Question about Brother HL 5250DN Laser Printer
How do I clear a paper jam on brother hl-21 laser printer????
SOURCE: Re: paper jam in brother laser printer hl 2040 : paper red ligh continue to flash
Besides your helpful
there are extra doing steps to make my printer back to normal:
- Remove completely the unit toner cartridge, check paper jammed in that unit
- open the basck lid of the printer , remove all paper jammed in that arrea
- Blow out the container inside of the printer, to blow away all paper depris and dust.
- re-install unnit toner, close back lid\re-strat printer like your suggestion
Many thanks
Have a Nice Day
FP
714-715-6412
Posted on Feb 13, 2008
SOURCE: Paper jam with Brother HL-2030 laser printer
Being a retired electronics technician, I located and downloaded a copy of the service manual. Then proceeded to hunt for the reason why the Paper LED was staying on. I put the printer into the Production diagnoses mode, then by process of alimination opened and closed each panel and cheack each sensor switch one at a time. At which time it was apparent the problem was the rear door sensor. So I started to disassemble the printer getting instructions from the Service manaul, as most electronic equipement there is a sequence process to accompliah this. and once I found that the method of the rear door sensor operated I found the bracket was not in the right position. I put the sensor bar back into it's proper position and put the printer back to normal opperateing mode, I found my problem was solved. So I reassembled the unit and plugged it back into the compter ran a couple of test sheets and cleaned and aligned the printer head(s) made a few adjustment and everything was back to normal.
I must say that locating the Service Manual was a feat, but worth every cent I paid for it which was $9 USD. Personally i think all service manuals should be available for all Brother products for a fee, then a large number of problems can be fixed by the owners without much bother to Brother.
I ahve two of these printers and would still purchase a Brother colour printers, my next purchase is going to be a Brother color laser printer. Out of all the printers i've used on my computers I like the brother the best.
Posted on Mar 22, 2008
SOURCE: Paper jam in Brother HL-2140 printer
I have the same problem - try what it says at this link. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_015.html?reg=us&c=us&lang=en&prod=hl2140_all
Posted on Mar 18, 2009
SOURCE: Paper Jam lite is on ( no paper jam )
did you try turning it off and then back on?
Posted on May 27, 2009
SOURCE: Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Posted on Apr 23, 2010
Paper jam btother prinnter 5140
Hi justus1229,
Just click on this link and you'll have the step by step procedure on how you'll clear paper jam. This troubleshooting works for HL-5140, HL-5150D, HL-5170DN brother printers.
Hope it helps.
Thank you for using Fixya.
Apr 14, 2011 | Brother HL 5140 Laser Printer
Cannot get at paper jammed in printer. How do I do this
You this manual to clear your paper jam.
Directly go to page No. 91 it explains how to open the door and paper tray to clear the paper jam.
http://static.globalcomputer.com/pdf/Brother-HL-2140-Mono-Laser-Printer-Manual.pdf
Regards
Rudra.
Oct 11, 2010 | Brother HL-2150N Laser Printer
HL-5250DN Laser Printer: We have a brother 5250 laser printer. Trying to...
The problem coming because there is some paper jam in side the printer. Remove the toner cartridge and look inside the printer for any paper jam.
I hope it will help to solve your printer problem.
May 18, 2010 | Brother HL 5250DN Laser Printer
Brother Laser 5040 says there is no paper when there is plenty of paper. Have checked for jams and recently replaced drum and toner.
Unplug the printer for about ten minutes. This will clear the NVRAM in the printer. That is where the paper jam's are stored if they get stuck in the printer.
Dec 17, 2009 | Brother HL 5040 Laser Printer
How to clear paper jam in HL 5040 laser printer
Clearing paper jam in a printer is simple almost seven step procedure.
i. Put off the printer.
ii. Open all the covers/shutters on the printer (usually one in front or top and one at the back.
iii. Now pull out the cartridge carefully.
iv. Site the paper that has jammed and pull it out in the opposite direction of its movement. (Pulling the paper in the opposite direction is important for the printer mechanism).
v. Return the cartridge and press it firmly inside.
vi. Close all covers.
Power on your printer and you should be able to print again.
Dec 04, 2009 | Brother HL 5040 Laser Printer
May 27, 2009 | Brother HL-2040 Laser Printer
HL 2040 paper jam light is blinking but there is no jam. the printer sounds like it dies out everytime it tries to print.
Often the paper jam light will stay on when the *back* paper jam door is not cleared.
Open up the back of your printer. There is a 2nd door behind this door that you can pull open. If there is a paper in this section, pull it out and it should clear your red light.
When clearing paper jams, clear the front first, and then if the red light is still on, you need to check the back hidden door for another piece of paper.
Dec 08, 2008 | Brother HL 1440 Laser Printer
Paper JAm
There are three places to clear the jam: 1. Paper tray (remove it and feel inside, clear paper. 2.Open the front (above the manual feed slot) inside is the drum - remove that and the toner cartridge, if necessary. 3. On the back - open the rear chute. You should be able to remove the paper in one of those areas. See the Brother web site for complete pictures ans instructions. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_006.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=4
Aug 20, 2007 | Brother HL-2040 Laser Printer
Brother HL 5250DN Laser Printer Logo
233 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
