In order to look up the filter change procedure I would need the specific model number. However, filter changes or washing should be done regularly. Look for a very simple lift-out design that is washable in the kitchen or laundry sink. Soak in soapy water and rinse with spray nozzle.
As for the symptom "Blows out warm air" this is expected. The dehumidifier is less than 100% efficient, meaning that the energy that is used produces heat in the exhaust air. A 100% efficient design would still send all the heat energy of condensation (endothermic phase change) into the exhaust air. You should expect 1072 BTU per pint (1 pound of water). This is far more than the heat of crystallization (144 BTU per pound of ice) and therefore much more sensible when you feel the discharge air from the dehumidifier. Dehumidifiers typically operate in basements to both warm and dry the area where a sump pump may be operating to remove the water that seeps through the foundation. A dehumidifier is not a good idea for warm areas of the house. This will decrease the efficiency by increasing the temperature differential needed to get the evaporator coil below the dew point to cause condensation. The condenser coil will be much hotter than expected if the unit is operated in a warm humid room. Only air conditioners which discharge condensate and exhaust air to the outside of the structure should be used to cool a room.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in. You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
I think you are asking about a portable air conditioner, not a de-humidifier. With that assumed, the answer is, NO - that is not a good idea. The exhaust tube is for getting rid of the heat that you have pulled from the room you are cooling, plus the extra heat that the device itself creates. This is a considerable amount of heat, which will quickly heat up the closet and leak back into the room you are trying to cool. If the closet it tightly sealed, the unit will not be able to push the air through the tube, and the unit itself will overheat. The result will be that you will be buying electricity to actually RAISE the temperature of the room you are trying to cool.
This may be caused by running the unit in continuous mode, rather than timed mode. The heat is generally is generated when the defrost mode cycles on, to defrost the cooling coils. This happens more frequently, if the air space around the unit is obstructed or it's operating in a temperature range of 40 to 60 F. Cleaning the air intake filter at least once a week, can help solve this problem, too.
Maintain a minimum of 12" free air space around all sides of the dehumidifier. Use a timed mode rather than a continuous mode. Make sure the room is within the proper operating temperature range and clean the air intake filter weekly.
Hope this helped you troubleshoot and solve the problem.
Yes. Wet clothing would act to put Humidity in the air. think of the air as a sponge the more you heat the air the more the air will take moisture out of its surrondings. The more you cool the air the less moisture it can hold.
a Dehumidifier is a reverse refrigrator.. Air is forced over cool coils and the moisture forms and freezes on the coils (ice). The unit turns off and the coil and ice takes heat up from the surrounding area (makes room colder;Clothing takes longer to dry; The temperature in that room should be were people reside 70-80 degrees). the ice melts and water drips into a holding container which you dump periodically. Solution: 1. remove wet clothing or 2. raise temperature in room. 3. put a space heater in that room instead of Dehumidifier
The
coils you see on the back of your dehumidifier are the evaporator. When
the unit runs, the coils get very cold. As the fan draws the room air
over the coils, the humidity in the air condenses out of the air onto
the cold coils. But, if the temperature of the air the fan draws over
the coils is too cool, the humidity that condenses out of the air
freezes on the coils. To remedy this problem, you can try any of these:Warm up the room the dehumidifier is in.Put the dehumidifier on a sturdy table (the room air is coolest near the ground).Turn the unit off until the room warms up.
The
Dehumidifiers are designed to remove the moisture from the air not to cool.
Unfortunately, the way they remove this moisture is to reheat the air to
further dry it after it releases its moisture. Basically, the room
temperature humid air enters the dehumidifier where it is cooled to its
dew point which results in its releasing its moisture. This dried air is
then heated by the combination of latent heat of condensation, which is
a natural result of the process, and by circulating through the
condenser where heat is exchanged from it to the air. The result is the
air going back into the room will be slightly warmer than it was going
in, usually around 2 to 5 degrees.
A) The warm air that is being expelled from your dehumidifier is normal. When the unit is dehumidifying the compressor is working which causes the compressor to become quite hot. In order to avoid having the compressor overheat, air is drawn by the compressor at a rapid rate and the heat is then transferred to the air which must be expelled from the unit. The warm air will stop shortly after the unit has reached the desired humidity. This warm air should not change your room temperature by more than a degree or two.
