Logo
32 people viewed this question
Top HHB Audio Players & Recorders Experts
John
John
darren dillon
Level 1 Expert
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
