Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Question: atsc tuner
Does the samsung HCN4226W have an atsc tuner ?
Posted on May 30, 2008
How do I get my 7" widescreen lcd tv with atsc tuner to show channel numbers?
ATSC Digital (VIRTUAL!) Channel NUMBERS vs Actual Channel ...
Jul 2, 2010 - 4 posts - ‎4 authors
Then came ATSC tuners and digital - [I was about 20 minutes into .... *SHOULD*display the SAME VIRTUAL CHANNEL NUMBER when tuned ... iView-3500STB Tuner & DVR Owners Thread - AVS ...
Mar 30, 2013
Dec 3, 2005
More results from
Jan 13, 2016 | Televison & Video
Is the Rca true flat digital
I'd need the model number to tell if the RCA TV has a digital (ATSC) or analog (NTSC) tuner. The mandate for inclusion of the ATSC tuner depended on the size of the TV and the year of manufacture. Small (<25" diagonal) TVs didn't need to have an ATSC tuner when they were built until 2007. The older TVs could still be sold with a "cable-ready" or similar NTSC only label. (The 32"+ TVs had to have the ATSC tuners in 2005 and the mid-size TVs had to have the digital tuners in 2006.)
For example the 27F530T was manufactured in 2003 and only has a NTSC tuner. However, the 20F424T was manufactured in 2008 and does have an ATSC tuner.
I hope this helps.
Aug 07, 2015 | RCA Televison & Video
How can i tell if my tv is digital
The iLo IWT3206 TV provides two built-in -- or integrated -- TV tuners: a National Television System Committee (NTSC) tuner and an Advanced Television Systems Committee (ATSC) tuner.
While the NTSC tuner allows iLo IWT3206-viewers to receive analog, free-to-air TV broadcasts, the ATSC tuner allows viewers to receive digital TV broadcasts via a cable or satellite provider.
The benefit of having an integrated ATSC tuner is that it negates the need for a separate cable box or satellite receiver, which can take up space.
Oct 24, 2013 | iLO IWT3206 TV
Is jvc av-32d503 digital ready or do I need to buy a converter box for use with an outside antenna system
Looks like you'll need a converter.
Here's some background info:
Analog TVs were made up until 2007.
Digital tuners for over the air signals are called "ATSC tuners".
To tell if your TV has one:
-If the TV was sold as a "HDTV" or "DTV", it's supposed to have an ATSC tuner built in to it. "HD ready TVs" do not have a digital tuner.
-Check the specs in the owners manual or google the make & model of the TV to see if it has an ATSC tuner.
-If your TV's menu has an option for scaning for digital channels, then it has an ATSC tuner. If it dosen't have a way to scan for digital channels, then it doesn't have a digial tuner.
Most DTVs also have a digital QAM tuner that is used in some (but not all) cable systems.
Jun 11, 2011 | JVC AV-32D503 32" TV
Does this model have a built-in QAM tuner?
Yes it does.
  • Includes built-in ATSC/QAM/NTSC tuner for off-air HDTV and SD (standard-definition) reception
  • Accepts high-definition 1080i, 720p, and 480p signals from DTV set-top receivers and progressive-scan DVD players
  • Side-panel A/V hookups and controls allow easy connection with a camcorder, gaming console, or other device
  • Aug 15, 2009 | Samsung DynaFlat TX-P2775H 27" TV
    I don't know how a program it, since you change digital.
    So far as I know the HLN series does not have an ATSC tuner, thus no over the air (OTA) reception. You can probably still get a $40 coupon for an OTA ATSC to NTSC converter. Note that will NOT get you high definition (HD). With Dish you can get HD receivers that do get OTA ATSC both HD and SD. With Direct, no OTA AFAIK. With cable you would need a QAM tuner, not in your TV AFAIK to get clear channels as required for locals. Otherwise cable needs a Set Top Box for digital and scrambled channels although the standard definition (SD) non-scrambled channels work with your NTSC tuner. Too bad there seem to be no ATSC to 5-cable RCA or HDMI HD converters except Dish. -Ken
    Aug 10, 2009 | Samsung HLN617W 61" Rear Projection HDTV
    Programming a ATSC DTV tuner on a RCA Universal Remote
    Try a code for a "satellite receiver" of the same manufacturer of your DTV tuner. I've heard of a cross-remote complaint with the DirectTV box and the DTVPal box. Note, your DTV tuner may say RCA, but it could be manufactured by a common DTV tuner maker. The system looks very close to a Zinwell. Don't have an RCA model to try the codes out, though.
    Dec 27, 2008 | Televison & Video
    Tv Tuners
    Hey jp62388,
    According to information provided by the manufacturer, this model TV should have a built-in NTSC/ATSC and QAM tuner. These should allow you to receive locally broadcast digital TV signals without the use of a set-top box or digital converter box.
    If you're concerned about your TV's specifications, the most important thing you'll need to look for is a built-in or integrated ATSC tuner. NTSC is the old analog standard that is to be phased out in early 2009, while ATSC is the new digital standard that is to be used within the United States and Canada as NTSC’s replacement.
    Should you have any other questions or concerns, I'd strongly suggest checking out the FAQ section of the federal government’s official DTV transition website:
    Hope this helps you out.
    Go Ahead. Use Us.
    Jul 03, 2008 | Televison & Video
    To see if my tv has a digital tuner?
    you will need to get an adapter box,,,or a dvd recorder with an atsc tuner in it..(you might find a vcr with an atsc tuner but i doubt it
    Nov 27, 2007 | Televison & Video
    Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
    Jerry Greenberg
    Jerry Greenberg
