Have HCL552W and after normal operation for 1-2 hours TV screen flickers briefly and then goes to blue. Audio disappears (no noise). Turning the TV off and back on usually solves the problem for another few minutes. Do I have a bulb problem or some other component going bad (temperature sensitive)? TV is in cool basement and cable is not the problem (TV does same thing while watching DVD).
  • 11,800 Answers
No, no bulb problem. And the fact that the tv works just fine before and after this happens that means that no actual part is faulty.
The image turns blue when the tv signal is missing - which means that you have a faulty connection between the mainboard (the part that holds the tuner and all the inputs and the associated circuits) and the image board, the one that converts the signal in a format that is usable by the CRT. Since it appears to be heat caused then you should open the tv, find where the boards heat the most and check every wire and soldering, every connector and every jack and reseat or resolder the iffy ones.
Posted on Aug 31, 2010
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Vizio start blue/yellow flickering screen
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 01, 2017 | Vizio VW42LF 42 in. LCD HDTV
Samsung HLR5067W: Screen goes black - Audio Remains. Several months back my 5 years old HLR5067W started displaying the following behavior: - Launches OK - After running for a while (anywhere between...
When was last time you replaced Lamp? Ballast Board is what powers the lamp on.
Lamp Fan, if it is defective it will shut lamp off to protect it, if it is Not cooling the Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Encompass Parts Distribution has 10 Ballast Boards in Stock for $68.96 they also list Service Manual Free for this Model# 1-800-638-3328
Nov 03, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Hourglass picture. Panasonic CT-35G30T The picture is hour glassing from the sides. Starts to flicker back to normal after 1 to 2 hours. Getting progressively worse. Takes longer time to reach normal...
This is caused by bad solder connections in what's called the pincushion correction circuit. Some of the transistors get quite hot, and over time the solder connections to the TV circuit board become intermittent. When you tap the set, it causes them to make contact again so the picture is normal, but then it goes funny again. Resoldering the connections would take care of this problem. I would suggest calling a professional in to make the repair, which would cost far less than a replacement TV.
Hope this has been helpful, and thanks for using Fixya!
Feb 01, 2010 | Panasonic Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Jan 28, 2007 | RCA F27650 27" TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
