Question about Lexmark X2600 InkJet Printer
I changed my ink cartridges (x2600)and now when i try and print i get a cartridge stall message. Also the letters J and E flash seperatly where the number of pages would appear. I tried taking the ink cartrdidges out and same problem
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 7 Answers
I had the same problem. E J kept flashing. My black cartidge on the left side wasn't set correctly. It was a refill from a store an was smaller and looked different than the color . It was blocking the ink carraige from moving. I took out the black and pushed it back as far as possible. Now it works fine. Hope it works
Posted on Sep 02, 2010
How do I get my Lexmark X2600 to print? I got a message telling me that I would soon have to replace the black ink cartridge, and it just stopped printing. I put a new cartridge in, and it still will not...
Try to re-seat the cartridges into the printer. Remove both cartridges from the printer > re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds > when the printer printer turns on, firmly re-insert the cartridges into the printer. Try to print a document again to verify that the problem is fixed.
You can also try to manually clean the cartridge nozzles. Wipe the cartridge print nozzles with a slightly moistened soft cloth to clean it from possible dirt and clogs. Re-insert the cartridges and try to print a document again.
Oct 23, 2011 | Lexmark X2600 All-In-One InkJet Printer
Im trying to print a black and white document but it wont let me print because my color cartridge is missing
The Lexmark X2600 requires both cartridges to have ink in them to continue printing, even if your printing in "black and white". To print true black, you actually use some of the color ink. , Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality issues.
Sep 22, 2011 | Lexmark X2600 InkJet Printer
Lexmark x2600 i have ink and ervything my paper isnt jammed but everytime i try to print the button next to the X button keeps blinking orange
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
2. Open the printer cover and remove both the cartridges.
3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check the light status.
8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
10. Load some paper. Try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 21, 2011 | Lexmark X2600 InkJet Printer
Flashes E C . both printer cartridge lights flash, I just replaced both ink cartridges , and it willnot print. I tried replugging in everything.
Make sure you are using the correct cartridges for your printer and that they are inserted in the correct cartridge slots (14 black in the left carrier and 15 color in the right carrier). If error continues, try to insert different known working cartridges to determine if the other is faulty.
Apr 08, 2011 | Lexmark X2600 InkJet Printer
Lexmark x2600 is blinking ej
The EJ error on your printer indicates that your ink cartridge carrier has stalled. Open the printer cover and clear the mechanical jam, then press the power button. Try to reseat your cartridges and make sure it's properly inserted in the carrier.
Apr 04, 2011 | Lexmark X2600 InkJet Printer
What are proceedures for replacing print cartridges for Lexmark X2600 ink jet printer?
Perhaps the Lexmark X2600 User's Guide will be able to help you. To download it, click on this link: http://www.lexmark.com/publications/pdfs/2007/2600/v7649663_en.pdf. Scroll to Removing used print cartridges, Page 45, for instructions on how to replace print cartridges.
In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source. Hope this helps.
Jun 11, 2010 | Lexmark X2600 InkJet Printer
How to refill a lexmark x2600 black ink cartridge?
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Nov 05, 2009 | Lexmark X2600 InkJet Printer
Lexmark X2600 printer will not print in black and white
you may check your only black ink cartridge
longer time less using cause ink chanel(holes) dryer, could not print out even refilled.you may take out the ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 -2 Hrs, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Feb 06, 2009 | Lexmark X2600 InkJet Printer
Print cartridge in right stall not supported
Are these genuine HP ink. If not try using Original ink.
If its already the original ink then check the Exp date of the ink and try cleaning the copper contacts of the ink ( not the nozzles ) of the ink and the printer
All the best
Sep 24, 2008 | HP PSC 2410 All-In-One InkJet Printer
Lexmark X2600 InkJet Printer Logo
70 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
