My tv Samsung S42SD YB05 dont want to switch on.The power light is burning on tv.remote got new battery stil wont work.the relay that allways make a click sound when switch on now not working or cliking anymore.Please help.
  • 9 Answers
SOURCE: No picture
try chicking the horizontal section or vedio section...
Posted on Jan 29, 2008
  • 2427 Answers
SOURCE: samsung s42sd-yb05clicking and no power
Its a power problem.. Its deffinately on the sub electronic controll circuit as the set would not have even gained power if it was the main supply.. I suggest you look at defective or damaged components especially capicators.. If you have limited experience on this i recommend you take it to a technocian.. I will tryy to obtain more detailed information for you on the trouble shooting and repairs as well as other stuff that you can try..
if you are looking at the problem look at the relays and the capacitors close to them, Look at the transistors and ic last.. you can use a multi tester and see where the voltage stops, more than likely its that componet or the one before it is bad..
If a relay is tripping ceck to ensure the relay is getting power before it trips. If the relay shows contunity to input voltage but still shuts off its the relay thats bad...
Posted on Jan 13, 2008
  • 1894 Answers
i dont think it as an IC problem... it must be a short circuit occuring somehwere in the board.. and this is ticking is from relay which protects the circuit from the shorting..
so look out where is that bad portion of shorting.. if u r able to isolate it then i think u will get it fixed..
Posted on Jan 15, 2008
SOURCE: samsung s42sd-yd01 plasma television wont power up
i have also this problem 1 relay klikt than must klikt the second relay it do nothing
i see a few elco,s on the visibel boards who are dik the plastik is dik not the metal
to hot maybe
can this give the problems
somewone a solution for this tv ??
sorry for my bad englis
thanks
Posted on Aug 13, 2008
SOURCE: samsung s42sd-yd07
flat screen hisence keeps flsing red and blue but doen not go on until 20 min. can you help
Posted on Dec 15, 2008
Is there a troubleshooting guide for samsung model #s42sd-yd01?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 26, 2014 | Samsung Televison & Video
Samsung s42sd-yb05clicking and no power
Jan 13, 2008 | Televison & Video
Samsung un46f6300 does not turn on
Does the power on led burn?
If not, check if the power cable is inserted in the wall outlet. Check if the wall outlet has any power, by plugging in a lamp or so. Then check if the power cable is correct inserted in your flat panel TV.
Still no light, perhaps the cable is defect. If you have a power led burning on the TV, try switching it on manually, not by the remote.
To check the remote control, use a smart phone or a digital camera. Hold the front of the remote control in front of the camera lens and while the camera is on, press the on / off button on the remote. Look at the display if from the remote control is coming some light. If not, replace the batteries in the remote control. Or if the remote control is new, perhaps you should put in some batteries?
Jun 02, 2014 | Televison & Video
My antitheft light comes on all the time car ticks over but wont start have changed the battery in my car key and it stil dosent work i hav a 207 diesel 1.4
try a new battery in the car if old one is low on power the antitheft device kicks in as thinks its being stolen ,after installing new battery lock an unlock vehicle with the remote and then start as normal
Mar 18, 2014 | Cars & Trucks
How can i know if my starter relay is bad on a dodge stratus 2001
IF STARTER RELAY BAD THE STARTER WONT MAKE NO NOISE AT ALL HEADLIGHTS WONT DIM.IF YOU CLICKING NOISE BATTERY VOLTAGE TOO LOW. MAKE SURE BATTERY VOLTS ARE 12.6 VOLTS AND USE TEST LIGHT TO SEE IF STARTER GETTING POWER.COULD HAVE BLOWED IGNITION FUSE OR FAULTY IGNITION SWITCH. TO CHECK STARTER SOLENOID FIRST TURN OFF RADIO THEN REMOVE NEGATIVE BATTERY CABLE AND POSITIVE BATTERY CABLE.THEN REMOVE STARTER BUY A REMOTE SWITCH.YOU NEED BATTERY JUMPER CABLES HOOK BATTERY JUMPER CABLES TO BATTERY PUT POSITIVE CABLE ON POSITIVE BATTERY POST THEN PUT NEGATIVE BATTERY CABLE ON NEGATIVE POST. HOOK BATTERY CABLES TO STARTER USE NEGATIVE CABLE GROUND STARTER BODY AND PUT POSITIVE BATTERY CABLE ON THE LARGE POSITIVE POST ON STARTER SOLENOID. NOW TAKE REMOTE SWITCH HOOK RED WIRE TO STARTER SOLENOID POSITIVE POST THEN HOOK BLACK WIRE TO REMOTE SWITCH TO STARTER SOLENOID SWITCH TERMINAL WITH LETTER S THEN PRESS REMOTE IF STARTER SPINS STRONG WITH A GOOD KICK STARTER GOOD.YOUR PROBLEM COULD BE CORRODED WORN BATTERY CABLES. WEAK BATTERY FAULTY IGNITION SWITCH. IF STARTER DONT WORK WHEN YOU PRESS THE REMOTE SWITCH STARTER SOLNOID BAD OR STARTER ITSELF BAD.IF ALL IS GOOD. CODE SCAN CAR FOR THEFT SECURITY FAULT CODE.
Aug 28, 2011 | 1999 Dodge Caravan
Wont turn on
The power supply board has been defected. Replace it with a new one.
Aug 15, 2009 | Samsung LN32A330 32 in. LCD TV
Unable to get fan to respond to remote Hampton Bay 54
these fans must be reset as follows remove the battery from the remote manually turn off the wall power switch put the batteries back in the remote turn on the wall power switch press the remote buttons...if this doesn't work let me know
Jun 01, 2009 | Universal Remote Control Hampton Bay...
Samsung s42sd-yd01 plasma television wont power up
to hot maybe
thanks
Feb 02, 2008 | Televison & Video
Intermitten remote sensor issue
Evidently 2 good remotes point at the problem being the remote sensor on the TV itself. I have about 4 remotes I can adjust volume w/ including the remote that came w/ my samsung. The TV exhibits the same behavior w/ all of them.
Per the samsung site, the "test" for this (remote vs sensor) is to us a digital camera, (including the kind that's on most cell phones) to "see" if the remote lights up. Just point it at the camera/phone, and press any button. You should see a bright flashing light on the camera/phone's LCD screen. If not, REJOICE! All you need to replace is the remote or batteries in it. If you do see the light, good luck if you're not in warranty. I've been unable to find any procedures for replacing this kind of item.
Nov 13, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung s42sd-yd07
Sep 05, 2007 | Televison & Video
Open Questions:
Televison & Video Logo
900 people viewed this question
Top Televison & Video Experts
