Question about Maytag MDE16CS Electric Dryer
Timer not. Advanceing - Maytag MDE16CS Electric Dryer
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The timer has gone bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
Need two parts for homelite gas trimmer model number st -145 i need the retainer and the string head and the post can i order on line or do you have a dealer in s.c. i live in spartanburg s. c. also...
You'll probably need to just purchase a replacement head for your trimmer. You can buy one from PartsBuggy.com here. You'll need part #385-580.
Please note: The replacement parts shown when you click the link for the item # are replacement parts for the head being sold and may not necessarily fit the original Homelite head that may be on your trimmer.
Aug 29, 2011 | Garden
What is best way to defrost hotpoint future rf175b
The model number you gave is not valid. To defrost a fridge you have two options.
Is this a manual defrost? If so boil pot of water and set on rack inside the freezer. You will have to remove big chunks of ice.
Auto defrost fridges. Option 1- Unplug fridge open doors and leave for 24-48 hrs. A bit messy with this so have towels around fridge to soak up water.Option 2- Unplug fridge remove access panel on back wall inside freezer. Take hair dryer and melt all the ice inside on the coils. If you have an ice block you have a problem replace bi metal/efrost thermistat. Heater and/or defrost timer may also be out.
If you have an Ice block on auto defrost models always change the bi metal because they get warped usually inside and ruin them. Test heat with continuity tester and defrost timer by manually advanceing just before shutdown time and letting run through cycle. Should stay in defrost between 8 and 30 minutes.
If you need further assistance or have any questions please comment me back.
Jul 27, 2011 | Refrigerators
I would like to know how to adjust timing through advanceing the distrubtor on my 1990 VW cabrelet
When you loosen the distributor hold down clamp you can either turn the distributor clockwise which will advance the timiming or counterclockwise which will ****** it. It's a good idea to have a timing light on hand to visually be able to see O degrees or your starting point and start experimenting from there. This can be a pretty long trial and error thing so start with small increments tighten clamp and drive and do so until you set it to your liking.
Dec 11, 2010 | 1990 Volkswagen Cabriolet
The ice maker is not working
With the icemaker it could be a cycle thermostat or a water valve or a motor inside of the icemaker. It will be hard to tell you which one. You can try manually advanceing it by moving the fingers clockwise a little and see if it takes off and fill up with water?
Sep 14, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Subzero 532 refridge cooling but freezer won't freeze
Unit has separate compressors and thermostat's. Clean the condenser, if it doesn't improve call for service, as there is a decent chance you will need sealed system work or defrost issue. If you need instructions on cleaning the condenser check subzero.com.also try advanceing the defrost timer as they mostly die in the defrost cycle. Behind the grille there will be a panel with a small hole in it with a screw above and below. Use a flat blde screw driver to turn the gray piece in th small hole clockwise a few clicks. If the freezer comes back on you will need to replace the defrost timer.
Jul 26, 2009 | Sub-Zero 690 Side by Side Refrigerator
The timer on my dryer does not work.
Hi, If the dry is heating and neither the automatic or the time cycle will advance, you will need to replace the timer. You can test the timer by removing the rear panle and locate the 2 black wires on the timer motor. While the dryer is running, check and see if there is 120V going where the black wires attach to the timer contacts.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Maytag PYE2300AY Electric Dryer
Washer wont aggitate, spin or drain
Your drive belt sounds like the problem related to all these, provideing you hear the motor running, and timer is advanceing
Feb 10, 2009 | Roper RAS8445KQ Top Load Washer
Kodak Carousel 760H wont advance or reverse
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
Nov 23, 2008 | Kodak Carousel 4600 Slide Projector
2002-03 GRAND AM GT
It is not advanceing the timeing have it checked and or set.
Sep 03, 2008 | 2002 Pontiac Grand Am
Maytag MDE16CS Electric Dryer Logo
97 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
