Question about GE Spacemaker JVM1640SJ Microwave Oven
A GE Microwave gives an error F3 model # JVM1750SMC01 few of the buttons do not work and the oven keeps on, had to unplug it. any way to fix this?
MicrowaveSvc
  • 9047 Answers
SOURCE: GE microwave oven - f3 error
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 08, 2008
  • 42 Answers
SOURCE: The oven doesn't work. Gives an F2/F3 error. This
f3 code temp sensor circuit bad ,f2 oven temp higher 500 degrees
Posted on Mar 27, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: I have a ge profile microwave,convection oven,
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
It is part number WB07X10977 and you can get it here for $56.18 (compared to $93.00 from GE!).
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock as shown below:
Posted on Dec 25, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: The F3 code keeps coming on with a beeping sound
F3 means you have a shorted membrane keypad.
If it's under warranty, you should be able to get it fixed free.
The "C" in the model number means it's made for the Canadian market, and contacting GE Canada seems to be impossible for us here in the States.
So you'll need to contact GE via the info in your owner's manual.
If it's out of warranty, it's best to replace it, GE does not make parts available for JES-series microwaves.
One assumes they're meant to be thrown away when they fail out warranty.
Please don't kill the messenger... :)
Posted on Apr 28, 2010
espressonist
  • 1711 Answers
SOURCE: ge psacemaker microwave oven no working it started
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Posted on Dec 26, 2010
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave oven stop working. buttons will not work and an error code F3 come up on display. Could you tell me what this could be?
F3 is a shorted key you need a new keypad control panel. For the JE2160 series countertop model this should be the part#WB27X10681
Dec 06, 2010 | GE JE2160 Microwave Oven
GE Sensor Microwave model JES1456wf001 error code F3....how do we fix . Microwave comes on when plugged in and then reads to set clock and then it rings several times and we get an F3 code
F3 is a shorted key pad. To prove this, unplug the ribbon cable of the key pad from the control board and this symptom should go away when you plug the AC cord back into the wall. BE CAREFUL!!!
Sep 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave shows F3
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
Jul 25, 2008 | GE JE1460 Microwave Oven
Have a ge spacemaker xl1800 - f3 error
I had the same problem. I removed the grill and opened the control panel as I read an answer from "GENE" on APP (Appliance Pros) that this indicated a short in the circuit board (TouchPad). I was going to replace the faulty circuit board but when I opened the control panel there it was......One wire harness had just came unplugged!! I plugged it in, reassembled and the microwave works again!
Mike
Tampa, FL
Jan 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
172 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
