I have a belkin router i am having trouble connecting it. i dont know where to connect the ethernet cable. Does it go the computer or the modem?
  • 3 Answers
Actually the Belkin router goes both ways, First connect your computer to the Belkin router into port 1, configure it following the manual, Second connect your modem to the Belkin router into the Internet port.
Posted on Aug 31, 2010
  • 629 Answers
The ethernet cable should be connected to the ethernet port of the router to the ethernet/network port of the computer. you will also need to connect a cable through the router and the modem, then a phone cable from the modem to the phone line.
3 Suggested Answers
  • 95 Answers
SOURCE: i have a belkin router
Hi
First you have to connect the telephone line to the integral modem and then using straight through cable to connect the computer to the modem.
Jyothish
Posted on Jul 18, 2008
bizelski
  • 118 Answers
SOURCE: trying to set up wireless
Check that the wireless drivers are installed properly on both your laptop and desktop. THe certificate error is because your laptop does not "trust" your computer. Under network conections click add a connection ec, and when you try to conect, microsoft should ask you weva to trust the connections from computer to computer that should do it :D
Posted on Sep 07, 2008
Haw can i install Belkin wireless router N300 without the CD
1- Let us connect a modem to the WAN or through a port of a modem of a Belkin router.
2- Now plug into a modem & a router with a power source
3- After that it requires your PC system with any one of its LAN or an Ethernet port of a Belkin router. Remember, if a user is connecting as wirelessly then it first need to connect via the Ethernet Cable.
4- At last, in the upper panel of a device. Customer can easily observe the LED light of your Belkin router. Need to wait for 10-15 minutes for turning the LED light into totally solid blue.
5- Verify the Belkin router connections are properly connected to a modem and an Ethernet cable.
6- Now power cycle the modem by getting unplugging it through the power point and then again wait for a while. After a 15-20 minutes, plugged it back to its power source.
7- Power cycle helps a user to re-connect or established the strong communication with a modem and a Belkin router. Thus, the method is now completed for how do I setup a Belkin Router without CD.
for more checkout...
How to Setup Belkin router Install Belkin Wireless router
Apr 10, 2012 | Belkin F5D7234-4 Router
I dont know how to connect a belkin wireless router to thr rca modern router?
You will need 2 ethernet cable to set it up Tha first one will go from the ethernet port in your cable modem to the ethernet port of the router mentionned Modem. The next cable will go fron one of the port of the router to the ethernet port of your Computer,
This second cable is placed temporarely to be able to do set the routers settings,
After this is done insert the Cd that came with your Belkin router and it should guide you through the different setting pages of the router.
Jul 25, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
How can router, cable modem & Vonage modem be connected
Connect the Cable Modem - > The Vonage
Then Connect the Vonage -> The Yellow or Green Slot of the router
Connect your computer -> The Grey slot in the router
Run the Setup
Dec 11, 2010 | Belkin (F5D7231-4) Wireless Router
Got a new computer I forgot my log in to acess the router since it is protected how can get it reset?
Trouble Shooting Steps to by pass the login password
STEP 1: You can by pass this Screen by resetting the router for 30 seconds with the power cable alone connected to the router. You can find the reset button to the right side of the power connecter. And all the settings on the router will be lost and you need to reconfigure one by one again. That is the only solution for this problem
STEP 2: Then connect modem to the router using an ethernet cable one end of the cable on the actual modem and other end in the belkin router on the yellow slot or isolated slot called as "Connection to the Modem"
STEP 3: Then take a second ethernet cable and connect from the router wired slot in any like 1,2,3 or 4 and the other end of the same cable to the computer
STEP 4: And run the Setup CD o setup ur Router again
First you should know your internet service provider details like connection type
Connection type may be of Dynamic, Static and PPPoE
STEP 5: After setting connection type check whether the status is connected on the belkin screen on the right top corner and and if connected go ahead with the wireless settings like
Channel and SSID
Security
Kindly refer the attached screenshot. Which will be more helpful for u.
Thanks and Regards,
Nov 06, 2010 | Belkin (F5D5231-4) Router
Setup belkin wireless network
1.Connect a Cat5 cable into the Ethernet port on the back of your cable or DSL modem. Plug the other end of the cable into the "Connect to Modem Internet/WAN" port on the back of the Belkin Router.
2.Connect a Cat5 cable into the "Ethernet" port on the back of any desktop or stationary computers and then plug the other end of the cable into one of the LAN ports on the back of the Belkin Router. Start with port one and work your way up with subsequent computer connections.
3.Turn the Belkin Router on by plugging the router into a power outlet. Allow 30 seconds for the router to fully boot up. All computers tethered to the modem via a Cat5 cable have access to the Internet.
4.Open the Wi-Fi Wizard on your laptop and turn on the Wi-Fi antenna. Once turned on, the Wizard finds all network connections in your area. Connect to your network to establish an Internet connection. Complete this step for each computer not tethered to the Belkin Router with a Cat5 cable.
Thanks for using Fixya
Proton
Oct 04, 2010 | Computers & Internet
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
I have a Huawei EC 168 usb modem from alltel and would like to know if it can be used with my belkin N+ router
inorder to connect to the belkin router you should have an ethernet outlet from the modem...even if it is an usb modem, go ahead and check whether there is an ethernet port...if there is an ethernet port, then connect it to the MODEM port of BELKIN router using an ethernet cable...if no ethernet port is found then it willnot be possible to connect to the belkin router...
because belkin router has got only ethernet port for getting connected to the ISP...
pls rate me if its useful...
Apr 03, 2010 | Belkin Computers & Internet
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
Wireless router problems
Hi Andrew i had the same prob all i did was to connect by hard wire 1st. Connect your modem ethernet cable to your router , then connect your router to your computer again with ethernet cable, When i did this nothing happend at 1st so i unplugged the modem (not router) leave for about 20 sec's then plug in your modem within about 10 secs i was up and running. I hope this helps
Dec 31, 2008 | Belkin (F5D7230-4) Router (587009)
Hard ware problems
HI Barry
You need something called an ethernet cable. One end of the cable goes in the router and the other end goes in the ethernet poet of the computer.
This is an ethernet cable
512c92e.jpg.
This is the network port (ethernet) of the PC
If you dont have an ethernet port on ur pc u may need to pay an ethernet pci card like this and get it installed on your computer
Hope this helps
Cheers
JigSaw
XoXo
Aug 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
