My kenmore washmachine has stoppedd agitating
  • 1 more comment
  • nvor252 Aug 31, 2010
    the agitator works most of the time but just stops periodically. When it stops I grab the wash machine and vigorously tia it forward two or three times. and then the agitor starts to agitate and also to spin the water aou and centrifically spin he water out of the clothes
    I JUST SENT A LENGTHY ENTRY TO CAULDRON HAS IT GOTTEN LOST IN CYBER SPACE?
    i MENTIONED EARLIER THAT WHEN THE MACHINE STOPS AIATING AND SPINING i VIGOROUSSLY TIP THE MACHINE FORWARD ON ITS TWO FRONT LEGS SEVERAL AND MOST OF THE TIME IT WDILL START TO AGITATE AND SPIN.
  • 5,081 Answers
Does it spin properly?
Washer will not agitate or spin until the lid is closed. The problem is probably the switch that the lid contact/activates. Sometimes the switch is bad, sometimes the lid is not pushing the switch good enough. See where there is something on the lid that pushes into a hole when it closes.
If you hear the motor running, it is a broken transmission coupling
Check th below link for coupling replacement
http://repair2000.com/coupling.html
Posted on Sep 01, 2010
  • Washing Mach... Master
  • 17,130 Answers
Check power to the motor when the program controller is switched on. if there is power but no motion then the motor is faulty . If with a capacitor drive check for fault or replace.
However if there is no voltage to the motor then check the program controller for fault.
Make sure that there is good connections and all inputs are good. Make sure the inlet valve is working to trigger the wash once the water level pressure sensor switches on . So these inputs must be checked for the motor to start working.
Check this out.
Posted on Aug 31, 2010
  • Donald DCruz
    Donald DCruz Sep 01, 2010
    Your comment indicates that you must look out for a loose connecction inside. This is bigger evil as we will end up mentioning all the parts to checck. so checck all connecctions, boards and switches and sensors.
Is there a filter on a whirlpool heavyduty super capacity plus 7 cycle 2 speed washmachine
for top loaders pull up the center section of the agitator and the filter is right at the bottom of that
for front loaders ,consult you user manual
May 11, 2016 | Whirlpool Washing Machines
Agitation very weak turning only one way
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have a GE model WHDRE526E1WW washmachine.The complaint was it would not spin. I checked the agitator coupler and the washmachine agitates but won't spin or fill with water. I suspect it may be the...
Try suspecting the tub end of the water level tube being plugged with " goop " so that the washer thinks it is still full of water, thus will not fill or spin. Take the front panel off by releasing the push in clips at the top of the front panel, in the seam where it meets the washer's top. Now, find the tube at the left side of the outer tub and pull it off the tub. Clean it out or cut off an inch (don't do the cutting thing more than one time) and replace after using a thin wire to clean out the tub end of the attachment. To help prevent this from re-occuering, every few months, fill the washer to the lowest setting with the hottest water, no clothes, and several cups of bleach, and run the longest cycle you have (with no clothes, of course). Make sure to rinse out the tub on a higher water level before you wash a load of clothes.
Sep 06, 2009 | Washing Machines
How do I replace the belt on this machine
take the back off and put the on the small pulley and pull the belt over the large pulley
Apr 20, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water problem
Apr 01, 2009 | Washing Machines
Kenmore washmachine will not fill with water
If the unit is agitating with no water in it, you will need to replace the pressure switch( aka Water level switch) it is located up inside the control panel and has 3 wires and a hose on it.
Good Luck!
Feb 28, 2009 | Washing Machines
Calypso washmachine
you have a flood condition,,or overfill,,we must get rid of the water it seems the pump cant do it,,also it can be tripped or make this display fl if to much suds are in unit ..press stop than cancel and it will clear...than put unit in drain,,if water doesnt drain we have a drain problem that caused the fl error..onthejob
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
