Question about Toshiba 50H82 50" Rear Projection Television
Blue shadows on my tv was able to adjust the convergence for the color red but not the blue.
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
If red adjusts but blue does not adjust in some direction one of the two STK-392-110 convergence chips is bad.
Both should be replaced at the same time (about 12 dollars on EBAY) AND THE set will also have a number of small resistors in front and around them (they are usually 1.8 ohm and should read like a fuse).
Repair involves getting the chips out and replacing them. They have 18 pins each and are soldered in.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
Comment here if you have questions or need any help.
REGARDS, SD TECH
Posted on Aug 31, 2010
I have a toshiba tp50h50 rear projection tv and their is a blue shadow behind the words and makes the words a little blurry
Sounds like you need to do a color convergence. If you still have the owner's manual, it will give great detail on how to do this. The convergence menu is accessed from the video menu on the tv.
The tv has three color picture tubes, red, blue and green. The convergence alignment adjust each tube so that color from each tube overlaps each over to create a white image on the screen. Most tv's only allow you to adjust the blue and red colors.
Convergence should be performed each time the tv is moved and at least once annually.
May 16, 2011 | Televison & Video
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Currently, the red and blue color alignment is off and I am unable to adjust this. There is a red shadow with a blue hue. Have tried to realign the colors but can not get the red to move.
Ur tv have a convergence problems,it dead.The convergence board the 2 STK convergence ICS and some or all it resistors are dead.All these parts must be change to get ur convergence back to normal.The shop will u $300-350 for parts and labors.
May 25, 2010 | Philips Magnavox 51MP392H Rear Projection...
Mitsubishi RPTV has a blue shadow/image alignment problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 23, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Has blue shadows
  • Screen looks 3D
Jan 09, 2010 | Hitachi 50UX26B/27K 50" Rear Projection...
HITACHI 57UWX20B has blue ghost shadows how do I
  • Screen looks 3D
Jan 05, 2010 | Hitachi 57UWX20B 57" Rear Projection...
Colors shadowing eachother, adj convergence, but will not save.
Sounds like your convergence IC chips have failed. You can buy the parts from various suppliers or you can just get a complete repair kit from www.TvRepairKits.com
Mar 15, 2009 | Philips 46PP9302 46" Rear Projection...
Red and Blue convergence
you may need a new convergence board only a tv shop can tell you for sure
Nov 03, 2008 | Televison & Video
Toshiba 50H82 50" Rear Projection Television Logo
253 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
