Question about Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum
Just stopped running. Is there a reset button
  • 3 Answers
I think there is one at the very bottom...try that little black colored one at the the side facing you, when operating, near the very bottom of the unit..I lost my manual too, so that would be a guess since it looks like a reset button.
Posted on Oct 04, 2010
Tristar exl powerhead reset button won't reset
You should take it to your local vac shop for diagnosis. It may have a bad breaker, but it could have something else wrong. The way to tell if the breaker is bad without a meter, is to connect the 2 wires together and see if the motor runs. BUT BEWARE, if you do this and the motor is binding, it could burn it up. Again, the best thing would be to take it to a professional.
Feb 20, 2015 | Tristar Vacuums
Roomba 560 fully charges. Runs for 2 seconds fully green and just stops. And lights up red.????
Set him on the floor, after powering him off and then back on, and press the "Clean" button three times. This will reset him.
Sep 11, 2014 | iRobot Roomba 560 Robotic Vacuum
Panasonic vacuum cleaner just stopped running
Set the on/off switch to off, now check near the top of the "beater" portion, I think that model has a reset button, you should hear a slight "click" when depressed. Try turning the vacuum back on.
Aug 26, 2014 | Panasonic MC-V5217 Vacuum
The reset button is internal. If it overheats it will shut off but will come back on when it cools down. This usually means you have a clog somewhere or a clogged bag or filter. If that doesn't take care of it have it checked by your Riccar dealer.
Mar 30, 2014 | Riccar 1500. 1700, 1800, Pristine,...
Dyson DC17 stop running unplug let cool still won't turn on, is there a reset
yes there is if you unplug from wall socket then press start button very hard it will reset .
Dec 27, 2013 | Vacuums
The carpet sweeper on my electrolux stopped working....used it for a little bit and then it just stopped
Make sure the brush is cleared and clean, press the reset button, and try again.
If the motor runs, but the brush doesn't turn, it's likely due to a broken belt. Have it replaced by someone who knows what they're doing.
I strongly recommend taking it into an authorized shop.
Dec 04, 2010 | Electrolux Vacuums
Brush roller has stopped turning
look on the bottom of the unit for a small reset switch button.I have not worked on this unit but many are similar. If you can hear the roller motor running you may need to replace the belt
Sep 06, 2009 | Euro-Pro EP601 Bagless Upright Cyclonic...
Brush won't turn
The Agitator Overload switch is located on the top of the base assembly. Unplug the vacuum and press the reset button. The vacuum also has thermal protection, which will reset itself once the vacuum cools. The agitator will also stop when the vacuum is in the full upright position.
35922 Owner Manual
Feb 08, 2009 | Kenmore 35912 / 35913 Progressive Upright...
The vacuum stopped running and won't turn back on?
While there's no reset button it's not uncommon for the internal thermal switch to trip to an "open" position. This internal, no-access-switch opens when the motor gets hot, it protects the motor from overheating to the point of failure. Bissell's website states that if the thermal switch is tripped let the vacuumm sit for a half hour and then it try it again.
If it doesn't work you might then try Tech610's suggestions.
Dec 08, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum Logo
501 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
