Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Lamp Replacement I need to know where the is in order to install the one which I ordered. Does anyone know where I might find it at, I would be most happy. Thank You very very much!!!!!
  • wookie61 Sep 06, 2008
    I Have a lamp ty-la 1000 which my TV manual says is the correct one for my TV after taken the back of the TV off to try and find the lamp i gave up and called some in to replace it for me it turns out the lamp housing is in the front just like you described earlier. Ok so he has the lamp housing out and opening it up get to the lamp it's self when he finely dose the panasonic laamp has a shoe conection on the back of it a sort of push on clip but my replacement lamp does not it just has two nuts the engineer tells me that this is the wrong lamp and will ot work I ask him why he cannot just cut the shoe from the wire and them clamp the wire between the nuts on my new lamp he tells me that the lamp will blow up if i do the and he will be able to order the right one for me. Is this true i cannot use my new lamp with the TV
  • 47 Answers
Take the panel off of the bottom front of the TV - under the screen almost at the floor - with your hands. unscrew the screw on the caution statement and open the panel. you'll see a handle and another screw to the right of it - loosen that screw (it doesn't come all the way out - or shouldn't, anyway). slowly pull the handle until the lamp comes out - if there is busted glass, clear that out. Slide the other lamp inside the television the same way and power back up.
This should work, however - there are a couple of things to cover:
-If you ordered the lamp from Panasonic it would have come already in the assembly. If you ordered it elsewhere it may just be the bulb. If that's the case, you will need to assemble it yourself of have someone do it for you. You do not want to get oil or fingerprints on the bulb as this will significantly reduce it's lifespan.
-You may want to reset the lamp timer in the television once you get the new lamp inserted. First you have to have the television powered on and no messages or menus on-screen from the TV. Then use the original remote and take it to the television, make sure it's in TV mode and aimed at the IR sensor. Then, press and hold VOL- on the TV itself and PIP on the remote at the same time for 5 to 10 seconds. You should get a message that says "lamp time was reset to 0".
Posted on May 13, 2008
  • 4,234 Answers
There are instructions as well as diagrams with the replacement lamp (part # TY-LA1000). Generally speaking the lamp is in the lower back.
Posted on May 09, 2008
How do you reset the lamp clock on Panasonic model number PT-61LCX35 without an original remote?
We regret to inform you the original remote is necessary to reset the lamp hour meter. We recommend you use the below link to obtain the correct remote control for the TV. The remote part number is EUR7627Z70.
Parts Ordering
Mar 17, 2014 | Panasonic Televison & Video
Please get the correct model number (one posted here has too many numbers--label is on back of set)
GOOGLE THE MODEL NUMBER WITH THE WORD "LAMP" AND YOU WILL FIND (if available) the lamp and several places selling it.
Mar 23, 2012 | JVC HD-52Z575 52" HDTV
TV Screen has no picture and is black.
That should fix the problem but do not tuch the lamp of the glass because the oil from fingers will mark lamp
Nov 06, 2009 | Samsung Televison & Video
We bought a new replacement lamp XL2200U for our Sony 60" KDFE60A20 TV, but we need to know how to install it...Please help We removed the old lamp, bulb and casing together, and I ordered the replacement...
Yes, lamp installation procedure is written in user manual of TV and click Sony Support to download user manual copy if required. Lamp replacement is simple process, take out old lamp and slid in new lamp.
Please buy Sony original lamp for TV safety.
Nov 05, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Hitachi replacement bul
Let me know exact model of your Hitachi TV to check bulb availability in parts stores.
Bulb replacement is easy process and mostly it is written on owner's manual of TV.
Please use "add a comment" button to intimate model number of TV.
Thank you.
Apr 06, 2009 | Hitachi REPLACEMENT LAMP, Projector Lamp...
Reset lamp counter for zenith z52dc2d
Go to stand-by mode press "?" key on remote. then press 9 8 7 6 and the ok button. the 3 led lights will flash to verify the lamp timer was reset
Oct 30, 2008 | Televison & Video
New replacement lamp ty-la 100rl not working
If you place order for Panasonic lamp again this time, I think you would not face this problem as in past you had no problem.
Sep 05, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Picture and sound go off every 5 minutes then comes back on
I had this problem (every 30 seconds, not 5 minutes) and ordered a new replacement XL2200 lamp from Sony and that fixed it. By the way, the lamp installs from the front so there's no need to pull your TV out from the wall. Look at you manual, it is accurate in this respect. My lamp only lasted about 15 months. It costs $200 plus about $16 to ship. You can order direct from Sony on line service.
Feb 15, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
InFocus LP630
get it from or from infocus. do not get cheap replacements. you get what you pay for.
Sep 18, 2007 | 3M Projector lamp Projector Lamp
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
532 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
