Question about Goodman Heating & Cooling
When outside compressor kicks in, fan do not start. Needs a push.
    President:
  • 3,773 Answers
Check the fan capacitor Take it to parts appliance parts to check it.
Careful the capacitor will still be hot when it is removed.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 31, 2010
Running or not central a/c
There is a capacitor in the fan wiring that gives it a kick start. Replace it
May 20, 2012 | Heating & Cooling
Outside fan not running, inside unit running fine. Compressor was running this morning, but no longer. Replaced fan motor, turned power back on, now fan or compressor not running. What else can be checked?
There may be a manual reset high limit... look for a red button on a round part hooked to the small copper line and push it in hard...
Also the compressor may have kicked the overload and needs a few hours to cool and it reset, that is interanl insdie the compressor.
Contactor may also have went bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 25, 2010 | Goodman Heating & Cooling
Why does my fan runs continus. and the condenser won't run out side.
The fan runs continously because your condensor is not kicking on and removing the heat. The thermostat needs to come under the set temp. to kick off the fan. If your compressor doesn't run and the fan on the outside unit does run, your compressor has an issue. If nothing runs outside, then your transformer on the inside unit(air handler) has an issue. This could also be a control relay on the condenser or the air handler.
Jan 15, 2010 | Omega Trane Furnace Draft Inducer Blower...
I have pretty much the same problem
THE INSIDE FAN WILL RUN IF YOU HOLD THE CONNECTOR IN, TRY THE SAME THING OUT SIDE FIND THE CONTACTOR FOR THE OUTSIDE UNIT AND PUSH IT IN WITH SOME THING INSULATED SEE IF THE COMPRESSOR STARTS AND THE OUTSIDE FAN COMES ON IF THIS WORKS YOU WILL NEED TO TROUBLE SHOOT THE UNIT
Aug 10, 2009 | Heating & Cooling
Very hot outside. blower comes on but outside fan
Check the voltage source for the fan and compressor
Check the start capacitor for the compressor.If its over heating :bad compressor
Jul 05, 2009 | Carrier 38BRC036 Air Conditioner
Goodman CK36-18: Outside fan kicks on, but
Sounds like a bad capacitor. They can be bad and the fan will still run. Turn off power and check for burnt wires on the top of the contactor going to the capacitor or on the top of the capacitor.. Check terminals on the compressor also. When capacitors go bad they are slightly swollen. They can also look good and be bad . Could be compressor but start with capacitir and wires. IWork on a lot goodman units. Most of the time it is the cap.
Jun 03, 2009 | Heating & Cooling
I have a carrier infinity system. On the thermostat it reads "sens error" where the outdoor temp is normally displayed. The inside unit is running but the outside unit is not. Any suggestions?
A burned or pitted contactor will/can cause a unit to not run. Outside fan. Just thinking out loud. Start with low voltage check at t.stat then check outside low volt. Set t.stat to on. If fan engages at least your transformer is good. Next set calling for cool. Drop t.stat 68-70. If nothing happens go outside and with a screwdriver depress the contactor in. If fan and compressor kicks in change the contactor. If contactor is pulled in check outside fan. Remove the wires from the compressor and see if the fan will run . If it does you have eliminated start components as good. The compressor has to be check. It needs to be ohmed out. Turn off power at disconnect. Pull the cover on the compressor. Check between pins; then pins to ground. Open or infinite is good.Have you checked fuses. Like small 3-5 amp fuses
Jul 03, 2008 | Carrier Heating & Cooling
A/C quit running
This question is really to broad to answer. There are several things that could cause it to stop running. I think I would turn everything off, let it cool down for several hours and try it again. When you kick it back on, take note of what is running and what's not running. Inside fan, outside fan, compressor. If the outside unit will not run at all it could be as simple as a grasshopper caught in the contacts. If you hear the compressor running outside but no outside fan, The fan motor probably needs replaced. Please make sure that all power to the unit is TURNED OFF before removing cover plates on outside unit and before trying to remove insects from contact points. Check all wiring inside outside unit while it is open. Also check capacitors for swelling or leaking. If you don't know how to turn all the power off or open the outside unit, you need to call a professional AC technician. Hope this helps. kstfas
Aug 26, 2007 | Ruud UAKA037 Air Conditioner
Heating & Cooling Logo
22 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
