Question about Berk-Tek HYPER+plus Cat5e Bulk Cable 1000 Ft plenum (BERKTEKHYPERPLUSPLENUM)
I need to make a 600' ether net run what can I do ?
    Champion:
  • 331 Answers
Can't be done. You can run up to 300' if your cable is perfect. You would need to install an ethernet bridge (or hub/switch) at the 300' mark to make this work.
Posted on Sep 02, 2010
93 fzr 600 r
poor spark , low compression , carbs clogged up fuel tap not operating correctly.
Mar 18, 2014 | 1993 Yamaha FZR 600
Will a stuck float make a yamaha xt 600 hard to start?
needle and seat are leaking most likely from a pc of junk stuck between em.
Jul 16, 2017 | Yamaha XJ 600 Motorcycles
No start with out ether
There are to money things to look for, We need to get DTC codes from your ECM and hope that will shine some light at the end of the tunnel.
Here is a link on how to retrieve the DTC codes, after you have the codes if any there is also a link on the web sight to your year and engine type for the DTC codes.
Good luck and keep me posted, be glad to help you. Just don't like the guessing game. http://www.troublecodes.net/GM/
May 30, 2009 | 1993 Chevrolet Astro
Canon ImageRunner 3030: connecting scanner to network
Do you hvae a ether net PCB installed on it ? It is normally a option. You need the right boot rom and ether net pcb first
Feb 08, 2008 | Office Equipment & Supplies
Need help with getting madden08 online
Well 1. you need a router
2. if you read the instructions with your ether net you are not supposed to plug into the one side ((BAD NO NO )) trying to run it through your pc is a pain cuzz the stupid format disk does not work on your pc... easy way use the dial up cuzz they want you too use on of there service providers or call your dsl provider for your login and password stuff... i run mine with a differnt ether net box i got from my cable company so i can share my dsl ip address and connection ..its a pain i would start with your service provider first.
Dec 13, 2007 | Sony PlayStation 2 (PS2) Console
Motorola SB5101
ya u should have a router instead of a modem because modem provide only one ip address>and there is no DHCP server in the switch or hub>so buy one router which has 4 ether net port and connect it directly to the modem and connect ur two pc's behind the router then both will get a seperate ip address from the router both will go online
the connection is
modem-->ether net cable to the inter net port on the router-->and two ether net cable from both pc's to the 1 and 2 ether net jack on the router reboot all the devices>and modem+router+pc's then it will work>rate me solved if its helps thx
Nov 14, 2007 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Can't connect to the Internet
iam workinh for vonage and so its ur phone working then change the ether net cable>and and delete all the temp files and cookies and clear history>and also if still its not works change teh ether net port bet ween the pc to teh vonage devie>and still if its works then u need to check with the ether net card driver or ether net card>rate me solved if its help full
Oct 31, 2007 | Arris WR850G Router (DHWR850G)
Wireless router
modem to inter net or wan port on this router>and u have 4 ether net od lan use any one -->ether net cable to pc's>and if u r using cable inter net then reboot the both router and modem u can get inter net access if its dsl contact linksys cause need to configure teh router rate me solved if its help full thx
Oct 29, 2007 | Linksys EtherFast Cable/DSL VPN Router...
Computers & Internet Logo
70 people viewed this question
Top Berk-Tek Computers & Internet Experts
David Payne
David Payne
Are you a Berk-Tek Computer and Internet Expert? Answer questions, earn points and help others
