Question about Hotpoint Ultima WF860 Front Load Washer
WR480 ERROR CODE H20
IT DIDN’T SOLVE THE SLOTION FOR THE FIRST TIME, I STILL HAVING
THE PROBLUM WHEN I SWITCH THE MICHINE ON IT TAKES WATER
IN TH FIRST TWO TIMES THE IT RUN OK.BUT FOR THE THIRD TIME
IN THE MIDDLE OF THE CYCLE IT STARTS TO SHOW H20.
PLEASE COULD YOU HELP!
  • Aaron Staunton May 15, 2008
    F 08 Error Message first came up My partner unblocked drainage pipe
    Then restarted machine now starts on the rinse cycle but after ten minutes 'Tap' signal comes on LCD and then H20 flashes on the LCD
    Problem Solver:
  • 7 Answers
H20 fault code means you have a water supply problem.
check you have suficiant water pressure coming into your appliance,and also check that you have no blockages at the sump of the apliance and if plunbed to the sink check for blockages there.
f08 code means that the heater relay is stuck or open curcuit,check connections on your module and check your heater is not open curcuit,if these are ok you will require a module.
Posted on May 18, 2008
Aquarius wmf560 drum not moving after h20 code
if you do not have an instruction manual for this washer then download from this site.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WMF560UK_19507120302_UK.pdf
If the drum is not moving then it is very likely the pressure switch is also faulty. This tells the control that water level has been achieved. It is thinking water is not coming in.
Check this out.
PRESSURE SWITCH
Sep 13, 2014 | Washing Machines
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hi i have a hotpoint washin machine and it kepp showing H20 on the csreen can you please help th model number is WT740
H20 indicates a problem with water supply.
Check the inlet hose/s for restrriction or kinks, ensure water supply pressure is o/k, also check the filter screens in the inlet valves, you will have to turn the water off to do this.
Dec 06, 2010 | Hotpoint Aquarius WD63 Front Load...
H20 ERROR SPIN DRYING
The error indicates a problem with the incoming water supply.
Check for restricted or kinked inlet hose/s, check that tap/s are fully turned on and that you have adequate water pressure.
Mar 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Tv takes long time to switch on,at first it was only 1minute then up to 7mins then I thought it wouldn't come on at all then it came on after one day. I don't switch off. Television is only 2yrs old.
this is a SMPS problum pls. sum capaciter replace. and this problum is solve [*] : pls tv set repareing with tech.
this problum is not majur don wery...
Oct 06, 2009 | Televison & Video
H20
According to the Hotpoint error code list H20 indicates to check taps and pressure of incoming water..
So make sure you have adequate pressure of water at the valves, low hot water pressure can cause problems..
Also what I would do would be to check the filter located in the sump hose at the rear of the m/c,\this can leade to a sticking water level s/w..
Hope this helps.
Plz leave feedback.
Thanks.
Dec 13, 2008 | Hotpoint Ultima WD72 Front Load...
Error code h20
hi sounds like a faulty fill valve easy fix
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Machine fault code "f13"
Plug off the wall. There is a thin rubber tube going from the switch area to the exit near the outlet tube. Probably this is blocked. This tube should be free from any blockage; take out the top clip from this tube and blow into it - it should be free, clear the blockage if any and refit. This is the water level tube which tells the machine when to switch off water, etc.....
Sep 02, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
685 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
