Question about HP LaserJet 5550 Printer
Hp 5550 dtn 10.00.00 supply memory erro
Hi my machine has a 10.00.00 supply memory erro message can you tell me what is wrong with it please.
Regards
Peter
  • 21 Answers
The chip is faulty on the black cartridge, change the black and it'll work, alternately you can out it diagnostic made and run without the cartridges being monitored
Posted on May 11, 2008
My HP 5550 dtn has been "initializing" for 5 days? Is there any fix?
Might be a simple as a bad memory expansion or might be a failed formatter. After 5 days it is not going to start without intervension. YOu need to remove the formatter and if there is a memory expansion in the dimm slot, remove it and then reinsert the formatter and start the printer again. Never remove or install the formatter with the power connected. Formatter is the board that the network or USB cable plugs into. There will be either two black handles that slide to release or a bunch of screws around the outside edge.
Nov 14, 2016 | HP Office Equipment & Supplies
How do i fix my hp5550 error supply code 10.10.00
Here is the HP Laptop Technical Support Number 1-844-355-5111 (toll-free) to fix hp 5550 error code by expert technicians.
HP Laptop Support Number 1 844 355 5111 Laptop Repair
Apr 05, 2016 | HP Office Equipment & Supplies
Hp laserjet m1522nf 10.1000 supply memory error
Most likely the Orange Clip that surrounds the sensor contacts on the front edge of the cartridge was not removed. Open the machine, look at your cartridge, make certain that any clips or protectors are removed, clean the contacts if in doubt and reseat the cartridge... your problem should be solved.
Aug 16, 2012 | HP Laserjet M1522nf All-in-one Laser...
HP Colour Laserjet 5550dn. Once switched on it goes through memory check; display lights and hp logo on display screen. Then displays on screen "Initializing . . ." Doesn't go any farther - just...
i hope that the problem is not in some of your printer boards, but i have to tell you that you have to expect problems with POWER SUPPLY BOARD or FORMATER BOARD. Please call service for help
pifonski
Apr 19, 2011 | HP LaserJet 5550 Printer
Memory Supply Error 10.00.00 The printer is unable to read or write to the print
cartridge e-label, or the e-label is not on the cartridge.
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector
Contact a local HP Authorized Service Center for further assistance.
Aug 03, 2010 | HP LaserJet 5550 Printer
HP color lasejet 5550 dn does't print. Is this message: 10.00.03 supply Error memory. Can you help me Thank's
hello
You could try with different cartridge try to clean the contacts , check wether the cartridge is seated properly , make sure weather the strip is removed from the cartridge
OR
If you use a HP original cartridge, then you shouldn't have this message.
Anyway you can print, it's only at startup that this message appears.
If it is a HP toner, then change it.
Or
try this link and you will find answers for all your printers errors
http://www.all-laser.com/cgi-bin/webc.cgi/error-code.html
Mar 05, 2010 | HP LaserJet 5550 Printer
10.10.00 supply memory error coming on HP Laserjet 5200 Printer.
Dear Sir,
I has change the printer cartridge. After changing the printer cartridge above mentation comming. When I am making printer power on the (10.10.00 supply memory error) display. Please tell me how to solve this problem. Best regards,
Thanking
Ajom Khan Hero
Mobil No.092 5192797.
Al Nahr Co.Ltd
Tripoli - Libya
Jun 17, 2009 | HP Hewlett Packard LaserJet 5200 Printer
Adding IP addresses to a HP 5550 DTN printer
ok then install that printer as a network printer to one pc share ti and ad to as much pc you need after that without ip adress
Dec 10, 2008 | HP 5500 Color Laser Printer With Internal...
First time using my hp color laserjet 5550
We need to start with turning the machine on not connected to the computer.
Disconnect machine from computer.
turn machine on
if locks on memory count 128mb turn off.
If machine has a jetdirect card (network card I/O) installed remove it.
Turn machine on.
If it comes READY you found the problem.
If you are not using on network reconnect to computer and try again.
If there is no network card let me know.
hope this helps
Aug 28, 2008 | HP LaserJet 5550 Printer
HP LaserJet 5550 Printer Logo
1,876 people viewed this question
Ben Johnson
