Question about Whirlpool Dryers
I am getting a cabrio dryer today and i have a regular home outlet where my last dryer was, can i use the old cord on the new dryer
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on Sep 12, 2010
Bought GE Washing Machine but have 4 prong outlet
get in an electrician to fit the correct plug to suit the outlets
May 22, 2017 | GE Washing Machines
Need another cord to put on dryer as my home does not have the large outlet; only a 3 prong outlet. Can this dryer have a new cord put on?
Yes. Putting on a new cord is simple. There is a plate covering the cord that is on there now. Remove the two or three philips screws holding it on. Get a new cord at an appliance store. Use a nut driver to detach the old cord. Hook up the new cord with the colored prongs in the same places as the old. The green will be the one that is missing. Replace the green screw so it is not lost. Be sure to install the cord protector so the sharp edge does not slice through your new cord. Good luck.
Apr 06, 2011 | Roper REX4634KQ Electric Dryer
How do you connect the LG DLEX5101V Dryer to the electrical outlet on the wall if there is no cord to plug in?
There are a couple of types of plugs in homes - and the dryer manufacturer use this excuse to not ship a cord with the dryer - profiting that much more. You'll need to purchase a cord set for your dryer. Assuming you live in the U.S., that means you need a 30 amp 240 volt cord. That's easy enough, but it does get harder.
Most homes have an outlet that has three slots in it - like the one below:
A 240 volt, 30 amp, 3 wire dryer plug.
New homes have a safer, 240 volt 30amp 4 wire plug. They look like the one below:
A 240 volt, 30 amp, 4 wire dryer plug.
The code states that when a dryer is purchased it should be connected via a 4 wire cord. This means if you have the older, 3 wire outlet - it will have to be changed along with the entire length of cable between the electrical panel and the outlet (the new outlet needs a 4 wire cable - the older plug was supplied by a 3 wire cable).
Those are the rules. Many people opt to purchase the older 3 wire cords so that they can connect directly to the 3 wire outlet already installed in their home. As an electrician, I have to caution you on doing that. It is a violation of the electrical code as it has been identified as an unsafe condition. The code hopes to rectify this by slowly requiring new dryers to be wired with 4 wire cords and making the homeowner upgrade the old 3 wire outlet to a newer, safer 4 wire outlet. Of course, no one will come to see what you had and if you changed it, etc.
Mose hardware stores, Home Depot, Lowes, etc. sell these cords for under $20. Make sure you choose a 30 amp dryer cord - and not the similar looking but thicker 50 amp stove or range cord.
I hope this helps & good luck! Please rate my reply.
Mar 22, 2011 | LG Dryers
Need wiring diagram for electric cord attachment
Wiring Option1: Wiring Option2: OLDER HOMES AND ELECTRIC DRYERS NEWER HOMES AND ELECTRIC DRYERS range%203-wire_cord_connection_250.jpg range%204-wire_cord_connection_250.jpg
NEMA 10-30R 30AMP-125/250VOLT
NEMA 14-30 30AMP-125/250VOLT
This system can be configured depending on what your wiring situation is.
For example you could be faced with the following situations:
converting an old 3-wire outlet
to a new electric dryer
converting a new 4-wire outlet
to an old electric dryer
Feb 01, 2011 | Amana ALE643RB Electric Dryer
The electrical outlet does not match with my dryer cable, so I get a new set of wire from home depot to match the wall outlet. how do I hook it up?
Hello, welcome to Fixya,
If you'll notice the new cord has 2 hot (red & black) a neutral (white) and ground/earth (green) wires. In case you are not sure how to connect I've attached a photo which shows the correct way.
Thanks for visiting "fixya" and good luck. Please take a moment to rate the solution I provided for you here today.
macmarkus :)
May 24, 2010 | Amana NED5500TQ Electric Dryer
I am changing the 4 wire on my 2 yr old maytag dryer to a 3 wire to fit the recptical in my new house. Other then the 2 hots and 1 neutral connection, my dryer also has a white ground wire off to the side,...
So you have an, ahem... problem....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
At this point - you have two choices....replace the wiring from the dryer's breaker to the receptacle with all new 8/3 with ground romex (it more then likely only has 8/2 with ground now)....and replace the receptacle with a 4 prong grounding receptacle to match your dryer's cord....OR - as an alternative - you can replace the cord on your dryer with a 3 prong cord to match the existing dryer receptacle outlet.
Out of the 2 choices....the first one will bring the old wiring in the home up to current Codes (all NEW homes must have this 4 wire/4 prong set-up per Code...but older homes are grand-fathered)...but it is clearly the most involved, time consuming and most costly approach...and it is recommended only an electrician do this work. If this approach is taken....your dryer cord can stay as is...it will now fit the new receptacle outlet with no modifications.
The second approach - is to pick up a 3 wire 3 prong cord at your local hardware store to match the existing 3 prong receptacle.....and replace the 4 wire cord on your dryer with it. Although this is the least desireable - it is an allowed approach because this is an older home with existing wiring. This is a much less involved approach...all you need to buy is the 3 wire dryer cord (they come all ready to go) remove the 4 wire cord and install the 3 wire cord to your electrical connections at the back of the dryer. Hopefully...when the 4 wire cord was installed on your dryer, the ground strap wasn't removed completely (this is a metal strap that will connect the white wire to the metal frame of the dryer)...because now you will need to re-use the ground strap. For more on this....see the images of the differences of the 3 wire and 4 wire dryer hook-up at:
http://www.applianceaid.com/general.html#3to4
NOTE: the only real difference between the 3 wire cord and the 4 wire cord is now the white neutral and the ground are kept seperate in a 4 wire..the green ground will connect directly to the dryer frame....where in a 3 wire there is no seperate ground wire - ground and neutral are one and the same...the ground strap connects the frame to the white neutral. The 4 wire permits a better safety measure...in the event of an electrical problem (ground fault) in the dryer...the fault now has a seperate path to your panel's ground...and less chance of a shock from touching the metal frame of the dryer.
The choice of how to proceed is up to you....if you go with completely updating the dryer wiring from the breaker outward...I recommend an electrician do this work for you (it's about an hour's work...plus materials). Then your exisiting dryer's 4 wire 4 prong cord can stay as is....the electrician will install a 4 prong receptacle made to fit your cord.
If you go with simply replacing the dryer's cord....changing it to a 3 wire so it will fit the receptacle...make sure the ground strap is re-utilized as seen in the images at the site above.(also make sure all work is done with the dryer breaker (or fuse if a really old home) off before starting any work. If you change the cord yourself...make sure to reconnect in exactly the same manner as the previous cord was connected...(make a note on paper or take pictures so that there are no mistakes)..and that you tighten the nuts securely to the posts once the wire lugs are on them. Where you state you do not have a background in electrical work...you can have an electrician change this cord for you...(typically in under a half-hour)....or you can do it yourself - by carefully following the pictures.
The choice is yours...if it was me - I'd change the wiring from the breaker outward...making the older home meet today's current Codes and be complaint for this dryer..and then you wouldn't need to change a thing on the dryer....but you can go either way....Codes allow this grandfathering in older homes with existing wiring.
Feb 19, 2010 | Dryers
Need to replace existing three wire plug with new four wire plug. there are only three terminals to connect to. what do i do?
Based on your description....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
Feb 08, 2010 | Dryers
Changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Jul 23, 2009 | Dryers
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Raplacing the dryer cord coz my new home has a different socket
If you remove the cover plate on the dryer directly where the cord is entering the dryer.........If there isn't access there ,I could help you through it but first need a model number.
Jun 20, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
44 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
