Set up e-mail address in Canon 5020i
How do I save an e-mail address in this model.
  • 38 Answers
1) press the * (star) button with the head shape around it
2) on the screen touch on "Address book Settings"
3) Touch on "register address"
4) Touch on "E-mail"
5) in the bottom left hand corner of the screen touch on "Register New Address"
6) Touch on "e-mail"
7) Touch on "name" and enter the recipients name and press "OK"
8)Touch on "e-mail address" and enter the recipients e-mail address and press "ok"
9) Touch on "ok" again
Repeat steps 6 - 9 to add additional addresses otherwise touch on "done" 4 times to exit the menus
If you wish to register the e-mail addresses in the one-touch address book, follow the steps below:
3) touch on "one touch buttons"
4) touch on an empty block
5) touch on "register/edit"
6) touch on "e-mail"
7) touch on "name" and enter the person's name and press "ok"
8) touch on "one touch button name" and enter the person's name again (here you're restricted to 12 characters so you may need to abbreviate it somehow) and press on "ok"
9) touch on "e-mail address" and enter the e-mail address and press "ok"
10) touch on "ok"
repeat steps 4 - 10 to add more addresses. or touch on "done" 4 times to exit the menus.
Posted on May 11, 2008
Canon imageRUNNER 5020i: Looking for easy instruction to use scan function
there is no real easy way to use the scan function. now if you get the program e-copy desktop and install it on your computer that will be the easiest way to use it.
Jun 23, 2010 | Canon imageRUNNER 5020i Copier
I'm trying to figure out how to scan a document and send it to email using an IKON (Canon) imagerunner C3220 copier? Is this possible?
The following steps will allow you to send and receive E-mail: 1. Make sure you have all of your TCP/IP information set up (IP address, Subnet Mask, Gateway, DNS Server (if one), Host Name, and Domain name of your Domain) before you begin.
2. Enter into the Network Settings and Select E-mail/I-Fax.
3. If you are setting this up for SMTP (Simple Mail Transport Protocol) to send E-mail and I-Fax, enter the IP address or Fully Qualified Domain Name (FQDN) of your mail server in the SMTP Server section. For example: mail_server.organization.company.com. Then enter the email address that will be the default sender in the SMTP Address field.
4. If you use POP3 and want to receive e- imageRUNNER mail and I-Faxes, fill in the IP address or FQDN of your POP3 server and the account added for the imageRUNNER-iR. The password is optional and needs to be entered if set on the e-mail account of the imageRUNNER-iR. Set the POP interval (how often the machine will log in and check for mail).
5. Reboot the device.
* Note - AUTHENTICATION ISSUES -
-If the SMTP mail server requires authentication for sending email, enter Encryption/Authentication login information (SMTP authentication via a username and password).
- For the models that do not support SMTP authentication, the administrator will need to set up a SMTP Relay.
Apr 14, 2010 | Canon imageRUNNER C3220 Color Copier
Scanning problems with canon imagerunner 5020i
if you are using the i send function check smtp server settings
scan to email etc.
if you are using old fashioned pull scanning check your network scangear setup
May 20, 2009 | Canon imageRUNNER 5020i Copier
How to network 5020i
additional function system settings network setting protocol settings tcpip settings puy in your ip adress subnet gateway turn of f then on
Dec 17, 2008 | Canon imageRUNNER 5020i Copier
Need User Manual
I would bug the person you got it from till your blue in the face. They are very hard to come by or find. Mostly, because people throw them out and don't use them... They painic botton push till they find what they want.. Good Luck
Jul 24, 2008 | Canon imageRUNNER 5020i Copier
Canon imagerunner 5020I
Hello loosends,
I can merely make a hypothesis. If you can still print to the device and make copies, then something on your network has changed. Typically it has to do with the smtp server or the dns server. The changes can be brought about by many things. Operating system change (E.G. Vista) , Internet service provider changes, permission changes (your I.T. guru would know about all these , especially the latter) or some other network wide change that I have no way of knowing. Typically if there were an inability to reach an e-mail address or for that matter a shared folder the copier will spit out an error report basically saying that a data transmission failed. However, if permissions to accept scanned documents to e- mail or folders have been changed, which might cause denial of delivery, the copier will know its on a valid network and configured properly and may have no reason to generate an error report as all the criteria it looks for have been satisfied. Meanwhile the scanned document goes out into binary limbo. I guess the question that should be posed is"what if anything possibly changed on your network" about a month ago?
Jul 02, 2008 | Canon imageRUNNER 5020i Copier
Look up error code E00061001 for Canon 5020i
Title : E-061 Error Code Problem :
E-061 code is occurring for the IR5000/6000
Solution :
Check, re-seat or replace the Primary Corona Assembly
Apr 25, 2008 | Canon imageRUNNER 5020i Copier
288 people viewed this question
k24674
jasbo
jasbo
