Question about Frigidaire FDL45P1 Dehumidifier
Frigidaire MDD40WW2 dehumidifier turns on and compressor come on... the coils seem cold but no water come out
  • 828 Answers
Your dehumidifier may be low on refrigerant. Seems cold may not be cold enough to reach the dew point to condense moisture from the air stream.
Posted on May 11, 2008
Why does compressor continue running, even with dehumidifier turned off?
Hello Bernard, thank you for your post!
I see that you are experiencing an issue with the Frigidaire dehumidifier, FAD704DWD, compressor consistently being on. This could be a possible issue with your control panel or sensor. Since it could be any one of these underlying issues I would suggest contacting the manufacturer for further assistance. Hopefully this information is helpful to you. -Matt
Feb 16, 2016 | Frigidaire a/c fad704dwd 70 pint...
Dehumidifier freezes up
Good Afternoon Friend,
I understand your Frigidaire dehumidifier, model# FDF50S, is freezing up. I see that the compressor does not shut off, causing ice to build up on the coils, rather than water draining off. What can cause this is your dehumidifier has been turned on recently. This is normal due to refrigerant rushing through the coil. Frost will usually disappear within 60 minutes. Another cause is if the room temperature is too low or too high. Your appliance is designed to operate between 41 degrees F and 96 degrees F. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire FDF50S Dehumidifier
Fridigaire dehumidifier compressor gets very hot and no water in bucket
Good Morning Friend,
I understand that the compressor is getting very hot and there is no water in the bucket of your Frigidaire dehumidifier, model# LAD704TDL. I would check to make sure that your dehumidifier has enough ventilation. There should be a minimum of 12 inches clearance around your dehumidifier. Also, make sure that it is neither too hot, nor too cold where you have placed your dehumidifier. Your appliance is designed to operate between 41 degrees Fahrenheit and 96 degrees Fahrenheit. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dehumidifier status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Dehumidifier LAD704TDL
I have a frigidaire LAD704DUL 70 pint dehumidifier. Last year it worked great. This year, it has not collected any water in the bucket. The motor runs, it is on CO setting but still no water. I have...
If you have a dehumidifier that is not producing any water then you are wondering what you need to do to get this thing to work for you. In some cases you may be able to do something and in other situations there may be nothing that you can do.
If you do not hear the compressor running and the unit says that the humidity in the room is higher then the setting, then you have a problem with your dehumidifier.
A few things that can cause this are:
The circuit board relay has gone bad...replacement of this board will often cost more then a new unit. This also is a very common problem with many dehumidification units.
The compressor has failed...if you hear a buzz for a few seconds, every few minutes, then you have a bad compressor or at least bad start components on the compressor. Either way it again is a costly repair.
If the compressor is running and the coils are not getting cold then you have a refrigeration system leak. Recharging or fixing these units is very difficult and is another costly venture compared to the price of a new dehumidifier.
If the compressor is running but the fan is not, this also will cause low water production and continual freezing of the coil.
If the compressor and the fan are running but the coil is totally blocked then you will get no water production. Air needs to be continually moved over the cold coil to get the water out of the air.
If nothing is running, then you may also have a control board failure. Or the humidity sensor or humidistat has gone bad which tells the machine to run. If the sensor says that the humidity is low enough then it will never run.
Also if nothing is running check the float switch or the bucket switch. Many of these switches are very touchy and if you do not have the bucket in place just exactly right it will not trip the switch to allow the unit to run. These switches often are more fragile then they should be and break easily. The good thing is that when available they are easy to replace and relatively inexpensive.
There are some parts available for a few brands, but with the prices for most of the parts that you can replace running anywhere from 40.00 - 80.00 dollars, replacement parts with labor to install them, makes a repair more then the few hundred dollar cost of many of these dehumidifiers.
As you can see there are quite a few things that can cause your dehumidifier not to work. Systematically go through the list and eliminate things to get to the bottom of the issue causing your problem and then decide if it is worth spending the money to try to fix the old unit. Only you can make that decision.
Aug 10, 2012 | Frigidaire 70-Pint 2-Speed Dehumidifier...
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
Need a repair shop in the baltimore area to look at my dehumidifier runs but wont pull water
It's cold outside. If the temperature is too low, the cold coils will just frost up and you won't get much water 'pulled'.
Check to see if the cold coils actually are getting cold when the unit is running and the control is set to cause the compressor to work-not just the fan.
If the coils are cold and full of frost or ice, the room is too cold for the dehumidifier to work. You'll have to raise the temperature of the room or wait for warmer weather.
If the coils never get cold, the compressor might be bad or the unit might have lost its freon.
I wonder, though, if it's just too cool and dry right now for a dehumidifier to be pulling more moisture out of the air.
Hope this helps!
Jan 01, 2011 | Haier Dehumidifiers
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
Machine works, but no water collecting
A dehumidifier is basically a cooler. The condenser coil on the outside should feel cold to the touch usually around 34 to 38 degrees, as air passes over the coils they collect the humidity in the air and it then drips down into a collector tray. If the coil does not feel cold it is ether a bad control switch not letting the cooler (compressor) turn on, low on freon, or burned out compressor
Oct 07, 2009 | Haier 45-Pint Dehumidifier
Year 2005 cycling fan and compressor
Your unit is probably operating in defrost mode. When you use a dehumidifier in a cold room, the condensing coils can freeze water. The unit senses this and thus stops the compressor until the water frozen on the coils melts. Then it resumes its cycle. This is a problem you will have during the winter months. It makes the operation of the unit inefficient, but this is otherwise normal behavior.
Jan 04, 2009 | LG LD50EL Dehumidifier
Running but not collecting water...
Dehumidifiers have only a few components, and operate on the same principle as a refrigerator, freezer, or air-conditioner.
Components Residential dehumidifiers have a cooling system made up of these primary components:
  • The compressor is the quiet motor (engine) of the cooling system. It's the black, football-size component at the bottom of your dehumidifier. The compressor runs as long as the dehumidifier humidistat (the humidity-sensor) calls for a reduction in the humidity.
  • The condenser is a series of finned tubes, similar to a radiator. It's usually near the circulating fan.
  • The evaporator is located near the back of the dehumidifier, right above the water-collection container. It also resembles a radiator or a coiled-up set of tubes. When the dehumidifier's humidistat senses increased humidity, it cycles on, which starts the compressor and circulating fan.
  • The circulating fan circulates the air over the evaporator and condenser coils.
Principle When the unit runs, the circulating fan and compressor also run. The fan continually draws room air over the evaporator coils, which are cold, and then over the condenser coils, which are warm. Because the evaporator coils are cold, the moisture in the room collects on them--just as the outside of a glass of icy liquid "sweats" on a warm, humid day. When the moisture on the coils increases, it drips off of the coils into the collection container.
The air then flows over the warm condenser coils and out into the room. This process removes water from the air and, because of the heat from the fan motor and compressor motor, the exiting air is somewhat warmer, as well as dryer.
Jul 29, 2008 | Maytag M7DH65B2A Dehumidifier
Dehumidifiers Logo
717 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
richie46
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
