Question about Psion WORKABOUT PRO
Went into suspension mode
Was showing employee how to turn unit on and off and as i shut it off it went into suspended mode??? and now will not turn back on
Gold down the blue red and left scan buttons till the screen goes into boot menu. then press 1
Posted on Jun 15, 2009
When i try to suspend my pc, my motherboard gets f3 error and then restarts. The model is an old abit ab9 pro. I recently changed the ram and my os. The os runs perfectly.
have to select suspend mode s1 or s3 in BIOS power management to check the support mode, also check with hibernate, also need to free space in hard drive system partition for hibernating
Sep 11, 2016 | Abit AB9 Pro Motherboard
First time charging up of archos 5,it has now been charging for about 14-15 hours. but the green light did'nt blink yet. it says after fully charge, the green light blinking. what can be the promlem about...
@wilkerwkocer
On an Archos, battery is fully charge when the CHG LED light is flashing, while that light is ON all the time, the unit is still charging.
Now, in order to charge your Archos you must leave it on Suspended mode, by holding the Power button for about 4-5 seconds until it says "Suspending", DO NOT leave it on completely "Shutdown" mode, or your battery will never charge, and you are also risking the life of your battery by doing so.
So in other words:
1) On a PC via USB it should take around 8 hours to charge, while connected to an Archos mini dock, battery dock, or DVR Station, it should take around 3 hours to fully charge.
2) Leave your unit completely "Shutdown" (hold the Power button and wait 10 secs. or so until it says "Shutting down" and let it go off.
3) Connect it to your power source, either USB on computer, or external charging device as mentioned above, it will come back on, the two LED lights CHG and Power will come on, leave it like that, and after a few minutes the unit will go into Standby/Suspended mode by itself, and there is when you are charging your battery the right way.
3) Wait 8 hours if connected to your PC, or 3 hours if connected to an external power supply (as described above). If still after being in suspended mode (not completely off) your CHG light isn't blinking after the 8 hours on PC, 3 hours on external power supply, then suspect your battery is defective.
In that case, if the unit is still under warranty contact Archos, if it is out of warranty. If it isn't under warranty, you can buy a replacement battery on eBay and either replace it yourself, or find someone with the technical skill to do it for you.
I hope this helped you.
Mar 11, 2010 | Archos Internet Media Tablet MP3 Player
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
The computer doesn't turn back on after hibernating or suspension. it lights up for a minute and then the screen becomes blank, but the power light remains on.
Try going to the bios settings(when the computer first comes on after being shut down and shows the brand logo and will say something like press delete to go to setup) and look around in the options to see if you see an option to change the suspend mode or something like that to S3 resume.
Oct 19, 2009 | HP Mini 1000 Netbook
Sana e280 frozen screen reads Refresh Database
put the player in recovery mode by placing the hold slide button at the top of the player so that the red showes, held down the record button while turning on the player. upon connecting the USB cable the unit will go into the recover mode. Go to my computer and look for the drive which states "16MB Format" and copy the firmware files into it. Disconecting the cable after the files are copied will cause the player to reload the firmware. The player will restart and then shut off because of the Hold button position. Slide the Hold button back into normal mode and push the menu button to restart. The unit will power up and display the language settings. I went to the settings menu and changed the player USB setting to USC. I then placed the player in recovery mode again and went to the MY Computer again and set window to show hidden files. This allowes windows to see the database drive. I then ran chkdsk on the database drive which found a lot of crossed linked files. This then allowed me to delete all the files in the database. Upon comming out of the recovery mode the unit restarted normaly.
You can get the firmware at this site. http://mp3support.sandisk.com/firmware/e200/e200v101.02.18a.zip
Oct 11, 2008 | SanDisk Sansa E280 MP3 Player
Window resume loader
Windows Vista doesn't shut down the machine by default when you press the power button. Additionally, if you look at the bottom of the start menu you'll see this:
The button on the left, highlighted here in bronze, does NOT turn the machine off in Windows - it suspends it, which requires power. When the battery runs down, the power goes out and you get this message the next time you start up.
Some laptops also indicate suspend mode by flashing the power light.
Happily, if you click on the little right facing arrow a menu pops up, one of the options of which is "Shut down" and this will bring Windows down properly and fully.
You can also change the function of the power switch (which defaults to suspend, NOT shut down) by going into the power options from Control Panel:
Selecting one of the above options will allow you to set the power button and closing the lid to turn the machine off fully, not suspend it.
May 27, 2008 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Can't get PC out of Suspend mode
Please press The same Suspend Button
Feb 29, 2008 | Computers & Internet
It won't turn on!
Flashing green battery means it is in suspend mode. Pushing the power button should bring it out of suspension, however, one of the reasons I deactivate both suspend and hibernate mode is because the seldom work right. I would disconnect your A/C power cord and remove your battery from the laptop. After about 30 seconds plug them back in and your commuter should start again. Let us know how things go.
Dec 31, 2006 | Averatec 3200 Notebook
Psion WORKABOUT PRO Logo
223 people viewed this question
Top Psion Computers & Internet Experts
Lee Michel
Level 1 Expert
Are you a Psion Computer and Internet Expert? Answer questions, earn points and help others
